module QWorkspace from PySide.QtGui
vito
Post by vito »
Hi.
Thanks again for the software and the forum in general. The answers are fast.
Today I was running a python script on a ubuntu machine (python 3.8) outside FreeCAD python console (that is, the ubuntu regular terminal) from this page https://wiki.freecadweb.org/Embedding_FreeCADGui
(the section called "Without even firing up the FreeCAD Gui")
I will show just the first lines
import os, sys, FreeCAD, FreeCADGui
from PyQt4 import QtCore, QtGui
from PyQt4.QtGui import QMainWindow, QWorkspace, QAction, QFileDialog, QApplication
from pivy.coin import SoInput, SoDB, sogui
Which I couldn't run without errors. I discovered that if I changed the PyQt4 for PySide like this
PYSIDEPATH='/usr/share/freecad/Ext'
FREECADPATH= '/usr/lib/freecad-python3/lib'
PIVYPATH='/usr/lib/python3/dist-packages/'
import sys
sys.path.append(FREECADPATH)
sys.path.append(PYSIDEPATH)
sys.path.append(PIVYPATH)
import os, FreeCAD, FreeCADGui
from PySide.QtGui import QMainWindow, QWorkspace, QAction, QFileDialog, QApplication
I could get almost with no errors: The terminal show me
ImportError: cannot import name 'QWorkspace' from 'PySide.QtGui' (/usr/share/freecad/Ext/PySide/QtGui.py)
I could check that all the other modules imported from PySide.QtGui DO exists, the only missing is 'QWorkspace'.
I imagine that maybe the name of the module was changed in an update (I'm using FreeCAD 0.19)
I check dir( PySide.QtGui) and got all this:
>>> dir(PySide.QtGui)
['QAbstractButton', 'QAbstractGraphicsShapeItem', 'QAbstractItemDelegate', 'QAbstractItemView', 'QAbstractOpenGLFunctions', 'QAbstractScrollArea', 'QAbstractSlider', 'QAbstractSpinBox', 'QAbstractTextDocumentLayout', 'QAccessible', 'QAccessibleEditableTextInterface', 'QAccessibleEvent', 'QAccessibleInterface', 'QAccessibleObject', 'QAccessibleStateChangeEvent', 'QAccessibleTableCellInterface', 'QAccessibleTableModelChangeEvent', 'QAccessibleTextCursorEvent', 'QAccessibleTextInsertEvent', 'QAccessibleTextInterface', 'QAccessibleTextRemoveEvent', 'QAccessibleTextSelectionEvent', 'QAccessibleTextUpdateEvent', 'QAccessibleValueChangeEvent', 'QAccessibleValueInterface', 'QAccessibleWidget', 'QAction', 'QActionEvent', 'QActionGroup', 'QApplication', 'QBackingStore', 'QBitmap', 'QBoxLayout', 'QBrush', 'QButtonGroup', 'QCalendarWidget', 'QCheckBox', 'QClipboard', 'QCloseEvent', 'QColor', 'QColorDialog', 'QColormap', 'QColumnView', 'QComboBox', 'QCommandLinkButton', 'QCommonStyle', 'QCompleter', 'QConicalGradient', 'QContextMenuEvent', 'QCursor', 'QDataWidgetMapper', 'QDateEdit', 'QDateTimeEdit', 'QDesktopServices', 'QDesktopWidget', 'QDial', 'QDialog', 'QDialogButtonBox', 'QDirModel', 'QDockWidget', 'QDoubleSpinBox', 'QDoubleValidator', 'QDrag', 'QDragEnterEvent', 'QDragLeaveEvent', 'QDragMoveEvent', 'QDropEvent', 'QEnterEvent', 'QErrorMessage', 'QExposeEvent', 'QFileDialog', 'QFileIconProvider', 'QFileOpenEvent', 'QFileSystemModel', 