Tree update issue?: tree.selectedItems()
Roy_043
Post by Roy_043 »
I am trying to select the children of a Draft Layer in the tree.
Std_TreeSyncSelection is switched off.
If I test the code by pasting each line in the Python console everything works fine. But running the whole code results in an error:
File "C:/Downloads/test2.py", line 23, in <module>
item = tree.selectedItems()[0]
<class 'IndexError'>: list index out of range
It is this code sequence that causes the problem:
Gui.Selection.addSelection(grp) # Need to update the tree after this? But how?
Gui.Selection.clearSelection()
Test file attached.
The whole code:
# https://wiki.freecadweb.org/Macro_ExpandTreeItem
from PySide import QtGui
def expandParents(tree, item):
    parent = item.parent()
    if parent:
        tree.expandItem(parent)
        expandParents(tree, parent)
doc = App.ActiveDocument
mw = Gui.getMainWindow()
trees = mw.findChildren(QtGui.QTreeWidget)
tree = trees[0]
obj = App.ActiveDocument.Line003
grp = obj.InList[0]
tree.expandItem(item)
for i in range(item.childCount()):
    name = item.child(i).setSelected(True)
groups_and_layers.FCStd
(17.33 KiB) Downloaded 24 times
TheMarkster
Re: Tree update issue?: tree.selectedItems()
Post by TheMarkster »
After add to the selection:
Gui.updateGui()
Roy_043
Post by Roy_043 »
I already tried that. It has no effect.
