Thanks again for the software and the forum in general. The answers are fast.
Today I was running a python script on a ubuntu machine (python 3.8) outside FreeCAD python console (that is, the ubuntu regular terminal) from this page https://wiki.freecadweb.org/Embedding_FreeCADGui
(the section called "Without even firing up the FreeCAD Gui")
I will show just the first lines
import os, sys, FreeCAD, FreeCADGui
from PyQt4 import QtCore, QtGui
from PyQt4.QtGui import QMainWindow, QWorkspace, QAction, QFileDialog, QApplication
from pivy.coin import SoInput, SoDB, sogui
Which I couldn't run without errors. I discovered that if I changed the PyQt4 for PySide like this
PYSIDEPATH='/usr/share/freecad/Ext'
FREECADPATH= '/usr/lib/freecad-python3/lib'
PIVYPATH='/usr/lib/python3/dist-packages/'
import sys
sys.path.append(FREECADPATH)
sys.path.append(PYSIDEPATH)
sys.path.append(PIVYPATH)
import os, FreeCAD, FreeCADGui
from PySide import QtCore, QtGui
from PySide.QtGui import QMainWindow, QWorkspace, QAction, QFileDialog, QApplication
I could check that all the other modules imported from PySide.QtGui DO exists, the only missing is 'QWorkspace'.ImportError: cannot import name 'QWorkspace' from 'PySide.QtGui' (/usr/share/freecad/Ext/PySide/QtGui.py)
I imagine that maybe the name of the module was changed in an update (I'm using FreeCAD 0.19)
I check dir( PySide.QtGui) and got all this:
>>> dir(PySide.QtGui)
['QAbstractButton', 'QAbstractGraphicsShapeItem', 'QAbstractItemDelegate', 'QAbstractItemView', 'QAbstractOpenGLFunctions', 'QAbstractScrollArea', 'QAbstractSlider', 'QAbstractSpinBox', 'QAbstractTextDocumentLayout', 'QAccessible', 'QAccessibleEditableTextInterface', 'QAccessibleEvent', 'QAccessibleInterface', 'QAccessibleObject', 'QAccessibleStateChangeEvent', 'QAccessibleTableCellInterface', 'QAccessibleTableModelChangeEvent', 'QAccessibleTextCursorEvent', 'QAccessibleTextInsertEvent', 'QAccessibleTextInterface', 'QAccessibleTextRemoveEvent', 'QAccessibleTextSelectionEvent', 'QAccessibleTextUpdateEvent', 'QAccessibleValueChangeEvent', 'QAccessibleValueInterface', 'QAccessibleWidget', 'QAction', 'QActionEvent', 'QActionGroup', 'QApplication', 'QBackingStore', 'QBitmap', 'QBoxLayout', 'QBrush', 'QButtonGroup', 'QCalendarWidget', 'QCheckBox', 'QClipboard', 'QCloseEvent', 'QColor', 'QColorDialog', 'QColormap', 'QColumnView', 'QComboBox', 'QCommandLinkButton', 'QCommonStyle', 'QCompleter', 'QConicalGradient', 'QContextMenuEvent', 'QCursor', 'QDataWidgetMapper', 'QDateEdit', 'QDateTimeEdit', 'QDesktopServices', 'QDesktopWidget', 'QDial', 'QDialog', 'QDialogButtonBox', 'QDirModel', 'QDockWidget', 'QDoubleSpinBox', 'QDoubleValidator', 'QDrag', 'QDragEnterEvent', 'QDragLeaveEvent', 'QDragMoveEvent', 'QDropEvent', 'QEnterEvent', 'QErrorMessage', 'QExposeEvent', 'QFileDialog', 'QFileIconProvider', 'QFileOpenEvent', 'QFileSystemModel', 'QFocusEvent', 