[SOLVED] ModuleNotFoundError / ImportError - FC 0.20 Macro
bensenior
Post by bensenior »
Hello,
This is a question about trying to use the Legify Macro from vecronic (https://github.com/vectronic/freecad-legify-macros).
I'm using the weekly dev build AppImage on Ubuntu 21.10, placing the legify-brick.FCMacro in ~/.local/share/FreeCAD/Macro/ and the accompanying Legify package in the same location (i.e. ...Macro/Legify/[stuff]).
When I try to execute the macro in FC, I get the error :
<class 'ModuleNotFoundError'>: No module named 'Legify'
  File "/home/ben/.local/share/FreeCAD/Macro/legify-brick.FCMacro", line 6, in <module>
    from Legify.Dialog import *
The import statements in legify-brick.FCMacro are :
# coding: UTF-8
from FreeCAD import Console, Gui
from PySide2.QtWidgets import QMessageBox
from PySide2.QtCore import Qt
If I try to modify the import statement (I really know *nothing* about Python besides the last two hour's digging around trying to figure out what's broken) for Legify to something like
from .Legify.Dialog import *
to make the import relative and explicit (?!?) I then get the error :
<class 'ImportError'>: attempted relative import with no known parent package
    from . Legify.Dialog import *
Can somebody please help point me in the right direction? It would be so great to have some Lego Macros around for rapid prototyping :-)
Ben
onekk
Post by onekk »
usually you have to add the path to the library to FreeCAD.
some code that could help is:
MODULE_PATH = u"/your/module/position/"
if not MODULE_PATH in sys.path:
    print("module path is not present, loading....")
    sys.path.insert(-1,MODULE_PATH)
else:
    print("module path is already present")
if you put this at top of your code it will ad the module path to sys.path and FreeCAD will find it when searching.
Hope it helps
Regards
Carlo D.
- Various other stuffs.
bensenior
Re: [SOLVED - but not understood] ModuleNotFoundError / ImportError - FC 0.20 Macro
Post by bensenior »
Yes, thank you very much :) !
I'm not sure if it's something that's perhaps wonky in the weekly build, but I actually needed to set the module path to
MODULE_PATH = "/home/ben/.local/share/FreeCAD/Macro/"
Given that that's supposed to be the default macro path, could it be that the default sys.path for FreeCAD isn't quite setup correctly?
onekk
Re: [SOLVED] ModuleNotFoundError / ImportError - FC 0.20 Macro
Post by onekk »
Not exactly.
This is the default path that FreeCAD will automatically use for Macro.
It is different from the path used by WB that is in the a subdir of the "/Mod/" user directory and usually is in "sys.path"
Concepts are slightly different, as Macro is punt in the Macro Folder and searched by the Macro part of FreeCAD.
When you are using scripts you are suing "directly "FreeCAD python interpreter" that has his own "search path" that is accessble with "sys.path"
try to put this code in the Python Console:
import sys
print(sys.path)
import sys in console wil be not stricly necessary in a script I suppose is mandatory.
In my case I have a bunch of dirs, as running from an AppIMage, and also some "user dirs", but not "~/userdir/Macro"
Note that recently @wmayer has made some changes to the position of the stabdard user directories followint XDG standards so many of them are put in "~/.config/FreeCAD".
Mine are not as I'm using different config dirs for every version of FreeCAD I'm using, as I have 0.19.3, 0.19LS3, "0.20 latest" with Italian language and "0.20 latest" with English language, to be able to make some screenshot for my "scripting guide", I know it is a mess, but not difficult.
It suffice to set:
export FREECAD_USER_HOME="~/FreeCAD/config-eng"
to set an appropriate different user directory prior to run FreeCAD binary, in my case it is in the bash script that launch AppImage.
This way you could use different languages and different version without polluting each others config dirs.
The only drawback is that you have to set Preferences, AddOns and Macro for every version, but it is not a big hassle, as in Linux symlink will help a lot to make some "common directories" at least for same version of FreeCAD, (If you mix different version it will be a big mess).
Regards
Carlo D.
