Face Placement cannot be changed
pate
Post by pate »
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Finnish/Finland (fi_FI)
I am a new python user. It's very interesting. I've only been testing it for one month. I have been practicing and using Freecad for a few years. I mainly use a 2D cad and manage my client’s Aras PDM system.
I have been able to create a wide variety of components with python code. Now I have run into an unresolved problem. I copied the Python code from the python console and modified it to fit. The code creates a new file, a template, retrieves the cross section of the dxf file and creates a face from it.
The face should then be turned to the correct position and extruded. This will be a problem. The code doesn't go right at once, but if I export lines 1-60 and then lines 61-100 to the python console, it works.
What am I doing wrong?
PS. My client has hundreds or thousands of these dxf clip files undergoing an extrusion operation.
P_test3011A.dxf
(374.45 KiB) Downloaded 18 times
Face_test.py
(4.11 KiB) Downloaded 20 times
TheMarkster
Re: Face Placement cannot be changed
Post by TheMarkster »
Add this line:
FreeCADGui.updateGui()
pate
Post by pate »
Great, now it works. Thank you. :D :D :D
Now I can move forward a lot.
