Sketch Inside/Outside Curve
I am trying to do some processing on a sketch, when scanning a sketches geometry is there an easy way of determining if a curve is an inside or outside curve?
see screenshot
see screenshot
- Shalmeneser
Re: Sketch Inside/Outside Curve
Coming from outside, each time you cross a line, change color (B/W).
If the center is the same color of outside area : outside.
If ...
but center of inside curve can be in the outside area.
If ...
- Capture du 2021-12-03 00-06-58.png (3.77 KiB) Viewed 2177 times
I guess the question is concave/convexShalmeneser wrote: ↑Thu Dec 02, 2021 11:05 pm Coming from outside, each time you cross a line, change color (B/W).
If ...
- Shalmeneser
Find upper-left point then turn clockwise along the border. One side is inside, other side is outside.
No, it works with these as well. It is only critical if you by a bad coincidence cross a border at a point on the curve to be tested. Starting from the outside count the border trsnsitions. If the number is odd you are inside, if it is even, you are outside. Herer is a rough example using Sketcher
red: Sketch to be tested
white: outside
blue: inside.
- SnipScreenshot-9487a0.png (35.92 KiB) Viewed 2085 times
I know this My point is that I guess that OP question is actually to be able to determine if a curve is concave or convex.chrisb wrote: ↑Fri Dec 03, 2021 9:30 am No, it works with these as well. It is only critical if you by a bad coincidence cross a border at a point on the curve to be tested. Starting from the outside count the border trsnsitions. If the number is odd you are inside, if it is even, you are outside. Herer is a rough example using Sketcher
The OP wants to be able to determine from the information available from scanning the sketch.openBrain wrote: ↑Fri Dec 03, 2021 9:34 amI know this My point is that I guess that OP question is actually to be able to determine if a curve is concave or convex.chrisb wrote: ↑Fri Dec 03, 2021 9:30 am No, it works with these as well. It is only critical if you by a bad coincidence cross a border at a point on the curve to be tested. Starting from the outside count the border trsnsitions. If the number is odd you are inside, if it is even, you are outside. Herer is a rough example using Sketcher
I know the theory about does it cross a line etc, but how to program it?
To help me understand what my options are the code that scans the sketch has
if case('Part::GeomArcOfCircle') :
print('ArcofCircle')
print(dir(gs))
print(gs.StartPoint)
print(gs.EndPoint)
print(gs.Center)
print(gs.Radius)
print(gs.centerOfCurvature)
print(gs.curvature)
print(gs)
09:51:40 ArcofCircle
09:51:40 ['AngleXU', 'Axis', 'Center', 'Circle', 'Content', 'Continuity', 'EndPoint', 'FirstParameter', 'LastParameter', 'Location', 'MemSize', 'Module', 'Radius', 'Rotation', 'StartPoint', 'Tag', 'TypeId', 'XAxis', 'YAxis', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'approximateBSpline', 'centerOfCurvature', 'clone', 'continuityWith', 'copy', 'curvature', 'deleteExtensionOfName', 'deleteExtensionOfType', 'discretize', 'dumpContent', 'getAllDerivedFrom', 'getD0', 'getD1', 'getD2', 'getD3', 'getDN', 'getExtensionOfName', 'getExtensionOfType', 'getExtensions', 'hasExtensionOfName', 'hasExtensionOfType', 'intersect', 'intersect2d', 'intersectCC', 'intersectCS', 'isClosed', 'isDerivedFrom', 'isPeriodic', 'length', 'makeRuledSurface', 'mirror', 'normal', 'parameter', 'parameterAtDistance', 'period', 'restoreContent', 'reverse', 'reversedParameter', 'rotate', 'scale', 'setExtension', 'setParameterRange', 'tangent', 'toBSpline', 'toNurbs', 'toShape', 'transform', 'translate', 'trim', 'value']
09:51:40 Vector (6.171572889881885, 2.4369546850601067e-16, 0.0)
09:51:40 Vector (11.999999999999998, -0.999999999972443, 0.0)
09:51:40 Vector (9.171572889881885, 4.14020057e-08, 0.0)
09:51:40 3.0
09:51:40 <built-in method centerOfCurvature of Part.ArcOfCircle object at 0x7fed22754de8>
09:51:40 <built-in method curvature of Part.ArcOfCircle object at 0x7fed22754de8>
Also on the bases that one has to perform an algorithm on line crossing etc what do the various intersect?? functions do?
What does the function curvature return?
For the outer wire this can work:
Create a face from the sketch: face = Part.makeFace(sketch.Shape, "Part::FaceMakerSimple").
Get an ordered_vertexes_list: face.OuterWire.OrderedVertexes.
For each arc check the order of edge.firstVertex() and edge.lastVertex() in ordered_vertexes_list.
If the order is first->last the arc is convex.
To check if a point is inside the face you can use its isInside() method.
Interesting topic and @Roy_043's approach to problem to read
@Roy_043 indicates the solution apply to outerwire. Just some random thoughts. Sketch.Shape.Wires should return all wires in a Sketch e.g.
Test if the wire one by one if it is closed; then test the wires if they are 'inside' or 'outside' against the outerwire ( pick a point along the wire and test by algorithm discussed above?). Then test the concerned curve with @Roy_043's approach - but the reverse of the logic is true?
https://towardsdatascience.com/is-the-p ... 4b86472119
>>> s.Shape.Wires
[<Wire object at 0x557e08a1ef10>, <Wire object at 0x557e08a18f90>, <Wire object at 0x557e08a19010>]
Something similar to some modelling discussion on this page:
https://dev.opencascade.org/doc/occt-7. ... algos.html
when dealing with Interior/Exterior and following
It seems that OCCT has some methods (functions in C++ ??) to deal with them, but I don't know if and how they are implemented in FreeCAD.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
