evalExpression as a class/static method
Zoltan
Post by Zoltan »
I would like to evaluate an expression using FreeCAD's expression engine. The expression I have at hand is not connected to any document object, I just want to use the evaluation capability of the expression engine, something like this:
App.DocumentObject.evalExpression('2+2')
It doesn't work, so I guess evalExpression cannot be called as a class method. It is a pity because creating a dummy object (and hide it) just for the sake of the evaluation capability seems an overkill to me:
obj = App.ActiveDocument.addObject('App::FeaturePython')
obj.ViewObject.ShowInTree = False
obj.evalExpression('2+2')
Is there a simpler way?
openBrain
Re: evalExpression as a class/static method
Post by openBrain »
With a mobile now so can't test by myself, does that work?
App.DocumentObject().evalExpression('2+2')
Zoltan
Post by Zoltan »
@openBrain
Makes sense to try the evalExpression on the object and not on the class. However, it does not work either (seems to be an abstract class). Here are the tracebacks:
RuntimeError: You cannot create directly an instance of 'DocumentObjectPy'.
TypeError: descriptor 'evalExpression' for 'App.DocumentObject' objects doesn't apply to a 'str' object
openBrain wrote: Wed Sep 22, 2021 12:50 pm
Doesn't work either. Message:
openBrain
Post by openBrain »
Zoltan wrote: Wed Sep 22, 2021 12:56 pm @openBrain
Unfortunately this is what I expected but want to give a try though...
TheMarkster
Post by TheMarkster »
You could check to see if there are any objects in the document already and use one of them.
if App.ActiveDocument and App.ActiveDocument.Objects:
    App.ActiveDocument.Objects[0].evalExpression("3*2")
Is there a way to make a document object that does not appear in the tree? I know there is a context menu option to hide the object, but it still appears in the tree, but with some kind of overlay added to the icon.
Snip macro screenshot-aedc86.png (66.09 KiB) Viewed 1740 times
Zoltan
Post by Zoltan »
TheMarkster wrote: Wed Sep 22, 2021 5:13 pm You could check to see if there are any objects in the document already and use one of them.
True, but I cannot count on the fact that at least one document object exists.
The object appears only if the "Show Hidden Items" is enabled in the context menu. You can also hide an item programmatically (as I showed above) by
A third way to hide an object: select it, click on the View tab, and then change the Boolean value of the "Show In Tree" property.
By the way, this is how I found this property programmatically: hover your mouse over the "Show In Tree" text to see that its underlying property is "ShowInTree".
TheMarkster
Zoltan wrote: Wed Sep 22, 2021 9:12 pm
You can't count on it, but by checking first you can avoid creating one unnecessarily in some instances.
Ah, yes, thanks. I overlooked that (ShowInTree) in your post. I might be able to use this for something I have on the back burner. I experimented by entering it in the python console, but still I get the overlay icon and the object is still in the tree unless I toggle Show Hidden on/off, but I don't know how to do that in python. Maybe it works better in a macro/workbench.
What I would really like to be able to do is create a sketch in memory not in the tree with something akin to Part.makeLoft(), but it would be Sketch.makeSketch() or something along those lines.
Neat trick. I can't seem to reproduce. I don't see anything when I hover the mouse over Show in Tree. Is this in a debugger?
Founder
Post by wmayer »
Here you will find the implementation of evalExpression() and as you can see the first parameter passed to Expression::parse() is getDocumentObjectPtr() that points to an instance of a DocumentObject.
As a test I have replaced getDocumentObjectPtr() with nullptr and calling
obj.evalExpression("2+2+")
succeeded. So, this means it's possible that an expression can be evaluated outside the context of a DocumentObject instance and thus a class method should work, too.
Zoltan
Post by Zoltan »
That icon indicates that the object is hidden.
If you enable showing the hidden items, they will be shown of course.
Do this:
App.ActiveDocument.ShowHidden = True
Here is a GIF that demonstrates it.
When you create a document object and add it to the document, it will appear in the tree view (unless you hide it). If you want to work "in-memory", do not associate your custom class object with the Proxy field of a document object.
