FreeCAD external Python interpreter will not return body object on Ubuntu 20.04
Aleks
Post by Aleks »
[SOLVED]
Problem:
I have created this topic to document that I am having issues with the python interpreter on my server. I do not understand what is causing the problem or even what is the problem. The program runs just fine on ubuntu and windows when running it locally. The Python interpreter just says
shape = Part.getShape(doc.getObject('Body001'), '')
TypeError: argument 1 must be App.DocumentObject, not None
I am using ubuntu 20.04, nginx, gunicorn, supervisor, venv, flask.
Maybe someone in the future will have the same problem and can comment.
Solution:
The problem was that PartDesign needed to be imported differently and because of that body objects werent recognized. This is not needed on Windows. On Windows, PartDesign can be imported without adding '.../Mod' to path.
Using FreeCAD without a GUI and with an external Python interpreter on Ubuntu (20.04, does probably also apply to other Ubuntu versions).
If I won't forget I will keep this list updated.
1. Use PPA stable FreeCAD distribution
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
sudo apt update
sudo apt install freecad freecad-doc
2. Make sure that the external Python interpreter version is the same as the FreeCAD build-in version
freecadcmd
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import sys
>>> sys.version
'3.8.10 (default, Jun  2 2021, 10:49:15) \n[GCC 9.4.0]'
python3
>>> import sys
>>> sys.version
3. Add 'usr/lib/freecad-python3/lib' and 'usr/lib/freecad/Mod' to path ('.../Mod' is important for Python modules, especially PartDesign to work)
import sys
FREECAD_PATH = 'usr/lib/freecad-python3/lib' #needed for C++ modules or FreeCAD (e.g. 'FreeCAD.ActiveDocument')
FREECAD_MOD_PATH = 'usr/lib/freecad/Mod' #needed for PartDesign and other Python modules
if FREECAD_PATH in sys.path:
    pass
else:
    sys.path.append(FREECAD_PATH )
if FREECAD_MOD_PATH in sys.path:
    pass
else:
    sys.path.append(FREECAD_MOD_PATH )
try:
    import FreeCAD
except Exception:
    print('Cannot import FreeCAD.')
try:
    import PartDesign
except Exception:
    print('Cannot import PartDesign.')
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
jbi
Re: Issues with FreeCAD python interface on server
Post by jbi »
difficult to diagnose but i guess you are running without gui on the server, and with gui locally? no gui will mean no document object.
openBrain
Post by openBrain »
jbi wrote: Thu Sep 09, 2021 6:13 pm no gui will mean no document object.
Totally false. ;)
App::DocumentObject also are there in CLI mode.
Gui::DocumentObject and ViewProvider aren't.
Aleks
Post by Aleks »
I cannot provide more information om this, because I dont have any. But I already have quite a lot of experience with running in cli and I have never had that problem before. This may be related to dispatching multiple flask apps in combination with one freecad interface, but idk. As I said, maybe someone will have a similar problem in the future and we could compare. This is probably some edge case of the tech stack that is leading to this problem. I am able to run a single flask app on a vm with the freecad python interace just fine.
The reason I am even attempting to run multiple freecad web apps on one server is to cut down on server costs.
Aleks
Post by Aleks »
These are the differences between the setup that works and the one that doesnt.
works:
Windows 10 Pro
werkzeug
Python 3.8.8
does not work:
Ubuntu 20.04
Nginx
Python 3.8.10
My next guess is that some setting in nginx prevents the webapp from functioning correctly.
Aleks
Post by Aleks »
I have reduced this problem to the line
body = doc.getObject('Body001', '')
This code returns none.
In the freecad internal interpreter this works fine, while using the freecad python interface does not. The only differences left are
- Python 3.8.8 (FreeCAD) vs Python 3.8.10 (Webapp) and
- Windows 10 Pro vs. Ubuntu 20.04
What could be the case is that Python 3.8.8 and Python 3.8.10 are not compatible on Ubuntu 20.04, while they ARE compatible on Windows 10 Pro.
Whats funny, is that the exact code works fine in a different app with the exact same tech stack.
openBrain
Post by openBrain »
DO you explicitly recompute Body001 and/or document in the script before accessing it ?
Another thing is that sometimes in CLI mode, the shape of the object need to be explicitly tesselated with something like
Body001.Shape.tesselate(0.1)
Aleks
Post by Aleks »
In my initial code I did recompute the document before accessing the body object. But I have now removed everything, but the single line I have shown in my previous post.
Why do I need to tesselate the body? On Windows I do not get the error.
openBrain
Post by openBrain »
Aleks wrote: Fri Sep 10, 2021 4:00 pm Why do I need to tesselate the body? On Windows I do not get the error.
I didn't say you need, I said it happened sometimes in the past.
Are you sure eg. you have the same OCC version on both setups ?
Aleks
Post by Aleks »
I dont know. I will check it.
On Ubuntu I am using the latest stable PPA build.
On Windows I am using FreeCAD 0.19.24276.
Do you think that OCC can be causing this problem?
