Hello All
Is there a way to call the multiloft function from the Curves WB?
The wiki page is quite blank (on scripting)
For concreteness, I have three faces (face1,face2,face3) and I want to run multiloft on them.
Thanks
OS: Ubuntu 20.04.3 LTS (XFCE/xubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
How to call Multiloft from Curves WB
Re: How to call Multiloft from Curves WB
You want to build a loft shape through face1, face2 and face3 ?
Then you don't need multiloft.
Part.makeLoft() will do it :
Help on built-in function makeLoft:
makeLoft(list of wires,[solid=False,ruled=False,closed=False,maxDegree=5]) -- Create a loft shape.
wires = [f.Wire1 for f in (face1,face2,face3)]
loft = Part.makeLoft(wires, solid=True)
Part.show(loft)
It could be useful in Curves to have a feature python loft object that can loft between selected subobjects, for example loft between a selected edge and a selected face or a selected vertex and a selected face, etc. MultiLoft, as I understand it, uses all faces of selected objects.
But already some problems I ran into. In some experiments I have tried lofting between vertices, but Part.makeLoft() always fails. In the Gui the Part::Loft object can manage one vertex and another profile, example: loft between part::vertex and part::plane to create pyramid. I don't know why the Gui can succeed with vertices, but not the python function. Either I am doing something wrong or in the Gui version something is done to fix it, but even in the Gui vertex to vertex lofting is not supported. Workaround for that is simply make a line and use that for the shape.
A trick for vertex to other subobject lofting could be to make a very, very scaled down copy of the other subobject to replace the vertex in the loft. For example, the user selects a vertex and a face the loft is done between the face and a scaled down copy of the face placed at the position of the vertex.
When lofting face to face another problem can be the self-intersection. Here I select 4 faces from the 3 prisms and try to loft them.
>>> ### Begin command to_console
>>> doc1 = FreeCAD.getDocument('Unnamed')
>>> o1 = doc1.getObject('Prism002')
>>> f1 = o1.Shape.Face4
>>> o2 = doc1.getObject('Prism')
>>> f2 = o2.Shape.Face1
>>> f3 = o2.Shape.Face3
>>> o3 = doc1.getObject('Prism001')
>>> f4 = o3.Shape.Face4
>>> _sub_link_buffer = ((o1,('Face4')),(o2,('Face1')),(o2,('Face3')),(o3,('Face4')),)
>>> ol = (o1,o2,o3,)
>>> fl = (f1,f2,f3,f4,)
>>> ### End command to_console
>>> loft = Part.makeLoft([f1.Wire1,f2.Wire1,f3.Wire1,f4.Wire1],True,True)
>>> Part.show(loft)
Edit: attach file
- loft_experiment.FCStd
- (23.2 KiB) Downloaded 20 times