'QFocusEvent', 'QFocusFrame', 'QFont', 'QFontComboBox', 'QFontDatabase', 'QFontDialog', 'QFontInfo', 'QFontMetrics', 'QFontMetricsF', 'QFormLayout', 'QFrame', 'QGesture', 'QGestureEvent', 'QGestureRecognizer', 'QGradient', 'QGraphicsAnchor', 'QGraphicsAnchorLayout', 'QGraphicsBlurEffect', 'QGraphicsColorizeEffect', 'QGraphicsDropShadowEffect', 'QGraphicsEffect', 'QGraphicsEllipseItem', 'QGraphicsGridLayout', 'QGraphicsItem', 'QGraphicsItemAnimation', 'QGraphicsItemGroup', 'QGraphicsLayout', 'QGraphicsLayoutItem', 'QGraphicsLineItem', 'QGraphicsLinearLayout', 'QGraphicsObject', 'QGraphicsOpacityEffect', 'QGraphicsPathItem', 'QGraphicsPixmapItem', 'QGraphicsPolygonItem', 'QGraphicsProxyWidget', 'QGraphicsRectItem', 'QGraphicsRotation', 'QGraphicsScale', 'QGraphicsScene', 'QGraphicsSceneContextMenuEvent', 'QGraphicsSceneDragDropEvent', 'QGraphicsSceneEvent', 'QGraphicsSceneHelpEvent', 'QGraphicsSceneHoverEvent', 'QGraphicsSceneMouseEvent', 'QGraphicsSceneMoveEvent', 'QGraphicsSceneResizeEvent', 'QGraphicsSceneWheelEvent', 'QGraphicsSimpleTextItem', 'QGraphicsTextItem', 'QGraphicsTransform', 'QGraphicsView', 'QGraphicsWidget', 'QGridLayout', 'QGroupBox', 'QGuiApplication', 'QHBoxLayout', 'QHeaderView', 'QHelpEvent', 'QHideEvent', 'QHoverEvent', 'QIcon', 'QIconDragEvent', 'QIconEngine', 'QImage', 'QImageIOHandler', 'QImageReader', 'QImageWriter', 'QInputDialog', 'QInputEvent', 'QInputMethod', 'QInputMethodEvent', 'QInputMethodQueryEvent', 'QIntValidator', 'QItemDelegate', 'QItemEditorCreatorBase', 'QItemEditorFactory', 'QKeyEvent', 'QKeyEventTransition', 'QKeySequence', 'QKeySequenceEdit', 'QLCDNumber', 'QLabel', 'QLayout', 'QLayoutItem', 'QLineEdit', 'QLinearGradient', 'QListView', 'QListWidget', 'QListWidgetItem', 'QMainWindow', 'QMatrix', 'QMatrix2x2', 'QMatrix2x3', 'QMatrix2x4', 'QMatrix3x2', 'QMatrix3x3', 'QMatrix3x4', 'QMatrix4x2', 'QMatrix4x3', 'QMatrix4x4', 'QMdiArea', 'QMdiSubWindow', 'QMenu', 'QMenuBar', 'QMessageBox', 'QMouseEvent', 'QMouseEventTransition', 'QMoveEvent', 'QMovie', 'QNativeGestureEvent', 'QOffscreenSurface', 'QOpenGLBuffer', 'QOpenGLContext', 'QOpenGLContextGroup', 'QOpenGLDebugLogger', 'QOpenGLDebugMessage', 'QOpenGLExtraFunctions', 'QOpenGLFramebufferObject', 'QOpenGLFramebufferObjectFormat', 'QOpenGLFunctions', 'QOpenGLPixelTransferOptions', 'QOpenGLShader', 'QOpenGLShaderProgram', 'QOpenGLTexture', 'QOpenGLTextureBlitter', 'QOpenGLTimeMonitor', 'QOpenGLTimerQuery', 'QOpenGLVersionProfile', 'QOpenGLVertexArrayObject', 'QOpenGLWidget', 'QOpenGLWindow', 'QPageLayout', 'QPageSize', 'QPagedPaintDevice', 'QPaintDevice', 'QPaintDeviceWindow', 'QPaintEngine', 'QPaintEngineState', 'QPaintEvent', 'QPainter', 'QPainterPath', 'QPainterPathStroker', 'QPalette', 'QPanGesture', 'QPdfWriter', 'QPen', 'QPicture', 'QPictureIO', 'QPinchGesture', 'QPixelFormat', 'QPixmap', 'QPixmapCache', 'QPlainTextDocumentLayout', 'QPlainTextEdit', 'QPointingDeviceUniqueId', 'QPolygon', 'QPolygonF', 'QProgressBar', 