'QFocusFrame', 'QFont', 'QFontComboBox', 'QFontDatabase', 'QFontDialog', 'QFontInfo', 'QFontMetrics', 'QFontMetricsF', 'QFormLayout', 'QFrame', 'QGesture', 'QGestureEvent', 'QGestureRecognizer', 'QGradient', 'QGraphicsAnchor', 'QGraphicsAnchorLayout', 'QGraphicsBlurEffect', 'QGraphicsColorizeEffect', 'QGraphicsDropShadowEffect', 'QGraphicsEffect', 'QGraphicsEllipseItem', 'QGraphicsGridLayout', 'QGraphicsItem', 'QGraphicsItemAnimation', 'QGraphicsItemGroup', 'QGraphicsLayout', 'QGraphicsLayoutItem', 'QGraphicsLineItem', 'QGraphicsLinearLayout', 'QGraphicsObject', 'QGraphicsOpacityEffect', 'QGraphicsPathItem', 'QGraphicsPixmapItem', 'QGraphicsPolygonItem', 'QGraphicsProxyWidget', 'QGraphicsRectItem', 'QGraphicsRotation', 'QGraphicsScale', 'QGraphicsScene', 'QGraphicsSceneContextMenuEvent', 'QGraphicsSceneDragDropEvent', 'QGraphicsSceneEvent', 'QGraphicsSceneHelpEvent', 'QGraphicsSceneHoverEvent', 'QGraphicsSceneMouseEvent', 'QGraphicsSceneMoveEvent', 'QGraphicsSceneResizeEvent', 'QGraphicsSceneWheelEvent', 'QGraphicsSimpleTextItem', 'QGraphicsTextItem', 'QGraphicsTransform', 'QGraphicsView', 'QGraphicsWidget', 'QGridLayout', 'QGroupBox', 'QGuiApplication', 'QHBoxLayout', 'QHeaderView', 'QHelpEvent', 'QHideEvent', 'QHoverEvent', 'QIcon', 'QIconDragEvent', 'QIconEngine', 'QImage', 'QImageIOHandler', 'QImageReader', 'QImageWriter', 'QInputDialog', 'QInputEvent', 'QInputMethod', 'QInputMethodEvent', 'QInputMethodQueryEvent', 'QIntValidator', 'QItemDelegate', 'QItemEditorCreatorBase', 'QItemEditorFactory', 'QKeyEvent', 'QKeyEventTransition', 'QKeySequence', 'QKeySequenceEdit', 'QLCDNumber', 'QLabel', 'QLayout', 'QLayoutItem', 'QLineEdit', 'QLinearGradient', 'QListView', 'QListWidget', 'QListWidgetItem', 'QMainWindow', 'QMatrix', 'QMatrix2x2', 'QMatrix2x3', 'QMatrix2x4', 'QMatrix3x2', 'QMatrix3x3', 'QMatrix3x4', 'QMatrix4x2', 'QMatrix4x3', 'QMatrix4x4', 'QMdiArea', 'QMdiSubWindow', 'QMenu', 'QMenuBar', 'QMessageBox', 'QMouseEvent', 'QMouseEventTransition', 'QMoveEvent', 'QMovie', 'QNativeGestureEvent', 'QOffscreenSurface', 'QOpenGLBuffer', 'QOpenGLContext', 'QOpenGLContextGroup', 'QOpenGLDebugLogger', 'QOpenGLDebugMessage', 'QOpenGLExtraFunctions', 'QOpenGLFramebufferObject', 'QOpenGLFramebufferObjectFormat', 'QOpenGLFunctions', 'QOpenGLPixelTransferOptions', 'QOpenGLShader', 'QOpenGLShaderProgram', 'QOpenGLTexture', 'QOpenGLTextureBlitter', 'QOpenGLTimeMonitor', 'QOpenGLTimerQuery', 'QOpenGLVersionProfile', 'QOpenGLVertexArrayObject', 'QOpenGLWidget', 'QOpenGLWindow', 'QPageLayout', 'QPageSize', 'QPagedPaintDevice', 'QPaintDevice', 'QPaintDeviceWindow', 'QPaintEngine', 'QPaintEngineState', 'QPaintEvent', 'QPainter', 'QPainterPath', 'QPainterPathStroker', 'QPalette', 'QPanGesture', 'QPdfWriter', 'QPen', 'QPicture', 'QPictureIO', 'QPinchGesture', 'QPixelFormat', 'QPixmap', 'QPixmapCache', 'QPlainTextDocumentLayout', 'QPlainTextEdit', 