Is it possible to pass CLI arguments to a FreeCADCMD script?
Coreform_Greg
Post by Coreform_Greg »
Following guidance from https://wiki.freecad.org/Embedding_FreeCAD, I have a "master" Python script that needs to run FreeCAD as a subroutine. I'm unable to import FreeCAD likely due to the caveat regarding compilers:
Since the FreeCAD Python module is compiled from C++ (rather than being a pure Python module), it can only be imported from a compatible Python interpreter. Generally this means that the Python interpreter must be compiled with the same C compiler as was used to build FreeCAD. Information about the compiler used to build a Python interpreter (including the one built with FreeCAD) can be found as follows
Following the advice on the page, I'm instead going to issue a Python subprocess.run( cli_command, shell=True, check=True) from my master script. The cli_command will look something like: freecadcmd UpdateGeometry.py, however, I need to pass a variable into the UpdateGeometry.py script as a system argument (e.g. sys.argv[-1]). But I've looked high and low and can't seem to find any way to pass an argument into a script called in this manner.
This process is the same thing I do in my current Abaqus workflow, e.g. master script, uses subprocess.run to call a CLI executable, with an input Python script that accepts CLI arguments. The syntax for doing this with Abaqus is:
abaqus cae script=try.py -- argument1 argument2 argument3
which, inside the master Python script would be something like:
cli_command = f"abaqus cae script=UpdateGeometry.py -- {innerRadius} {outerRadius} {thickness}"
subprocess.run( cli_command, shell=True, check=True )
Is there any similar functionality to this when using freecadcmd that I've missed? I'd rather not have to write a temporary file to disk and hardcode this into a file read function in my script.
TheMarkster
Re: Is it possible to pass CLI arguments to a FreeCADCMD script?
Post by TheMarkster »
I'm not sure about subprocesses. From the command line parameters may be passed to a script as such:
FreeCAD c:\users\path\to\macros\commandline_args.FCMacro "first argument" 42
And in the commandline_args macro:
import sys
print(f"sys.argv = {sys.argv}")
my_arg = sys.argv[2]
my_arg2 = sys.argv[3]
print(f"my_arg = {my_arg}, my_arg2 = {my_arg2}")
Output:
sys.argv = ['FreeCAD', 'c:\\users\\mwganson\\documents\\freecad\\macros\\commandline_args.FCMacro', 'first argument', '42']
my_arg = first argument, my_arg2 = 42
Founder
Post by wmayer »
master.py
import subprocess
innerRadius = 2
outerRadius = 4
thickness = 1
cli_command = f"./bin/FreeCADCmd UpdateGeometry.py -- {innerRadius} {outerRadius} {thickness}"
UpdateGeometry.py:
import sys
print ("import UpdateGeometry.py")
print (sys.argv)
Run it with
python3 master.py
The output of UpdateGeometry.py wil be:
['./bin/FreeCADCmd', 'UpdateGeometry.py', '--', '2', '4', '1']
sliptonic
Post by sliptonic »
wmayer wrote: Wed Dec 01, 2021 1:04 pm ping
This works unless the argument is a filename of a type that FreeCAD understands.
For example, if I pass an argument that is a json file, I get an error from Fem:
import newstepmaker.py
['/home/brad/FCD/FC/bin/FreeCADCmd', 'Script', 'newstepmaker.py', '--', 'job.json']
  File "/home/brad/FCD/FC/Mod/Fem/feminout/importYamlJsonMesh.py", line 71, in open
    return insert(filename, docname)
  File "/home/brad/FCD/FC/Mod/Fem/feminout/importYamlJsonMesh.py", line 87, in insert
    import_yaml_json_mesh(filename)
  File "/home/brad/FCD/FC/Mod/Fem/feminout/importYamlJsonMesh.py", line 132, in import_yaml_json_mesh
    femmesh = read(fileString)
  File "/home/brad/FCD/FC/Mod/Fem/feminout/importYamlJsonMesh.py", line 173, in read
    mesh_data = convert_raw_data_to_mesh_data(raw_mesh_data)
  File "/home/brad/FCD/FC/Mod/Fem/feminout/importYamlJsonMesh.py", line 190, in convert_raw_data_to_mesh_data
    for (type_key, type_dict) in raw_mesh_data.items():
<class 'AttributeError'>: 'list' object has no attribute 'items'
Exception while processing file: job.json ['list' object has no attribute 'items']
Any idea how to pass in the name of a json file as an argument to the script file?
Founder
Post by wmayer »
The question is why did the above example work. Internally the numbers were treated as file names but because they don't have a suffix there is no module to handle them. That's why they "slipped" through to be handled by a script later.
With git commit f4b4aabc32 I have implemented the option "--pass" whose arguments are ignored by the application so that a script can handle them later.
So, you will have to change your master script to:
json_file = "job.json"
cli_command = f"./bin/FreeCADCmd newstepmaker.py --pass {json_file}"
Note 1:
The option supports one or more arguments, i.e. if you write
./bin/FreeCADCmd newstepmaker.py --pass job1.json job2.json job3.json
then the application ignores job1.json, job2.json, job3.json.
Note 2:
If you have a more complex command line string where some files should be handled by the application you can write
./bin/FreeCADCmd newstepmaker.py --pass job1.json job2.json job3.json --input-file job4.json
or
./bin/FreeCADCmd newstepmaker.py --pass job1.json job2.json job3.json -- job4.json
In this case the application ignores job1.json, job2.json, job3.json but handles job4.json
