Which Python command to use to extract the location of a point
paullee
Re: Which Python command to use to extract the location of a point
Post by paullee »
FlyingaHull wrote: Tue Nov 23, 2021 2:27 pm I have a project that studies the motion of a parametrized 4-bar linkage, animated with a Python script (I'm new at Python programming). I would like to have the script publish the motion of certain points into a file that I can eventually load into EXCEL. My question is what Python command can be used to extract the x-y-z location of any point in my model into a variable.
Kind of 4-bar hinge e.g. for windows?
Can share e.g. in Arch/BIM sub-forum after you make it ? :)
Thanks !
FlyingaHull
Post by FlyingaHull »
To Paullee:
I had 'mispoken' in describing my project as "4-bar" when it is actually just a "3-bar" mechanism, which isn't terribly sophisticated, and I suspect wouldn't be much use for you. The project is a study of the motion of a wing flap driven by a servo, where I wanted to make sure that the device had the appropriate range of movement that I was looking for. FreeCAD helped me with visualization of the motion, as well as allowing for parametric adjustments. This link https://youtu.be/CUgOfjrcX-k was very helpful in showing me how to set up the animation via a Python script. Then finally, through the help of those on this forum, I was able to extract actual motion was useful to record the results.
Regards,
Richard
Screenshot 2021-11-30 093008.png (101.41 KiB) Viewed 679 times
mario52
Post by mario52 »
Hi
Macro_crank_simul (in sketcher)
mario