'QProgressDialog', 'QProxyStyle', 'QPushButton', 'QPyTextObject', 'QQuaternion', 'QRadialGradient', 'QRadioButton', 'QRasterWindow', 'QRawFont', 'QRegExpValidator', 'QRegion', 'QResizeEvent', 'QRubberBand', 'QScreen', 'QScrollArea', 'QScrollBar', 'QScrollEvent', 'QScrollPrepareEvent', 'QScroller', 'QScrollerProperties', 'QSessionManager', 'QShortcut', 'QShortcutEvent', 'QShowEvent', 'QSizeGrip', 'QSizePolicy', 'QSlider', 'QSpacerItem', 'QSpinBox', 'QSplashScreen', 'QSplitter', 'QSplitterHandle', 'QStackedLayout', 'QStackedWidget', 'QStandardItem', 'QStandardItemModel', 'QStaticText', 'QStatusBar', 'QStatusTipEvent', 'QStyle', 'QStyleFactory', 'QStyleHintReturn', 'QStyleHintReturnMask', 'QStyleHintReturnVariant', 'QStyleHints', 'QStyleOption', 'QStyleOptionButton', 'QStyleOptionComboBox', 'QStyleOptionComplex', 'QStyleOptionDockWidget', 'QStyleOptionFocusRect', 'QStyleOptionFrame', 'QStyleOptionGraphicsItem', 'QStyleOptionGroupBox', 'QStyleOptionHeader', 'QStyleOptionMenuItem', 'QStyleOptionProgressBar', 'QStyleOptionRubberBand', 'QStyleOptionSizeGrip', 'QStyleOptionSlider', 'QStyleOptionSpinBox', 'QStyleOptionTab', 'QStyleOptionTabBarBase', 'QStyleOptionTabWidgetFrame', 'QStyleOptionTitleBar', 'QStyleOptionToolBar', 'QStyleOptionToolBox', 'QStyleOptionToolButton', 'QStyleOptionViewItem', 'QStylePainter', 'QStyledItemDelegate', 'QSurface', 'QSurfaceFormat', 'QSwipeGesture', 'QSyntaxHighlighter', 'QSystemTrayIcon', 'QTabBar', 'QTabWidget', 'QTableView', 'QTableWidget', 'QTableWidgetItem', 'QTableWidgetSelectionRange', 'QTabletEvent', 'QTapAndHoldGesture', 'QTapGesture', 'QTextBlock', 'QTextBlockFormat', 'QTextBlockGroup', 'QTextBlockUserData', 'QTextBrowser', 'QTextCharFormat', 'QTextCursor', 'QTextDocument', 'QTextDocumentFragment', 'QTextDocumentWriter', 'QTextEdit', 'QTextFormat', 'QTextFragment', 'QTextFrame', 'QTextFrameFormat', 'QTextImageFormat', 'QTextInlineObject', 'QTextItem', 'QTextLayout', 'QTextLength', 'QTextLine', 'QTextList', 'QTextListFormat', 'QTextObject', 'QTextObjectInterface', 'QTextOption', 'QTextTable', 'QTextTableCell', 'QTextTableCellFormat', 'QTextTableFormat', 'QTileRules', 'QTimeEdit', 'QToolBar', 'QToolBarChangeEvent', 'QToolBox', 'QToolButton', 'QToolTip', 'QTouchDevice', 'QTouchEvent', 'QTransform', 'QTreeView', 'QTreeWidget', 'QTreeWidgetItem', 'QTreeWidgetItemIterator', 'QUndoCommand', 'QUndoGroup', 'QUndoStack', 'QUndoView', 'QVBoxLayout', 'QValidator', 'QVector2D', 'QVector3D', 'QVector4D', 'QWhatsThis', 'QWhatsThisClickedEvent', 'QWheelEvent', 'QWidget', 'QWidgetAction', 'QWidgetItem', 'QWindow', 'QWindowStateChangeEvent', 'QWizard', 'QWizardPage', 'Qt', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'qAlpha', 'qApp', 'qBlue', 'qGray', 'qGreen', 'qIsGray', 'qRed', 'qRgb', 'qRgba']
Couldn't figure if any of those is the new version.
Can someone help me please?
Syres
Re: module QWorkspace from PySide.QtGui
Post by Syres »
vito
Post by vito »
Thanks for the fast answer.
