Get Part.Wire data from Cut
Tom28
Post by Tom28 »
Hello @ all,
I am having the folowing script, where I do a cut of a shape:
        # cut shape with cutting box
        doc.addObject('Part::Cut', 'cut')
        doc.cut.Base = doc.shape
        doc.cut.Tool = doc.cut_box
        doc.recompute()
        # create cutting surface
        cut_surf_wires = list()
        for i in doc.cut.Shape.slice(App.Vector(0, 0, 1), 0):
            cut_surf_wires.append(i)
        cut_surf = Part.Compound(cut_surf_wires)
        add_cut_surf = doc.addObject('Part::Feature', 'cut_surf')
        add_cut_surf.Shape = cut_surf
Now I want to access the path datas of this cutting surface, I tried a lot but have no clue so far how to access these data.
Any hint would be appreciated
Tom
onekk
Re: Get Part.Wire data from Cut
Post by onekk »
If you add a compound (remember compound has no intersecting edges), you have a sort of container, so you have to dig more deep into the tree to obtain primitives (surfaces, wires and so on).
you could try to do get some interesting info simply using:
print(dir(add_cut_surf))
and see what properties and methods are exposed.
Maybe not the more clean way, but it usually works.
Regards
Carlo D.
- Various other stuffs.
openBrain
Post by openBrain »
It's a bit hard to help as a Cut doesn't result in a surface, but in a solid with multiple surfaces.
How would you identify the face that was "born" from the Cut ?
ebrahim raeyat
Post by ebrahim raeyat »
openBrain wrote: Wed Dec 01, 2021 10:56 am It's a bit hard to help as a Cut doesn't result in a surface, but in a solid with multiple surfaces.
may be this can help?
https://github.com/ebrahimraeyat/Civil/ ... om.py#L144
onekk
Post by onekk »
OK.
you have this object that is a "list of faces".
Try with a generic solid, you will obtain the wire simply doing:
Part.show(solid.Faces[0].OuterWire, "wire")
But if faces has "holes" Outerwire is generally hold the external wire, while Wires will hold even holes, a simple loop will traverse things.
Hope it helps
Regards
Carlo D.
Tom28
Post by Tom28 »
Many thanks, I will try and give you feedback here..
Tom
