Determine object visibility.
Roy_043
Re: Determine object visibility.
Post by Roy_043 »
Unnested Body results in "TypeError: 'NoneType' object is not iterable".
TheMarkster
Post by TheMarkster »
Roy_043 wrote: Fri Oct 22, 2021 6:07 pm Unnested Body results in "TypeError: 'NoneType' object is not iterable".
Ah, so it returns None instead of an empty list [].
def getParents(obj):
    if hasattr(obj,"Parents") and obj.Parents:
        return [obj.Parents[0][0]]+[FreeCAD.ActiveDocument.getObject(p) for p in obj.Parents[0][1].split('.') if obj != FreeCAD.ActiveDocument.getObject(p) and p != '']
def isVisible(obj):
    if not obj.ViewObject.Visibility:
        return False
    if not obj.VisibleFeature:
        return False
    parents = getParents(obj)
    if not parents:
        return True
    for par in parents:
        if not par.ViewObject.Visibility:
            return False
    return True
bodies = [obj for obj in FreeCAD.ActiveDocument.Objects if obj.TypeId == "PartDesign::Body"]
FreeCADGui.Selection.clearSelection()
for body in bodies:
    if isVisible(body):
        FreeCADGui.Selection.addSelection(FreeCAD.ActiveDocument.Name,body.Name)
