Edit FCCircularText
Edit FCCircularText
Hi all,
When creating an FCCirculartext, is it possible to edit the parameters after creation?
Or is it either: know the precise values when creating, or trial and error?
If I create it as a compound, I can use the transform tool to reposition it but the text itself sits between 2 closely spaced half circles and needs to be pretty precise.
Thanks,
Jim
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks,
Jim
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Edit FCCircularText
hi 56jimalexander
if you give the limits in a file I can help you
mario
you must use : Macro_Rotate_To_Point56jimalexander wrote: ↑Mon Aug 02, 2021 12:52 am When creating an FCCirculartext, is it possible to edit the parameters after creation?
yes for the moment (you have the undo/redo or delete the last creation for facilitate the re-creation)56jimalexander wrote: ↑Mon Aug 02, 2021 12:52 am know the precise values when creating, or trial and error?
then not modifiable
if your text is right (not inclination) tray create the line directrice select it and use the Path tab (the text follow the complete path (line, arc ...))56jimalexander wrote: ↑Mon Aug 02, 2021 12:52 am I can use the transform tool to reposition it but the text itself sits between 2 closely spaced half circles and needs to be pretty precise
mario
Thank you for these tips!
I now realize that the text is not ordered correctly in the creation. Please see the attached parameters and resulting creation.
Jim
Jim
- FFCircularText_test.FCStd
- (73.64 KiB) Downloaded 44 times
- Macro_parameters.jpg (280.96 KiB) Viewed 2076 times
hi
the circle begin right to left (depend also to begin and end angle)
you must use the reverse button
i give 83 degrees instead 90
mario
mario
Hi Mario,
Yes, I am able to duplicate your output but I don't understand why it works.
Also, why 83deg rather than 90deg?
When I choose "reverse" the letters in the box change to what was I was outputting previously.
Can you give me some clarification on this please?
Thank you,
Jim
Thank you,
Jim
hi
angle = 270 - 90 = 180 to work
180 / 27 = 6.6 degrees by characters but really 26 characters then stay 6.6 degrees
result : why 83deg rather than 90deg? 90 - 6.6 round(7) = 83
why + 1 character : for not always adding one space in end word for rotation and begin 0 to 360-x degrees instead 0 to 360 (or 0 to 0)
(maybe not good idea)
make a tests, use reset button ... enjoy
mario
example with DERMATOLOGIST RECOMMENDED = 25+1 characters (internal 25+1+1 = 27)
depend begin end angle, flat or stand position56jimalexander wrote: ↑Mon Aug 02, 2021 8:20 pm When I choose "reverse" the letters in the box change to what was I was outputting previously.
mario
Thank You Mario for this excellent information.
I know, this is an old thread. But it looks somewhat related to my change;-) I was not happy with the letter spacing, so I tried to hack it to take the width of the letters into account. So far, I only changed the 'flat outer' layout and probably broke the others in the process! But something similar could probably be done for all of them;-)
Maybe, this helps somebody or is an inspiration for others;-)
Have fun,
-- Marco
Have fun,
-- Marco
@mario52, you may want to have a look?
Hi
good work , i have also this idea (BBox) but i didn't know how to combine angle and boundbox i have not successful and then not follow this way
i have little problem with your modification:
very well with
mario
yes thanks
no problem right post
OS: Windows 10 build 19045
Version: 0.22.0dev.33909 (Git)
Version: 0.21.0.33682 (Git)
Version: 0.21.0.33668 +7 (Git)
Version: 0.22.0dev.33981 (Git)
Version: 0.20.2.29177 +426 (Git)
Version: 0.19.24267 +148 (Git)
