Running pip from within FreeCAD
chennes
Post by chennes »
I'm working on dependency resolution for the Addon Manager, and I'd like to be able to offer the user the ability to (attempt to) install missing Python dependencies. From a normal Python script I'd write something like:
                subprocess.check_call([sys.executable, "-m", "pip", "--version"])
But of course this doesn't work within FreeCAD, because sys.executable is FreeCAD, not python! How do I figure out what the FreeCAD Python interpreter binary is, so I can execute this sort of command?
ETA: Or, if that doesn't really make sense (since I guess the "binary" really is FreeCAD), how can I use something like "runpy.run_module" to work?
ETA2: Some notes to self:
# Something like:
import runpy
old_argv = sys.argv
sys.argv=["pip","install","ezdxf"]
sys.argc = len(sys.argv)
runpy.run_module("pip",run_name="__main__")
# This fails because it is expecting an interactive terminal, I think
Chris Hennes
Pioneer Library System
gbroques
Re: Running pip from within FreeCAD
Post by gbroques »
chennes wrote: Tue Jan 04, 2022 10:44 pm How do I figure out what the FreeCAD Python interpreter binary is, so I can execute this sort of command?
shutil.which may help you.
>>> import shutil
>>> shutil.which('python')
'/home/g/miniconda3/envs/openafpm-cad-core/bin/python'
Reference: https://stackoverflow.com/questions/987 ... ch-command
gbroques
Post by gbroques »
Additionally loo did some work with FreeCAD and pip you may want to look at.
See:
https://github.com/looooo/freecad.pip
looo wrote:
ickby
Post by ickby »
I tried to figure this out for my add-on. In the end I just called the python executable, with the following extra logic:
On windows:
- set the working directory for the call to the freecad bin folder, as there is the python executable compatible with freecad
On Linux:
- it is possible that freecad uses a different python version than the system default, e.g. python2 Vs python3. Hence this needs to be figured out
Appimage:
- did not get it to work
Here the code:
https://github.com/OpenCollaborationPla ... ler.py#L48
nic
Post by nic »
chennes wrote: Tue Jan 04, 2022 10:44 pm I'm working on dependency resolution for the Addon Manager, and I'd like to be able to offer the user the ability to (attempt to) install missing Python dependencies. From a normal Python script
Something like :
import pip; pip.main(["install", "pynastran"])
onekk
Post by onekk »
There will be problem with appimages, but as i usually import things to use in FreeCAD, maybe it will be possible to state a directory in userdir from which importing things.
This will involve to retrieve user directory, maybe a subdir with appropriate name and add to the Path of the internal interpreter.
This should be working, but the way to have pip to install missing packages in userdir\site_packages is unknown to me.
I'm away from PC so I could not investigate further.
Regards
Carlo D.
- Various other stuffs.
Founder
Post by wmayer »
To me the very first question is whether it's a good idea to let FreeCAD install itself any 3rd party packages and to be honest I doubt it.
My main concerns:
  • Do we have full control over what will be installed or in other words: can it be misused to install any malware? AFAIR there were already such cases. And according to https://stackoverflow.com/questions/382 ... stall-them there is not even an independent quality control of the PyPI.
  • In many cases the OS (i.e. mainly a Linux distribution) provides a suitable package in its repository and this should be preferred over any PyPI stuff because the risk to break your system with PyPI packages is much higher.
    In the past we have seen a couple of postings where a user broke his system because he installed PySide2 via pip that may pull in a different Qt version that (partially) overwrites the system Qt version.
Like always it's a trade-off between convenience and security and is the little gain of convenience really worth all the trouble? IMO, if an add-on requires a 3rd party package then it should inform the user about it and let him decide how to continue.
ebrahim raeyat
Post by ebrahim raeyat »
ickby wrote: Wed Jan 05, 2022 6:13 am
Here the code:
such a great code, it is excellent.
chennes
Post by chennes »
wmayer wrote: Wed Jan 05, 2022 12:49 pm To me the very first question is whether it's a good idea to let FreeCAD install itself any 3rd party packages and to be honest I doubt it.
I am happy to defer to you on this point (obviously it's less work!), but I have some concerns about the benefits of your suggested approach. To discuss your concerns first:
  • Do we have full control over what will be installed?
No: asking pip to install a package implies installing all of that package's dependencies as well. But I think it's worth remembering a) while malware distribution via pip has happened it is a rare occurrence, and has not called for a moratorium on using pip, and b) that not only might one of those dependent packages be malware, but the FreeCAD package itself might be malware! Further, if we say to a user "we are not going to install this package for you, go do it yourself", we're basically still telling them to install malware. A user sophisticated enough to recognize the possibility of this as a malware distribution vector will always have the option to say "no, don't install the dependencies", and for an unsophisticated user there's little difference between our actually installing it, and our instructing them to do so.
This is a serious concern, and probably undetectable by us, though if there is a way I am all ears! Maybe try to do an apt/yum/brew/whatever search before offering pip?
wmayer wrote: Wed Jan 05, 2022 12:49 pm Like always it's a trade-off between convenience and security and is the little gain of convenience really worth all the trouble? IMO, if an add-on requires a 3rd party package then it should inform the user about it and let him decide how to continue.
My concern is that saying to a user not familiar with python installation: "Install this dependency" is the same as saying "You can't use this Addon," because they don't know how to do it. I suspect this is particularly true on systems where we are shipping a monolithic package (e.g. Windows, Appimage), where the user will not even know which copy of python they should be installing with.
The paths forward as I see them are:
  1. Keep the old behavior: tell the user there are dependencies they should install, and abort installation of the Addon
  2. Attempt to explain to the user how to install the addon (e.g. where is the python instance they need), but still tell them to do it themselves.
  3. Try to figure out really how the user should do the addon installation (e.g. detect if their system uses apt, see if apt has a package, offer instructions for using apt to install it), but still make the user do it themselves.
  4. Same as above, but actually offer to run the commands for them.
Chris Hennes
LarryWoestman
Post by LarryWoestman »
Something else to consider when using something like "pip" is that you don't have
any guarantees of repeatability either of which packages get installed or what
versions of packages get installed. This makes it very hard to test or debug
a problem because you can't be confident that you can reproduce the same
configuration twice.
