Using QRunnable in python script causes crash
maxwang531
Post by maxwang531 »
I currently use FreeCAD to create a CNC path for my model. The path content is composed of a Profile and a Pocket processing. Since I need to call the CAM simulator to generate a processed model file, I also call FreeCAD's internal simulator.
Since each simulation needs to be completed, I used the QRunnable function to let the simulation be carried out in it and export the simulation results. But the FreeCAD program will crash every time at the end of the script.
Below is part of my code.
FREECADPATH = "D:\\FreeCAD\\bin"
SIMULATORPATH="D:\\FreeCAD\\lib"
BINVOXPATH="E:\\111Masterarbeit\\Github\\Ausarbeitung\\utils"
import os
import sys
sys.path.append(FREECADPATH)
sys.path.append(SIMULATORPATH)
sys.path.append(BINVOXPATH)
import math
import numpy as np
import csv
import pandas as pd
#import PathSimulator
import FreeCAD as App
import FreeCADGui as Gui
from FreeCAD import Base, Rotation, Vector
import Part
import Path
import Draft
from math import pi, sin, cos
from PathScripts import PathJob
from PathScripts import PathJobGui
from PathScripts import PathProfile
from PathScripts import PathAdaptive
from PathScripts import PathPocket
import PathScripts.PathDressupDogbone as PathDressupDogbone
import PathScripts.PathDressupHoldingTags as PathDressupHoldingTags
from PathScripts import PathGeom
from PathScripts import PathPostProcessor
from PathScripts import PathUtil
DOC=FreeCAD.openDocument('E:/111Masterarbeit/Github/Ausarbeitung/Model mit binvox/Rechteckpocket2.FCStd')
DOC.recompute()
DOC = FreeCAD.activeDocument()
DOC.recompute()
Part1 = DOC.getObject('Part__Feature')
result = pd.read_csv('E:/111Masterarbeit/Github/Ausarbeitung/CSV/Pocket-Result.csv')
x=result.shape[1]
y=result.shape[0]
print(result.iloc[0][1])
print(int(result.iloc[0][2]))
if int(result.iloc[0][1]) == 10:
    facName = 'Face{:d}'.format(int(result.iloc[0][2]))
print(facName)
Gui.activateWorkbench("PathWorkbench")
job = PathJob.Create('Job', [Part1], None)
job.ViewObject.Proxy = PathJobGui.ViewProvider(job.ViewObject)
#Profile Creat
profile = PathProfile.Create('Profile')
profile.setExpression('StepDown', None)
profile.StepDown = 10
profile.processHoles = True
profile.processPerimeter = True
profile.recompute()
DOC.recompute()
#Pocket
pocket = PathPocket.Create('Pocket')
pocket.Base = (Part1 , facName)
pocket.setExpression('StepDown', None)
pocket.StepDown = 5
pocket.recompute()
DOC.recompute()
#Simulation
from PathScripts import PathSimulatorGui as a
from time import sleep
from PyQt5.QtCore import (QCoreApplication, QObject, QRunnable, QThread,QThreadPool, pyqtSignal)
class Runnable(QRunnable):
    def run(self):
        count = 0
        app = QCoreApplication.instance()
        while a.pathSimulation.iprogress < a.pathSimulation.numCommands :
            sleep(1)
        print("Tasks are finished")
        a.pathSimulation.accept()
        #app.quit()
        DOC.recompute()
        FreeCADGui.Control.closeDialog()
        # export
        Gui.Selection.addSelection('Rechteckpocket2', 'CutMaterial')
        __objs__ = []
        __objs__.append(FreeCAD.getDocument("Rechteckpocket2").getObject("CutMaterial"))
        import Mesh
        Mesh.export(__objs__, u"E:/111Masterarbeit/Github/Ausarbeitung/ModelCutmaterial/Rechteckpocket-CutMaterial.stl")
        print("export finished")
        del __objs__
        DOC.recompute()
        DOC.removeObject('CutMaterial')
        DOC.recompute()
Gui.runCommand('Path_Simulator',0)
a.pathSimulation.SetupSimulation()   #Simulation Reset
a.pathSimulation.SimFF()
runnable = Runnable()
QThreadPool.globalInstance().start(runnable)
Is there any solution to this? Is this a conflict between the QRunnable function and FreeCAD's internal program?
My FreeCAD version information is as follows.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Founder
Re: Using QRunnable in python script causes crash
Post by wmayer »
The problem is that Qt's GUI is not thread-safe. This means from within a thread you are not allowed to directly manipulate the GUI.
Now QRunnable is managed by the thread pool and each instance is executed in its own thread. So, if you work with QThread or QRunnable doesn't make a big difference at the end.
