I have an annoying issue. When I edit the macro in notepad++, for some odd reason, all the characters are correctly shown in Freecad macro editor, except tab. It is translated into 4 spaces when opened in Freecad editor. Has anyone had a similar issue? And is there a way to solve it?
notepad ++ tab
freecad tab
Kind regards,
Peter Korenčan
Edit macro in Notepad++ tab issue
- n.FCMacro
- (236 Bytes) Downloaded 16 times
Kind regards,
Peter
Peter
Re: Edit macro in Notepad++ tab issue
Hi
FreeCAD:
Menu > Edit > preference > General > Editor > Indentation Space or Tabs
Notepad ++:
Menu > edition > Traitement des espaces
the best use space
mario
FreeCAD:
Notepad ++:
the best use space
mario
You don't want tabs in your python code, or at least you don't want to mix tabs and spaces. Everybody seems to be using spaces for python code in FreeCAD, so it's better to just use the 4 spaces. Mixing was okay with python2, but no longer works with python3.
Tabs in Python are not very accepted, in fact all the guides to the language will advice to use spaces.
Edit:
from PEP8
It is consistent across OS and between editors.
Other thing, are avoid to have spaces at the end of the line and avoid having empty line with only spaces, so it is better to activate also "Show non printable characters" or whatever options your editor have to show spaces, usually as little grey points.
All editors have such option and is very useful.
Happy coding with Python and FreeCAD.
Regards
Carlo D.
Edit:
from PEP8
Why? "tabs stops" could have different lengths, so the most simple thing is to use 4 space per indent level.
Tabs or Spaces?
Spaces are the preferred indentation method.
Tabs should be used solely to remain consistent with code that is already indented with tabs.
Python disallows mixing tabs and spaces for indentation.
Regards
Carlo D.
- Various other stuffs.
Hi
it is interesting to activate the spaces by default instead of tab in the preference Editor > Indentation
mario
mario
Thanks guys. I changed the setting in notepad++ now it works with tabs. I like it better.
Regards,
Peter
Regards,
Peter
Kind regards,
Peter
Peter