'QPointingDeviceUniqueId', 'QPolygon', 'QPolygonF', 'QProgressBar', 'QProgressDialog', 'QProxyStyle', 'QPushButton', 'QPyTextObject', 'QQuaternion', 'QRadialGradient', 'QRadioButton', 'QRasterWindow', 'QRawFont', 'QRegExpValidator', 'QRegion', 'QResizeEvent', 'QRubberBand', 'QScreen', 'QScrollArea', 'QScrollBar', 'QScrollEvent', 'QScrollPrepareEvent', 'QScroller', 'QScrollerProperties', 'QSessionManager', 'QShortcut', 'QShortcutEvent', 'QShowEvent', 'QSizeGrip', 'QSizePolicy', 'QSlider', 'QSpacerItem', 'QSpinBox', 'QSplashScreen', 'QSplitter', 'QSplitterHandle', 'QStackedLayout', 'QStackedWidget', 'QStandardItem', 'QStandardItemModel', 'QStaticText', 'QStatusBar', 'QStatusTipEvent', 'QStyle', 'QStyleFactory', 'QStyleHintReturn', 'QStyleHintReturnMask', 'QStyleHintReturnVariant', 'QStyleHints', 'QStyleOption', 'QStyleOptionButton', 'QStyleOptionComboBox', 'QStyleOptionComplex', 'QStyleOptionDockWidget', 'QStyleOptionFocusRect', 'QStyleOptionFrame', 'QStyleOptionGraphicsItem', 'QStyleOptionGroupBox', 'QStyleOptionHeader', 'QStyleOptionMenuItem', 'QStyleOptionProgressBar', 'QStyleOptionRubberBand', 'QStyleOptionSizeGrip', 'QStyleOptionSlider', 'QStyleOptionSpinBox', 'QStyleOptionTab', 'QStyleOptionTabBarBase', 'QStyleOptionTabWidgetFrame', 'QStyleOptionTitleBar', 'QStyleOptionToolBar', 'QStyleOptionToolBox', 'QStyleOptionToolButton', 'QStyleOptionViewItem', 'QStylePainter', 'QStyledItemDelegate', 'QSurface', 'QSurfaceFormat', 'QSwipeGesture', 'QSyntaxHighlighter', 'QSystemTrayIcon', 'QTabBar', 'QTabWidget', 'QTableView', 'QTableWidget', 'QTableWidgetItem', 'QTableWidgetSelectionRange', 'QTabletEvent', 'QTapAndHoldGesture', 'QTapGesture', 'QTextBlock', 'QTextBlockFormat', 'QTextBlockGroup', 'QTextBlockUserData', 'QTextBrowser', 'QTextCharFormat', 'QTextCursor', 'QTextDocument', 'QTextDocumentFragment', 'QTextDocumentWriter', 'QTextEdit', 'QTextFormat', 'QTextFragment', 'QTextFrame', 'QTextFrameFormat', 'QTextImageFormat', 'QTextInlineObject', 'QTextItem', 'QTextLayout', 'QTextLength', 'QTextLine', 'QTextList', 'QTextListFormat', 'QTextObject', 'QTextObjectInterface', 'QTextOption', 'QTextTable', 'QTextTableCell', 'QTextTableCellFormat', 'QTextTableFormat', 'QTileRules', 'QTimeEdit', 'QToolBar', 'QToolBarChangeEvent', 'QToolBox', 'QToolButton', 'QToolTip', 'QTouchDevice', 'QTouchEvent', 'QTransform', 'QTreeView', 'QTreeWidget', 'QTreeWidgetItem', 'QTreeWidgetItemIterator', 'QUndoCommand', 'QUndoGroup', 'QUndoStack', 'QUndoView', 'QVBoxLayout', 'QValidator', 'QVector2D', 'QVector3D', 'QVector4D', 'QWhatsThis', 'QWhatsThisClickedEvent', 'QWheelEvent', 'QWidget', 'QWidgetAction', 'QWidgetItem', 'QWindow', 'QWindowStateChangeEvent', 'QWizard', 'QWizardPage', 'Qt', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'qAlpha', 'qApp', 'qBlue', 'qGray', 'qGreen', 'qIsGray', 'qRed', 'qRgb', 'qRgba']
Can someone help me please?