The following function calls in the run() method are not allowed:
[/code]
DOC.recompute()
[/code]
One way to (indirectly) modify the GUI from within a thread is to post events or with signals/slots where the connection type between sender and receiver is "queued". In this case the actual functions are executed in the GUI thread.
maxwang531
wmayer wrote: Sat Nov 27, 2021 2:14 pm The problem is that Qt's GUI is not thread-safe. This means from within a thread you are not allowed to directly manipulate the GUI.
[/code]
DOC.recompute()
[/code]
Thank you for pointing out the key to the problem. After receiving your answer, I carefully studied the operation of the Qt framework, but unfortunately there is no progress.
If I want to use the path simulator through scripts, the worker threads must be used. In fact, I have tried putting instructions with GUI in the main thread, FreeCAD will go directly into the unresponsive state. The code is shown below.
Gui.runCommand('Path_Simulator', 0)
a.pathSimulation.SetupSimulation()  # Simulation Reset
while a.pathSimulation.iprogress < a.pathSimulation.numCommands:
    sleep(1)
DOC.recompute()
At present, I try to use signals and slots to complete the call of the path simulator. I try to write a QObject and put the operations that I need to perform in it. I am not sure whether GUI commands can be used in it.
class Worker(QObject):
    finished = pyqtSignal()
    progress = pyqtSignal()
    def run(self):
        count = 0
            sleep(1)
            self.progress.emit()
        # app.quit
        DOC.recompute()
        # export
        __objs__ = []
        import Mesh
                    u"E:/111Masterarbeit/Github/Ausarbeitung/ModelCutmaterial/Rechteckpocket1-CutMaterial.stl")
        del __objs__
        DOC.recompute()
        self.finished.emit()
I am still a beginner with the Qt framework. If possible, can you help to write a simple example for calling the path simulator? Or are there other ways to call the path simulator in the script?
Founder
Post by wmayer »
Sorry but I don't know much about the Path code and can't really tell what can be used in a thread. It's best that you ask one of its maintainers.
TheMarkster
Post by TheMarkster »
Try adding a call to FreeCADGui.updateGui() inside your loop. This will keep the Gui from becoming unresponsive in many cases.
maxwang531
TheMarkster wrote: Sat Nov 27, 2021 10:24 pm Try adding a call to FreeCADGui.updateGui() inside your loop. This will keep the Gui from becoming unresponsive in many cases.
Thank you for this solution. After experimenting, the code that I previously ran in the sub-thread can indeed be run in the main thread, and the GUI will not appear unresponsive. This is really amazing.
    sleep(0.05)
DOC.recompute()
ebrahim raeyat
Post by ebrahim raeyat »
I also have a problem with using QRunnable:
I have a dialog and want when user accept (click ok), does 2 time consuming tasks, when I use simple task, it works, but with my real task, it did not work, minimal code that working:
from PySide2.QtCore import QRunnable, QThreadPool
    def __init__(self, fn, *args, **kwargs):
        super().__init__()
        self.fn = fn
        self.args = args
        self.kwargs = kwargs
    def run(self):
        self.fn(*self.args, **self.kwargs)
class EtabsTaskPanel:
    def __init__(self):
        self.form = Gui.PySideUic.loadUi(PATH_TO_UI_FILE)
    def accept(self):
        pool = QThreadPool.globalInstance()
        runnable = Runnable(self.time_consuming_func)
        pool.start(runnable)
    def time_consuming_func(self):
        import time
        for i in range(20):
            print(i)
            time.sleep(1)
        print('finished')
output:
16:36:22  0
16:36:23  1
16:36:24  2
16:36:25  3
16:36:26  4
16:36:27  5
16:36:28  6
16:36:29  7
16:36:30  8
16:36:31  9
16:36:32  10
16:36:33  11
16:36:34  12
16:36:35  13
16:36:36  14
16:36:37  15
16:36:38  16
16:36:39  17
16:36:40  18
16:36:41  19
16:36:42  finished
I set it to 20 seconds, because my real task, take some seconds to freezes the FreeCAD.
but when it come to my real task, it crashes, the difference is in time consuming function, when i import my module, it freezes. my program works without threading:
    	from safe.punch import etabs_punch
    	print('finished')
FreeCAD freezes at this point. as I said my import without threading works.
I also implemented yorik's statuswidget, it works in my civiltools WB the way that yorik use, but when I want to apply this method in my dialog, FreeCAD show a tiny windows with FreeCAD icon and then freezes.
https://github.com/yorikvanhavre/BIM_Wo ... ar.py#L122
https://github.com/ebrahimraeyat/civilT ... Bar.py#L40
