Determine object visibility.
koirat
Post by koirat »
Right now I'm using
obj.ViewObject.Visibility
To test If object is visible.
Problem is that this returns true even when the Part or the group that this body belongs to is invisible.
How can I determine the final Visibility ?
Syres
Re: Determine object visibility.
Post by Syres »
You need to study the following with particular attention to Is Parent:
# -*- coding: utf-8 -*-
# Togglevis is a macro created for FreeCAD .19 and is intended to toggle the visibility of selected/non selected objects to make it easer to edit when you have many objects in scene
# HOW TO USE: select the objects you want to keep visible (any vertex, edge, face will work) then run the macro.
# All non selected objects will be hidden.
# Run the macro again to restore previsous visibility state.
__title__    = "ToggleVis.py"
__author__   = "Paulo Rogerio de Oliveira"
__version__  = "1.0"
__date__     = "2021/03/31"    #YYY/MM/DD
__Comment__  = "hide unselected objects so you can edit then easily. restore prior visibility state running the macro again"
__Help__     = "Select objects you must keep visible and run the macro. Run it again to restore previsous visibility"
__Status__   = "stable"
__Requires__ = "freecad 0.19 (not tested in previous versions)"
import FreeCAD
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
doc = FreeCAD.ActiveDocument.Name
# clear output window
mw=Gui.getMainWindow()
#	c=mw.findChild(QtGui.QPlainTextEdit, "Python console")
#	c.clear()
#	r=mw.findChild(QtGui.QTextEdit, "Report view")
#	r.clear()
#initialize cache
if not hasattr(FreeCAD, "previouslyVisibleObjects"):
	FreeCAD.previouslyVisibleObjects=[]
if not hasattr(FreeCAD, "previouslyHiddenObjects"):
	FreeCAD.previouslyHiddenObjects=[]
# store all parents of all selected objects to ensure its keep visible (store the Label)
# for parentList and selectedList, store the QTreeWidgetItem reference. Try to avoid error if change label while in edit mode
parentList = []
selectedList = []
# try to get internal object associated with QTreeWidgetItem
def getInternalObject(treeItem):
	# first looks by Label
	obj = App.ActiveDocument.getObjectsByLabel(treeItem.data(0,0))
	if len(obj) > 0:
		return obj[0]
	else:
		# if not found, looks by Name
		return App.ActiveDocument.getObject(treeItem.data(0,0))
	pass
# for each object in treeview
def traverse(list, pad):
	# for each child
	for idx in range(list.childCount()):
		item = list.child(idx)
		name = item.data(0, 0)
		obj = getInternalObject(item)
		isParent = name in parentList
		isSelected = name in selectedList
		# hide any object that is visible and not parent of selected or selected itself - store it on list to restore state later
		if obj.Visibility == True and not isParent and not isSelected:
			obj.Visibility = False
			FreeCAD.previouslyVisibleObjects.append(item)
		# if not selected, not a group or if its parent of selected, traverse childs
		if not isSelected:
			if not hasattr(obj, "Group") or isParent:
				traverse	(item, pad + "  ")
# if there are objects in visibility cache, you are in edit mode
inEdit = len(FreeCAD.previouslyVisibleObjects) > 0
if inEdit:
	FreeCAD.Console.PrintLog('Leaving Edit Mode\n')
	# show all objects that where visible when entered edit mode
	for object in FreeCAD.previouslyVisibleObjects:
		obj = getInternalObject(object)
		try:
			obj.Visibility = True
		except:
			pass
	# hide all objects that where hidden when entered edit mode
	for object in FreeCAD.previouslyHiddenObjects:
		try:
		except:
			pass
	# reset visibility cache
	FreeCAD.previouslyVisibleObjects = []
	FreeCAD.previouslyHiddenObjects = []
	FreeCADGui.SendMsgToActiveView("ViewFit")
else:
	tab = mw.findChild(QtGui.QTabWidget, u'combiTab')
	tree = tab.widget(0).findChildren(QtGui.QTreeWidget)[0]
	top = tree.invisibleRootItem().child(0)
	# get selected objects
	sels = FreeCADGui.Selection.getSelection()
	if not sels:
		FreeCAD.Console.PrintWarning("Select something first!\n\n")
	else:
		for obj in sels:
			currentSelectedName = obj.Label
		FreeCAD.Console.PrintLog('Entering Edit Mode of '+doc+' - '+currentSelectedName+'\n')
		# import time
		# start_time = time.time()
		# find the treeitem for ActiveDocument
		for idx in range(top.childCount()):
			doc 	= top.child(idx)
			if doc.data(0,0) == App.ActiveDocument.Label:
				top = doc
		# store a list of selected items and its parents to keep it visible
		for sel in tree.selectedItems():
			current = sel
			selectedList.append(current.data(0,0))
			while current:
				obj = getInternalObject(current)
				if hasattr(obj, "Visibility") and obj.Visibility == False:
					FreeCAD.previouslyHiddenObjects.append(current)
				current = current.parent()
				if current:
					parentList.append(current.data(0,0))
		traverse(top, "")
		# print("--- %s seconds ---" % (time.time() - start_time))
freedman
Post by freedman »
In PartDesign, visibility is a combination of Body visibility and the Tip visibility. Is that the WB your targeting?
koirat
Post by koirat »
So we don't have just getParent() :( crazy !
koirat
Post by koirat »
freedman wrote: Mon Oct 18, 2021 3:25 pm In PartDesign, visibility is a combination of Body visibility and the Tip visibility. Is that the WB your targeting?
I just want to know if the object is visible by the user. (excluding camera position).
What is WB ?
freedman
Post by freedman »
Workbench....
freedman
Post by freedman »
Here is an older post that might help
https://forum.freecadweb.org/viewtopic. ... ct#p424782
koirat
Post by koirat »
I just want to make simple script that selects every visible body.
For now I have got this:
Gui.Selection.clearSelection()
for obj in FreeCAD.ActiveDocument.Objects:
	if obj.ViewObject.Visibility and  obj.isDerivedFrom("PartDesign::Body") :
		Gui.Selection.addSelection(obj)
And as for now I got two problems:
1. It selects objects that are set to be visible but are not visible because of ancestors visibility.
2. when the body is a clone it is selected in a list but on a screen body is not highlighted as selected.
TheMarkster
Post by TheMarkster »
body.VisibleFeature will return the visible feature or None if none are visible.
(untested)
visibleBodies = [body for body in FreeCAD.ActiveDocument.Objects if body.isDerivedFrom("PartDesign::Body") and body.VisibleFeature]
koirat
Post by koirat »
Thank you for all your help.
Here is the (I hope so) final solution.
It selects all truly visible bodies.
	if obj.ViewObject.Visibility and  obj.isDerivedFrom("PartDesign::Body") and obj.VisibleFeature :
