Yes: once we have stopped hardcoding the path to user macros, I definitely imagine there being several ways to set which directories to look in.
Folder Structure for Macros?
Re: Folder Structure for Macros?
the code is at here:
https://github.com/FreeCAD/FreeCAD/blob ... mp.cpp#L78
What it does is:
1. retrieve the macro path from parameter or use the user data as default
2. Fill the List box
The list is not needed. Better change to just browse to select a file. Then do whatever one want.
What it does is:
- bavariaSHAPE
What @chrisb writes would be a real simplification for macro management. Running macros from any folder without having to remember the path of the previous folder would be a relief for everyone. The current path specification (e.g. ...AppData/Roaming on Windows) is hard to follow for many users.
… for a happy FreeCAD-World … JM2C …
Agreed. After reading this post, I started working on packaging for a macro I'm developing. I chose to use a subfolder under .../Macro to hold class files, icon files, and thread standard lookup tables, keeping the FCMacro files in /Macro. This worked great except for one hard stop... I can't load the class file from subfolder into Macro Editor to work on it.bavariaSHAPE wrote: ↑Tue May 24, 2022 9:51 am What @chrisb writes would be a real simplification for macro management.
May whatever Higher Power you believe in bless the Ukrainians. They are a decent people who never hurt anybody.
Another minor annoyance:
The Macro directory finds its way onto the directory history for Save and Save As so I end up accidentally writing FCStd files to the Macro Directory.
You should be able to open from the File -> Open menu.KurtF wrote: ↑Thu May 26, 2022 4:24 pmAgreed. After reading this post, I started working on packaging for a macro I'm developing. I chose to use a subfolder under .../Macro to hold class files, icon files, and thread standard lookup tables, keeping the FCMacro files in /Macro. This worked great except for one hard stop... I can't load the class file from subfolder into Macro Editor to work on it.bavariaSHAPE wrote: ↑Tue May 24, 2022 9:51 am What @chrisb writes would be a real simplification for macro management.
