Trouble Setting Circle Radius Programatically
browntoastjam
Post by browntoastjam »
Hello All,
I am trying to set the radius of a circle in a sketch programmatically:
sheet = (FreeCAD.getDocument('model').getObject("Spreadsheet")
avgdia = (sheet.shankdia1  + sheet.shankdia2)/2.0
sketch = FreeCAD.getDocument('model').getObject('Sketch018')
for count, value in enumerate(sketch.Constraints):
	if value.Type == "Radius":
		print(count,value)
		sketch.addConstraint(Sketcher.Constraint('Radius',count,avgdia))
However I see no changes to the sketch. Any idea about what I am doing wrong?
There are no error messages in the report view.
Thanks.
OS: Ubuntu 20.04.3 LTS (XFCE/xubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
chennes
Re: Trouble Setting Circle Radius Programatically
Post by chennes »
Does your sketch already have a radius constraint, which you are trying to update? Or is it unconstrained, and you are trying to add a new one? To me this code looks like it's trying to do some combination of both.
Chris Hennes
Pioneer Library System
TheMarkster
Post by TheMarkster »
try this (untested)
sketch.setDatum(count,value)
chennes
Post by chennes »
TheMarkster has it, I think: for your case, something like
        sketch.setDatum(count, avgdia)
Chris Hennes
edi
Post by edi »
browntoastjam wrote: Fri Sep 17, 2021 11:44 pm
		print(count,value)
I think, in this loop you are running through all existing constraints. If a 'Radius'-constraint is found, a new constraint is appended at the end of the list. So you have two constraints at the object with the GeoId "count", having different radius values.
