get continuous edges respect to relative angle from group of edges
ebrahim raeyat
Post by ebrahim raeyat »
Hi. first, I don't know if it is a related topic.
I have a series of edges that meet each other on some point or not. I want to extract a series of continuous edges from this edges with one rule:
if angle between two edges is between for example 180 - 45 and 180. the 45 degree maybe vary from 0 to 45. for example in this shape:
I wrote a algorithm for this. It creates a table for each node and each edge that connect to it, the other edges of node that connect with this node with respect the angle between this edges and other edges.
I want to know is there a simple solution for this? thanks.
this is my functions, it needs pandas library.
def get_similar_edge_direction_in_common_points_from_edges(edges : list) -> 'pd.DataFram':
	This function give a list of edges, find the common points of those edges.
	then for each point and each edge of all edges that connected to this point,
	it search for similarity direction with this edge. the df columns output is
	like "point edge 1 2 3 4"
	import pandas as pd
	cols = ['edge', 'is_first', 'is_end', 'x', 'y', 'z']
	df = pd.DataFrame()
	for e in edges:
		v1, v2 = e.firstVertex(), e.lastVertex()
		se = pd.Series([e, True, False, v1.X, v1.Y, v1.Z], index=cols)
		df = df.append(se, ignore_index=True)
		se = pd.Series([e, False, True, v2.X, v2.Y, v2.Z], index=cols)
	group = df.groupby(['x','y', 'z'])
	max_number_edges_connect_to_point = group['edge'].count().max()
	additional_cols = [n for n in range(1, max_number_edges_connect_to_point)]
	df1 = pd.DataFrame(columns=['point', 'edge'] + additional_cols)
	for state, frame in group:
		edges_from_point = list(frame['edge'])
		for edge in edges_from_point:
			edges_without_curr_edge = set(edges_from_point).difference([edge])
			preferable_edges = get_in_direction_priority(edge, edges_without_curr_edge)
			none_exist_edge_len = max_number_edges_connect_to_point -  len(preferable_edges) - 1
			preferable_edges += none_exist_edge_len * [None]
			se = pd.Series([state, edge] +  preferable_edges, index=df1.columns)
			df1 = df1.append(se, ignore_index=True)
	map_dict_edges_to_num = dict()
	for i, e in enumerate(edges, start=1):
		map_dict_edges_to_num[e] = i
	edges_cols = ['edge'] + additional_cols
	for col in (edges_cols):
		df1[col] = df1[col].map(map_dict_edges_to_num)
	df1 = df1.fillna(0)
		df1[col] = df1[col].astype(int)
	return df1
def get_continuous_edges(edges : list):
	This function get a list of egdes and search for groups of egdes that create continuous edges in x or y direction
	df = get_similar_edge_direction_in_common_points_from_edges(edges)
	all_edges = []
	end = False
	used_edges = []
	continues_edges = []
	edges_cols = list(df.columns)[1:]
	additional_cols = edges_cols[1:]
	for i, row in df.iterrows():
		if end:
			all_edges.append(continues_edges)
			end = False
			df['edge'] = df['edge'].replace([previous_edge], 0)
			if df[edges_cols].sum().sum() == 0:
				break
		while not end:
			if len(continues_edges) == 0:
				filt = (df['edge'] == 0) | (df[edges_cols].sum(axis=1) == 0)
				temp_df = df[~filt]
				if len(temp_df) == 0:
					end = True
					break
				j, temp_row = next(temp_df.iterrows())
				edge_num = temp_row['edge']
				point = row['point']
				if not edge_num in used_edges:
					continues_edges.append(edge_num)
					used_edges.append(edge_num)
				for col in edges_cols:
					df.at[j, col] = 0
				df[additional_cols] = df[additional_cols].replace([edge_num], 0)
			else:
				previous_edge = continues_edges[-1]
				filt = (df['edge'] == previous_edge) & (df['point'] != point)
				if not True in filt.values:
					end = True
					break
				temp_df = df.loc[filt]
				row_num = temp_df.index.to_list()[0]
				end = True
				for col in additional_cols:
					edge_num = temp_df.at[row_num, col]
					if edge_num != 0 and not edge_num in used_edges:
						end = False
						point = df.at[row_num, 'point']
						break
	return all_edges
def get_in_direction_priority(edge, edges,
		angle: int = 45):
	Getting an edge and calculate angle between edge and each member of edges and then
	sort them from large to small. angle is acceptable angle that ilustrate edge is in direction
	of other edges
	acceptable_anlge = 180 - angle
	if len(edges) == 0:
		return []
	edges_angles = []
	for e in edges:
		angle = angle_between_two_edges(edge, e)
		if angle == 0:
			angle = 180
		if angle < acceptable_anlge:
			continue
		edges_angles.append((e, angle))
	edges_angles.sort(key=lambda x: x[1], reverse=True)
	return [a[0] for a in edges_angles]
def dot(vector_a, vector_b):
	return vector_a[0]*vector_b[0]+vector_a[1]*vector_b[1]
def angle_between_two_edges(
	edge1 : Part.Edge,
	edge2 : Part.Edge,
	# v1 = edge1.tangentAt(0)
	# dx1, dy1 = v1.x, v1.y
	# v2 = edge2.tangentAt(0)
	# dx2, dy2 = v2.x, v2.y
	# if abs(dx1) == abs(dx2): # if two edges are in the same direction, also if dx = 0
	# 	return 180
	p1, p2 = [v.Point for v in edge1.Vertexes]
	p3, p4 = [v.Point for v in edge2.Vertexes]
	p1, p2, p3, p4 = find_common_point(p1, p2, p3, p4)
	x1, x2, y1, y2 = p1.x, p2.x, p1.y, p2.y
	x3, x4, y3, y4 = p3.x, p4.x, p3.y, p4.y
	vector_a = [(x1 - x2), (y1 - y2)]
	vector_b = [(x3 - x4), (y3 - y4)]
	dot_prod = dot(vector_a, vector_b)
	magnitudes_a = dot(vector_a, vector_a) ** 0.5
	magnitudes_b = dot(vector_b, vector_b) ** 0.5
	angle = math.acos(dot_prod / magnitudes_b / magnitudes_a)
	ang_deg = math.degrees(angle)%360
	if ang_deg-180>=0:
		return 360 - ang_deg
	else:
		return ang_deg
def find_common_point(p1, p2, p3, p4):
	if p1.isEqual(p3, .001):
		return p1, p2, p1, p4
	elif p1.isEqual(p4, .001):
		return p1, p2, p1, p3
	elif p2.isEqual(p3, .001):
		return p2, p1, p2, p4
	elif p2.isEqual(p4, .001):
		return p2, p1, p2, p3
sliptonic
Re: get continuous edges respect to relative angle from group of edges
Post by sliptonic »
Not really a Path/CAM topic. Moving to Python Scripting and Macros
ebrahim raeyat
sliptonic wrote: Sun Nov 14, 2021 3:56 pm Not really a Path/CAM topic. Moving to Python Scripting and Macros
Thanks, I completed the code. user can choose acceptable angle between edges to be continuous:
this is 45 degree angle:
and 20 degree:
if user reduce the acceptable angle, more continuous edges creates.
