Is object instance of Body. 'PartDesign' is not defined.
koirat
Post by koirat »
This line:
print( isinstance(Gui.Selection.getSelection()[0],PartDesign.Body) )
I basically want to know if selected object is a body.
I will use it to select all visible bodies.
But this gives me:
NameError: name 'PartDesign' is not defined
Syres
Re: Is object instance of Body. 'PartDesign' is not defined.
Post by Syres »
Something like:
# -*- coding: utf-8 -*-
import FreeCAD
import FreeCADGui
try:
    s = FreeCADGui.Selection.getSelection()[0]
except:
    print('Nothing selected')
for selection in FreeCADGui.Selection.getSelectionEx():
    if str(type(selection.Object)) == "<class 'PartDesign.Body'>":
        print(selection.Object.Label)
    else:
        print('You must only select PartDesign Bodies')
        break
Tested using:
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.6.9
Qt version: 5.9.5
koirat
Post by koirat »
Thank you for your guidelines.
I have used this in the end:
obj.isDerivedFrom("PartDesign::Body")
