Which Python command to use to extract the location of a point
FlyingaHull
Post by FlyingaHull »
I have a project that studies the motion of a parametrized 4-bar linkage, animated with a Python script (I'm new at Python programming). I would like to have the script publish the motion of certain points into a file that I can eventually load into EXCEL. My question is what Python command can be used to extract the x-y-z location of any point in my model into a variable.
Thanks in advance
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
onekk
Re: Which Python command to use to extract the location of a point
Post by onekk »
It is not clear, from what data you have to start.
There is no such command, from what I know you would have to:
- scan the document for objects
- for each objects you have to extract the infos and put into some external file.
or you have to select objects and work on selections.
Without some example data it is hard to guess how much work has to be done, it depends also on the complexity of the input data.
But also how much experience in Python programming you have, and how much time you want to spend on learning FreeCAD "internals".
As I'm used to script in Python, it is not an impossible work, but it is not also a small work, if the "macro" has to be "generalized" you have to spend some time on filtering data.
Regards
Carlo D.
- Various other stuffs.
FlyingaHull
Thank you Carlos for your reply -
I probably wasn't clear enough with my question.
The animation of the linkage is being conducted by a Python script utilizing QtCore.QTimer.
For each increment of the animation, I wish to capture and record (via the script) the x-y-z position of various points in the linkage.
I note in the Python console the commands that are created for each action in the Sketcher.
However, I've not found in Sketcher a function that reports out the position of points - but that could just be because I'm not versed enough with all the FreeCad capabilities.
So my question is whether there would be a similar command that simply reports out the location of a selected point in my model.
Or perhaps there's some sort of a 'model report' that lists out every aspect of the model, which I can later go in and extract out the coordinate information that I'm looking for.
Otherwise, if it's more complicated than a relatively simple command and as you mention would involve having to go deep into the 'internals', I'll just skip the idea.
Regards & Thanks again, Richard
heda
Post by heda »
of course you can extract the coordinates of points/vertexes, or anything else you have on the screen.
in order to get specific help - you have to be specific enough on what you have to begin with (like a file, or at least mention what is in your model).
suppose you are after the global coordinates, and depending on what you have you likely need to care for that in the code.
if you managed to make an animation, this thread https://forum.freecadweb.org/viewtopic.php?f=22&t=25821 should be enough to get you going.
good luck, I'm sure you will make it!
FlyingaHull
Thank you heda -
I think I should be able to get what I need from this reference, which extracts the needed coordinates that are an attribute of lines attached to the point, and is a good workaround vs getting the point coordinates directly.
Regards, Richard
onekk
Post by onekk »
If the animation is driven by a script, i think that it would be possible to modify the script to record and output positions.
As you have been told, point and positions could be different, as there are many point and poistions.
Simply FreeCAD has two "engines":
a modelling engine (model coordinates)
a visualization engine (visualization window coordinates)
so there are many ways to obtain things, based also on what you want to record.
Such questions should be done with some example files and maybe with some code to ease the work of the good fellow that maybe could help you.
In some other forum requests without a MWE (Minimal Working Example) and/or a test file, simply remain unanswered or get a simple "Please post a MWE and test_code" (how much politely depends on the moderator) :D.
Regards
Carlo D.
FlyingaHull
Thanks again Carlos for your response.
Per your suggestion, I went ahead and created and attached a very simple model (MWE) of a rotating point (driven by a Python Macro) to help illustrate my question.
My desire is to identify the necessary Python commands that query the location of the point, and ultimately write them to a file.
'heda' pointed me to some links where the user (script) outputs the motion of the end-points of a vector, which seems like a good enough workaround, but any simpler approach would very much welcome.
Regards,
Richard
rotate.FCMacro
Macro used to rotate point with placeholder for potential code that could be used to extract displacements
(377 Bytes) Downloaded 25 times
MWE_for_question_on_how_to_output_displacments.FCStd
MWE file of rotating point
(4.81 KiB) Downloaded 27 times
onekk
Post by onekk »
Some code refactoring to make more readable:
from PySide import QtCore
irot = 0
DOC = FreeCAD.getDocument('MWE_for_question_on_how_to_output_displacments')
def update():
    global irot, cycles
    sketch = DOC.getObjectsByLabel('Sketch')
    # it returns a list as multiple names could match
    sketch[0].setDatum(2, App.Units.Quantity(str(irot) + ' deg'))
    point = sketch[0].Geometry[0].EndPoint
    FreeCAD.Console.PrintMessage("{} > {} \n".format(irot, point))
    DOC.recompute()
    irot += 1.0
    if irot >360:
        irot = irot -360
for idx in range(100):
    update()
Please note that:
Geometry[0]
is a cheat, as it takes the first element of the list Geometry of the Sketch.
and I've modified some code to make the routine to not clutter FreeCAD, if not the macro will run forever, maybe to use some other different from Qtimer used in that way.
Hope it helps.
Regards
Carlo D.
mario52
Post by mario52 »
Hi
other idea for create one animation Macro_Rotate_To_Point Image (in 3D view not in the sketcher)
but you must rotate, translate step by step and save the coordinate if needed after save the final work in one macro with different options
mario
FlyingaHull
Thanks again Carlo,
Using the commands in your script, I was able to report out the coordinates as they changed during the animation.
Best regards,
Richard
