Problem using uic to convert .ui file to .py file
falviani
Post by falviani »
I am working on a python workbench and and creating the user interface using the designer app found in my local version of FreeCAD. When I try to use uic to convert the .ui file to a .py file I get the following error:
C:\Users\frank\AppData\Roaming\FreeCAD\Mod\FC_TabbedBoxWorkbench\freecad\TabbedBoxWorkbench\resources\ui-files>uic -o ..\converted-ui-files\basicValues basicValues
File 'basicValues' is not valid
This is using the uic from the PyQt5 package installed in the Python 3.8 directory, and executed using Python 3.8.
However, designer opens the file just fine, and it has a valid length in the directory listing. Does anybody have info about what the error is and (more importantly) how to fix it?
Thanks in advance,
Frank
basicValues.ui
problem file
(1.84 KiB) Downloaded 39 times
onekk
Re: Problem using uic to convert .ui file to .py file
Post by onekk »
Not an expert, but if I remeber well in the past there were some discussion about similar questions, try to search for uic in the forum and mybe you will find some answers.
If not, sorry for bothering.
Regards
Carlo D.
- Various other stuffs.
