Run an in-memory macro as if run by MacroManager
TheMarkster
Re: Run an in-memory macro as if run by MacroManager
Post by TheMarkster »
Does it also fail on linux and mac? It fails for me on 0.19 and 0.20 in windows, but not with an older version (0.18 py2/qt4 build) and not on 0.20 running inside a virtual machine (ubuntu guest running on a windows 10 host). Does the application itself have a certificate that needs to be updated?
heda
Post by heda »
chennes wrote: Tue Oct 26, 2021 1:45 am the code that gets pulled off the wiki via a crazy html-parsing routine.
have formed a vague idea around that (not put into action),
for whatever reason that html generator is clipping the "source code" in the template, that could be worked around by not looking at the html page of the wiki, but rather go to an address like https://wiki.freecadweb.org/index.php?t ... emplates=1 which opens up for getting the full version of the macro from the wiki regardless if it is capped or not in the html. would probably simplify parsing as well - have not looked at it, but suppose it is regexp which if in python is slow...
TheMarkster wrote: Tue Oct 26, 2021 3:53 pm Does it also fail on linux and mac?
I admit that I didn't follow this topic. What exactly can/should I test?
TheMarkster
chrisb wrote: Tue Oct 26, 2021 7:19 pm
Addon manager fails to get the list of macros from the wiki. It gets the git repo macros, but not the wiki. It works in my ubuntu virtual machine (ubuntu guest / windows host) and in windows if I use 0.18 py2/qt4 build.
TheMarkster wrote: Tue Oct 26, 2021 8:01 pm It gets the git repo macros, but not the wiki.
Works here, but I have GitPython installed.
OS: macOS 10.16
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
TheMarkster
Perhaps the lack of git python is part of the issue with windows versions. Yet if I enter into the python console:
from git import Repo
it works without a hitch.
But I think it might be fixed anyway. I applied the patch to my local files, so I don't know if fixing the ssl certificate solved it or not. There is mention of this in the developer board.
chennes
Post by chennes »
The Git Python thing is separate from the Wiki thing -- the macros on the wiki are only fetched from the wiki, over https. The Git Python difference is whether we can use git clone to download a repo, or if we have to download the zip file instead.
Chris Hennes
Pioneer Library System
thomas-neemann
Post by thomas-neemann »
TheMarkster wrote: Mon Oct 25, 2021 5:06 am ...
Sorry if my question doesn't quite fit here, but I've been looking for a way to integrate "return" into a freecad macro for hours. here is the thread:
https://forum.freecadweb.org/viewtopic.php?f=22&t=72820
you write:
you can do that in this line
Gui.runCommand('Std_Copy',0)
use?
