Python script to automatically generate Step files
nasher128
Post by nasher128 »
Hi all.
I'm working on a personal project with contains many parts which I've created, around 25 parts. However, manually exporting each part to prepare my releases takes a while. Is there a Python script or any other method which I can run which automatically exports each part into a STL/STEP file, ready for 3D printing?
Thanks
openBrain
Re: Python script to automatically generate Step files
Post by openBrain »
How are defined your 'parts'? Are these Part containers? Or just all top level objects? Or specific names?
nasher128
Post by nasher128 »
Hi, thanks for the reply. They are specific names. There are no components, just used parts design -> and created a body for my part
onekk
Post by onekk »
It will be possible to generate automatically files from parts.
I use it to generate STL starting from drawings, but I'm coding all the models too.
What you are searching for is similar to this workflow?
  • select all the objects
  • invoke a Macro
  • Macro will generate STEP files starting from selected objects
Regards
Carlo D.
- Various other stuffs.
openBrain
Post by openBrain »
nasher128 wrote: Fri Jan 21, 2022 10:42 pm Hi, thanks for the reply. They are specific names. There are no components, just used parts design -> and created a body for my part
Say you want to export each Body in a separate STEP :
for obj in App.ActiveDocument.findObjects('PartDesign::Body'):
    obj.Shape.exportStep(f"/tmp/{obj.Label}.stp")
This snippet exports in /tmp/ folder and gives the Label of the Body as filename.
