Store edges or faces as properties for scripted objects.
TheMarkster
Re: Store edges or faces as properties for scripted objects.
Post by TheMarkster »
josegegas wrote: Fri Dec 03, 2021 1:01 am
Then, the user selects two edges or faces belonging to the same object, and I do:
fp.reference_1 = (FreeCADGui.Selection.getSelection()[0],FreeCADGui.Selection.getSelectionEx()[0].SubElementNames[0])
fp.reference_2 = (FreeCADGui.Selection.getSelection()[0],FreeCADGui.Selection.getSelectionEx()[0].SubElementNames[1])
This works well so far, but now I want to recover the center of mass of reference_1 and of reference_2 (which can be edges or faces), and I'm not sure how to do so. Any ideas?
What means "recover"? To get the center of mass, just enter:
face.CenterOfMass
edge.CenterOfMass
josegegas
Post by josegegas »
TheMarkster wrote: Fri Dec 03, 2021 5:54 pm
face.CenterOfMass
edge.CenterOfMass
The object has reference_1 and reference_2. How can I get the center of mass out of these? Of course I cannot simply do
reference_1.CenterIfMass
I need to do something to get the edges or faces out of reference_1 and reference_2...
By doing:
 fp.reference_1[0]
I get:
<Part::PartFeature>
Which is the whole shape selected by the user (FreeCADGui.Selection.getSelection()[0]).
And:
 fp.reference_1[1]
returns:
['Edge10']
Where "Edge10" is a string. So the question is, how can I get the edge named 'Edge10' out of <Part::PartFeature>? I´ve been looking for some method like Part.GetEdgesByName() or similar, but no luck so far...
Chris_G
Post by Chris_G »
theShape = fp.reference_1[0].Shape
firstEdge = theShape.getElement(fp.reference_1[1][0])
onekk
Post by onekk »
Probably, the OP, whant to make something like.
  1. Store an object shape () in his case only some edges that e want to modify
  2. operate on the shape, modifying it as needed
  3. have the ability to "recover" the original shape
  4. apply new modification to the old shape
Or similar thing, like storing some "position" on the original shape and apply modification to the same positions, when as example a dims is changes.
He was speaking of joints, I have in mind some like you want to model say a rod and apply some modification to an edge, but if the rod is changed (maybe modify only the length or the diameter), store edges and apply modification to "same" edges of the new object.
In this case, the problem is to determine a proper position as edge number could change.
For this a simple object in my opinion is not sufficient.
You have to script a whole new object class that could build and object and store "joints position" in a manner that it could survive some shape modifications, in other word, even if it is a simple "tube" you have to store "building parameters" and "joints positions" and rebuild the whole object if something is changed.
This is derived from the analysis of the code he posted:
class Revolutepin:
    def __init__(self, obj, label, node, reference1, reference2):
He is storing reference1 and reference2 as a way to retrieve the "joint positions" based on "edge number" on the original shape.
maybe using some mean to store a relative position in respect of the center of mass, wil make something useful, but the shapes should be simple shapes, where some reference like "N", "NE" or similar could have sense.
if you think of doing some joints to a rod that is a cylinder, and then modify the rod shape to a "hexagonal rod" you could have some idea, the edge count is very different, but some "N", "S", "E", "W" positions could have a logical mean.
Different thing would be if you want to generalize things, and use maybe a figure similar to the image posted, where maybe if this something that resemble a "modified cube" with six faces, maybe slanted it could have even a sense, but if you modify a face to have say a protrusion, edge count and position is not helping a lot.
So a sort of abstraction or categories of shapes has to be done to have a mean to have a "predictable joint position" when altering "base shape", simply storing edge reference will not be enough.
Hoping have not guessed things wrong.
Regards
Carlo D.
- Various other stuffs.
TheMarkster
(untested)
obj = reference_1[0]
elements = reference_1[1]
edges = [obj.getSubObject(element) for element in elements if "Edge" in element]
faces =  [obj.getSubObject(element) for element in elements if "Face" in element]
josegegas
Post by josegegas »
thanks a lot for the responses!
I now understand how to use App::PropertyLinkSubList, and I have already modified a couple of my joint classes to make them fully parametric, and it works like a charm!
phpBB [video]
paullee
Post by paullee »
Looks Great !
