Accessing face data
drmacro
Accessing face data
Post by drmacro »
As with every time I want to drill down to a particular objects data, stumped again. :oops:
I can see that when a face of a Part Cube or Part Design Pad is selected the full name in the selection object is, for example:
"(App.getDocument('Unnamed').getObject('Pad'),['Face2',])"
So, the user has selected Face2 and that really translates to object Faces[1].
But, how do I get to the Faces object so I could do, for example:
myvector = myselface.Faces[1].CenterOfGravity
Naively I tried:
myselface = App.getDocument('Unnamed').getObject('Pad'),['Face2',]
But, nope. :mrgreen:
openBrain
Re: Accessing face data
Post by openBrain »
Depends what you have as available information.
If the subelement is currently selected
Gui.Selection.getSelectionEx()[0].SubObjects[0]
edwilliams16
Post by edwilliams16 »
How about
pd =App.getDocument('Unnamed').getObject('Pad')
fc = pd.Shape.Faces[1]  #Face2
myvector = fc.CenterOfGravity
vm4dim
Post by vm4dim »
>>> for f in App.ActiveDocument.getObject("Box").Shape.Faces: print(f, f.CenterOfGravity);
<Face object at 0x55b50de02f10> Vector (0.0, 5.0, 5.0)
<Face object at 0x55b51402bf10> Vector (10.0, 5.0, 5.0)
<Face object at 0x55b51401e8d0> Vector (5.0, 0.0, 5.0)
<Face object at 0x55b513738820> Vector (5.0, 10.0, 5.0)
<Face object at 0x55b514008380> Vector (5.0, 5.0, 0.0)
<Face object at 0x55b51441ef60> Vector (5.0, 5.0, 10.0)
drmacro
Post by drmacro »
edwilliams16 wrote: Wed Dec 08, 2021 5:31 pm How about
This is all well and good if as a human I'm looking at a breakpoint in the code and see Face2 and know that is a count and not a 0 based index.
But, I wasn't clear how code it to access Faces[x].
In this case, I needed something like:
sel = Gui.Selection.getSelectionEx()
if len(sel) == 1:
    subobjs = sel[0].SubObjects
    if len(subobjs) == 1:
        face = subobjs[0]
        if face.ShapeType == 'Face':
                COG=face.CenterOfGravity
                newvert = App.ActiveDocument.addObject("Part::Vertex","Vertex")
                newvert.X=COG.x
                newvert.Y=COG.y
                newvert.Z=COG.z
Though, shouldn't I be able to use the COG vector rather than it's constituent x,y,z?
And what does the message: "Warning: Wire is deprecated, please use OuterWire" mean... :?
edwilliams16
@drmacro Your OP seemed to suggest you were trying to access the face by its name. Accessing via selection is slightly different.
If you want to bundle the components into a vector
(newvert.X, newvert.Y, newvert.Z) = COG
is tidier. It appears a vector is just a tuple of its components.
drmacro
Post by drmacro »
edwilliams16 wrote: Wed Dec 08, 2021 6:51 pm @drmacro Your OP seemed to suggest you were trying to access the face by its name. Accessing via selection is slightly different.
Yes, bad description on my part. But, the debug let me see the name of "Face2" in the value of the SelectionObject
(i.e. sel[0].FullName), but it didn't click that the SubObject was the selected face.
Duh, obvious...pythonic (I guess). I just don't think in "programmer" any more I guess. :mrgreen:
freedman
Post by freedman »
I finally found what works the best for me, this is what I put in a SelObserver:
self.ob1 =  Gui.Selection.getSelectionEx("",0)
for sel in self.ob1:
	for subname in sel.SubElementNames:
		for obj in sel.Object.getSubObjectList(subname):
			if hasattr(obj,'Shape'):
				print("COG = ", obj.Shape.CenterOfGravity)
				print("Faces are ", obj.Shape.Faces)
	#		if obj.TypeId ==  "App::Link":
	#		if obj.TypeId == "App::LinkElement":
	#		if obj.TypeId == "PartDesign::Body":
	#		if obj.TypeId == "Sketcher::SketchObject":