I'm not sure if that is going to be the answer
The full code as appears here https://wiki.freecadweb.org/Embedding_FreeCADGui is this
import os
import sys
from PyQt4.QtGui import QMainWindow, QWorkspace, QAction, QApplication
from pivy.quarter import QuarterWidget
import FreeCADGui
class MdiQuarterWidget(QuarterWidget):
    def __init__(self, parent, sharewidget):
        QuarterWidget.__init__(self, parent=parent, sharewidget=sharewidget)
    def minimumSizeHint(self):
        return QtCore.QSize(640, 480)
class MdiMainWindow(QMainWindow):
    def __init__(self, qApp):
        QMainWindow.__init__(self)
        self._firstwidget = None
        self._workspace = QWorkspace()
        self.setCentralWidget(self._workspace)
        self.setAcceptDrops(True)
        self.setWindowTitle("Pivy Quarter MDI example")
        filemenu = self.menuBar().addMenu("&File")
        windowmenu = self.menuBar().addMenu("&Windows")
        fileopenaction = QAction("&Create Box", self)
        fileexitaction = QAction("E&xit", self)
        tileaction = QAction("Tile", self)
        cascadeaction = QAction("Cascade", self)
        filemenu.addAction(fileopenaction)
        filemenu.addAction(fileexitaction)
        windowmenu.addAction(tileaction)
        windowmenu.addAction(cascadeaction)
        self.connect(fileopenaction, QtCore.SIGNAL("triggered()"), self.createBoxInFreeCAD)
        self.connect(fileexitaction, QtCore.SIGNAL("triggered()"), QtGui.qApp.closeAllWindows)
        self.connect(tileaction, QtCore.SIGNAL("triggered()"), self._workspace.tile)
        self.connect(cascadeaction, QtCore.SIGNAL("triggered()"), self._workspace.cascade)
        windowmapper = QtCore.QSignalMapper(self)
        self.connect(windowmapper, QtCore.SIGNAL("mapped(QWidget *)"), self._workspace.setActiveWindow)
        self.dirname = os.curdir
    def closeEvent(self, event):
        self._workspace.closeAllWindows()
    def createBoxInFreeCAD(self):
        d=FreeCAD.newDocument()
        o=d.addObject("Part::Box")
        d.recompute()
        s=FreeCADGui.subgraphFromObject(o)
        child = self.createMdiChild()
        child.show()
        child.setSceneGraph(s)
    def createMdiChild(self):
        widget = MdiQuarterWidget(None, self._firstwidget)
        self._workspace.addWindow(widget)
        if not self._firstwidget:
            self._firstwidget = widget
        return widget
def main():
    app = QApplication(sys.argv)
    FreeCADGui.setupWithoutGUI()
    mdi = MdiMainWindow(app)
    mdi.show()
    sys.exit(app.exec_())
if __name__ == '__main__':
    main()
The problem appears at the line
when you try to assign to
All the imports I replace them for this
import sys
import os
import PySide
from PySide.QtGui import QMainWindow, QAction, QApplication
from PyQt5 import QtWidgets  #QtWidgets.QMdiArea() replaces QWorkspace
import FreeCADGui
And then replace to
self._workspace = QtWidgets.QMdiArea()
But I receive this error
TypeError: 'PySide2.QtWidgets.QMainWindow.setCentralWidget' called with wrong argument types:
PySide2.QtWidgets.QMainWindow.setCentralWidget(QMdiArea)
Supported signatures:
PySide2.QtWidgets.QMainWindow.setCentralWidget(PySide2.QtWidgets.QWidget)
I could check that the self._worspace expects a PySide2.QtWidgets.QWidget object
from this https://wiki.freecadweb.org/PySide it states that
The only unusual aspect is that the PySide2.QtWidgets classes are placed in the PySide.QtGui namespace.
so I replace
self._workspace = PySide.QtGui.QWidget()
But this error appears
File "pruebas_varias.py", line 90, in main
File "pruebas_varias.py", line 59, in __init__
AttributeError: 'PySide2.QtWidgets.QWidget' object has no attribute 'tile'
I'm still reviewing.
onekk
Post by onekk »
You are talking about Qt4 and you don't specify what version of FreeCAD you are using.
So every answer could be wrong, as far I remember Qt4 is almist old at least FreeCAD version 0.18 and 0.19, will use Qt5 as you could see clearly in the name of AppImages.
Maybe it will be interesting to have some information about your FreeCAD version.
Regards
Carlo D.
- Various other stuffs.
