Try to post simply the view Tab and not "display properties" as in the first image.
0.18 is old, so maybe better to use 0.19 (that is the actual stable release and is at his third update 0.19.3)
From the information given, this is not a bug, simply a "wrong place" where to look.
"display properties" are the default colors that a Shape will use if nothing is changed in his ViewObject properties.
using:
doc.getObject(NewSliceName).ViewObject.ShapeColor = (0.4, 0.5, 0.3, 1.0)
You are changing the color
only for the object "NewSliceName" and not for all the "documentObjects".
See this image:
- shapecolor.png (25.88 KiB) Viewed 2822 times
Please post this tab with your actual setting, probably you will see that the property Shapecolor is what you want.
If you want to change "all objects, colors" you have to do something different.
So the image is perfectly right, as you are seeing "default screen properties" and not the Object properties that are in the "View Tab" of "NewSliceName".
Regards
Carlo D.
