[Solved] name 'FreeCADGui' is not defined in InitGui.py
phixxx5
Post by phixxx5 »
When starting FreeCAD my workbench fails to load and I get the error message:
During initialization the error name 'FreeCADGui' is not defined occurred in /home/philip/.FreeCAD/Mod/OSM-Buildings/InitGui.py
InitGui.py starts with the following:
import FreeCAD, FreeCADGui
Is something wrong with my python installation? I am on Ubuntu 20.04. I have Anaconda installed but I think FreeCAD uses the standard system python version not the conda environment.
TheMarkster
Re: name 'FreeCADGui' is not defined in InitGui.py
Post by TheMarkster »
Other addon workbenches in that folder work? Unknown? Install one and find out.
Here is how I start InitGui.py for DynamicData workbench:
import dynamicdatawb_locator
dynamicdataWBPath = os.path.dirname(dynamicdatawb_locator.__file__)
dynamicdataWB_icons_path = os.path.join(dynamicdataWBPath,'Resources','icons')
global main_dynamicdataWB_Icon
main_dynamicdataWB_Icon = os.path.join(dynamicdataWB_icons_path , 'DynamicDataLogo.svg')
There is an empty file named dynamicdatawb_locator.py in the same folder.
phixxx5
Post by phixxx5 »
I solved the problem by removing the import statements for FreeCAD and FreeCADGui
KAKM
Post by KAKM »
That's a problem I have periodically, and it's usually because I used
import FreeCADGui as Gui
which means that any place you would normally use FreeCADGui to access something, you need to use Gui instead. For example, instead of using
FreeCADGui.Selection.getSelection()
, you would use
It happens because you essentially rename the module as you import it so that accessing its methods can be done with shorter lines of code.
