Running pip from within FreeCAD
chennes
Re: Running pip from within FreeCAD
Post by chennes »
sgrogan wrote: Sat Jan 15, 2022 6:19 pm
chennes wrote: Sat Jan 15, 2022 4:43 pm I think numpy is optional, in that it's only required by some workbenches, so if you compile without them it may be missing.
What is a good add-on to test? One that has a good requirements.txt file.
I've been using Inventor and SteelColumn as my two main test cases, since they both have dependencies that my system didn't have by default.
Chris Hennes
Pioneer Library System
chennes
Post by chennes »
user1234 wrote: Sat Jan 15, 2022 8:37 pm Whitelisted or not, FreeCAD must ask if if you want to run pip install.
It does: please see https://github.com/FreeCAD/FreeCAD/pull/5376
Chris Hennes
user1234
Post by user1234 »
chennes wrote: Sun Jan 16, 2022 1:32 am It does: please see https://github.com/FreeCAD/FreeCAD/pull/5376
Oh, i did not know there was an other discussion about that.
Thanks for clarifying! Thanks for working on it!
Greetings
user1234
chennes
Post by chennes »
ebrahim raeyat wrote: Sat Jan 15, 2022 11:15 am Here is my wishlist :
  • comtypes: for communicating with windows software
I'm a little leery of adding comtypes: it appears to be essentially without a maintainer right now, and is having some Py2-Py3 conversion difficulties in recent versions of Python. Have you considered another option?
Chris Hennes
ebrahim raeyat
Post by ebrahim raeyat »
chennes wrote: Wed Jan 19, 2022 3:26 pm
I extensively use this package for communicating with CSI ETABS Software in my etabs api module. I have no issue with it:
https://github.com/ebrahimraeyat/etabs_api
I don't think there is an options that works as well as comtypes. Thanks
