FreeCAD external Python interpreter will not return body object on Ubuntu 20.04
openBrain
Re: Issues with FreeCAD python interface on server
Post by openBrain »
I'd bet for a no, but who knows ???
Aleks
Post by Aleks »
My best bet is the python version incompatibility, I will check that later.
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
Aleks
Post by Aleks »
Looks like I cannot even get the body object on ubuntu using the python interface with
doc.getObject('Body001')
-> returns none
or
doc.getObjectsByLabel('Body001')
-> returns empty list
openBrain
Re: Issues with FreeCAD python interface on Ubuntu
Post by openBrain »
Could you just give output of
doc
and
doc.Body001
Aleks
Post by Aleks »
doc
does not return anything
print(doc)
returns
<Document object at ...>
doc.Body001
and
print(doc.Body001)
both return
Attrubute error: 'App.Document' object has no attribute 'Body001'
This only happens on ubuntu when using an external interpreter. All of this works fine on ubuntu in the internal interpreter and on Windows using the internal interpreter and an external one.
openBrain
Post by openBrain »
You have to be careful when using an external interpreter. It has to be the exact same version of Python as the one FreeCAD was compiled with.
Aleks
Post by Aleks »
Thats why my best bet was the interpreter incompatibility but I thought that 3.8.8 (FreeCAD) and 3.8.10 (external) would be compatible. I will give an update once I have installed python 3.8.8 as the external interpreter, but it does not look like its as straight forward as installing the latest stable version.
Aleks
Post by Aleks »
I am still working on installing Python 3.8.8 on Ubuntu 20.04.
I have also tested other FCStd files with very simple bodies, just to be sure, and I also cannot get them using
doc.getObject("Body")
returns None
Aleks
Post by Aleks »
I have installed Python 3.8.8 and it still does not work. FreeCAD just wont return the body object. Can anyone verify this? Operating system is Ubuntu 20.04 with external Python interpreter version 3.8.8. FreeCAD 0.19.2 PPA-stable. This works on Windows 10.
Use this code:
import sys
# Set working directories
FREECAD_FILES = '/home/aleksander/test-multi-flask-freecad/freecad-files'
# Initialize FreeCAD python interface
sys.path.append('/usr/lib/freecad-python3/lib')
try:
    import FreeCAD
except ValueError:
        print('FreeCAD library not found. Please check the if the FREECAD_PATH variable is correctly set')
try:
    import Part
except:
    print('One of the FreeCAD workbenches is missing.')
try:
    doc = FreeCAD.openDocument(str(os.path.join(FREECAD_FILES, 'test.FCStd')))
    print('FreeCAD file successfully loaded!')
except:
    print('FreeCAD file could not be loaded')
body = doc.getObject('Body')
print(body)
#shape = Part.getShape(body, '')
openBrain
Post by openBrain »
Aleks wrote: Wed Sep 15, 2021 12:29 pm I have installed Python 3.8.8 and it still does not work. FreeCAD just wont return the body object. Can anyone verify this? Operating system is Ubuntu 20.04 with external Python interpreter version 3.8.8. FreeCAD 0.19.2 PPA-stable. This works on Windows 10.
I don't really understand why you had to install a specific Python version. The principle of the PPA is to compile FreeCAD against the Python version available in the distro repo... :?
