Running pip from within FreeCAD
sgrogan
Re: Running pip from within FreeCAD
Post by sgrogan »
chennes wrote: Fri Jan 14, 2022 6:07 pm Any obvious additions I should make?
Some to consider?
matplotlib - FEM WB
ply - OpenSCAD WB
pycollada - Open SCAD WB
"fight the good fight"
chennes
Post by chennes »
sgrogan wrote: Sat Jan 15, 2022 3:53 pm
Some to consider?
matplotlib - FEM WB
ply - OpenSCAD WB
To support this we'd have to have a "meta" Workbench whose only job was to supply dependencies -- right now the built-in WBs don't talk to the Addon Manager (though I guess we could add that sort of communication... I had never considered it before).
Chris Hennes
Pioneer Library System
sgrogan
Post by sgrogan »
chennes wrote: Sat Jan 15, 2022 3:56 pm To support this we'd have to have a "meta" Workbench whose only job was to supply dependencies -- right now the built-in WBs don't talk to the Addon Manager (though I guess we could add that sort of communication... I had never considered it before).
I don't know if its necessary.
These are already runtime dependencies, or at least add functionality if present.
It wouldn't be unreasonable for the Add-on developer to assume they are available. By this argument maybe numpy should be removed from the list?
chennes
Post by chennes »
I think numpy is optional, in that it's only required by some workbenches, so if you compile without them it may be missing.
Chris Hennes
sgrogan
Post by sgrogan »
chennes wrote: Sat Jan 15, 2022 4:43 pm I think numpy is optional, in that it's only required by some workbenches, so if you compile without them it may be missing.
This is true. But for a long time we have pulled in numpy because it is a dependency of matplotlib.
See for example the Debian Control file https://salsa.debian.org/science-team/f ... ontrol#L54
I would say the default runtime dependencies are those required when compiling the default workbenches in CMake.
This isn't definitive though. Sometimes the feature is "greyed out", sometimes an error is thrown if the package isn't present.
Technically PySide2 is optional. We certainly don't want users installing the present PYPI PySide2 package.
I'm just starting to test, so all my observations are preliminary.
nic
Post by nic »
it's a workbench I'm currently developing. Sure they will go to requirements file. But will it be enough to pass through the "allowed" official whitelist? Maybe I missed something in the process you set up, but I thought that any package out of this official list would be blocked...
[edit] this post was an answer to:
chennes wrote: Sat Jan 15, 2022 3:16 pm Which workbench are you using these in? Can you add them to a requirements.txt file when you have a moment?
chennes
Post by chennes »
Yes, they need to be added to this Allowed file, as well as be in a requirements.txt file.
Chris Hennes
sgrogan
Post by sgrogan »
What is a good add-on to test? One that has a good requirements.txt file.
keithsloan52
Post by keithsloan52 »
chennes wrote: Fri Jan 14, 2022 6:07 pm For the initial allowed list of Python packages, I've got:
ezdxf
markdown
numpy
olefile
pillow
pygit2
requests
scipy
xlrd
xlutils
xlwt
PyYAML
That covers all of the packages that are currently specified in metadata files in "official" addons. I would guess there are also dependencies out there that are not yet set in a metadata file, but I have no way of knowing what those are. Any objections to this initial list? Any obvious additions I should make?
ImportNURBS uses rhino3dm
GDML uses gmsh ( python library) and lxml
user1234
Post by user1234 »
onekk wrote: Fri Jan 07, 2022 8:33 am A side note pip is not very "integrated" in many distribution, as example on Debian and Arch Linux this is not the recommended way to install packages, and sometimes pip supplied by the distribution is patched do avoid some operation.
+1
Whitelisted or not, FreeCAD must ask if if you want to run pip install. On Debian if have only troubles with pip. When python dependencies are needed, i install them from the apt-get, else it often does not work correctly in FreeCAD or other programs.
Greetings
user1234
