FreeCAD api fails in external application
drmacro
Re: FreeCAD api fails in external application
Post by drmacro »
wmayer wrote: Wed May 11, 2022 11:21 am ...
Yes __init__.py was created with the content you specified. And, it did not change the problem.
There is a rather long post in this thread about what I found where:
https://forum.freecadweb.org/viewtopic. ... 23#p594423
I noted in the above thread that, when AUR is done sys.path does not have a directory the includes PartDesign.
(In fact, the sys.path list has at least one directory that includes _PartDesign.so and __init__.py, But, no directory named PartDesign.)
I also noted that using the following script to execute Blender does fix the issue.
PYTHONPATH=/usr/lib/freecad/Mod    #define PYTHONPATH
export PYTHONPATH                 #export PYTHONPATH
blender                                    #launch blender
adrianinsaval
Post by adrianinsaval »
wmayer wrote: Wed May 11, 2022 11:21 am Looks OK to me. It creates /usr/lib/freecad and puts the bin and (I hope) the Mod directory inside there and the shared libraries go to /usr/lib
Yes, it also makes symlinks for /usr/lib/*.so into /usr/lib/python3.10/site-packages/ and /usr/lib/freecad/bin/* into /usr/bin
For some reason it also does
echo "export PATH_TO_FREECAD_LIBDIR=/usr/lib" > /etc/profile.d/freecad.sh
do you know if this is necessary and if it even has an effect? it looks really strange to me and looks like it can cause some clashes if I have another local build of freecad
./usr/lib/python3.10/site-packages/PartDesignGui.so
./usr/lib/PartDesignGui.so
Are these identical files or do they come from different FreeCAD and/or Python versions?
The one in site-packages is a symlink to the one in /usr/lib/ so I think the file structure in AUR is correct, I think drmacro is expecting that the /usr/lib/freecad/Mod directory be in sys.path by default but I'm not sure if this is a reasonable expectation? how does this work in other systems?
Founder
Post by wmayer »
adrianinsaval wrote: Wed May 11, 2022 3:46 pm do you know if this is necessary and if it even has an effect?
See https://github.com/FreeCAD/FreeCAD/blob ... y.template
The environment variable is used in this script but not sure if this is placed into a location where it can be found by the interpreter before having loaded the FreeCAD module.
When starting FreeCAD or loading its Python module then it determines its location (i.e. the path of the executable or the library) and expects the Mod directory to be a sibling of the parent directory. Then it adds Mod and all sub-directories to sys.path.
drmacro
Post by drmacro »
adrianinsaval wrote: Tue May 10, 2022 9:33 pm ...
The output of
pacman -Ql freecad-git
produces a list
/etc/
/etc/profile.d/
/usr/
/usr/bin/
/usr/bin/FreeCAD
/usr/bin/FreeCADCmd
/usr/lib/
/usr/lib/DraftUtils.
/usr/lib/Drawing.so
/usr/lib/DrawingGui.
/usr/lib/Fem.so
/usr/lib/FemGui.so
/usr/lib/FreeCAD.so
/usr/lib/FreeCADGui.
/usr/lib/Image.so
/usr/lib/ImageGui.so
/usr/lib/_PartDesign.so
/usr/lib/freecad/Mod/PartDesign/
/usr/lib/freecad/Mod/PartDesign/Init.py
/usr/lib/freecad/Mod/PartDesign/InitGui.py
/usr/lib/freecad/Mod/PartDesign/InvoluteGearFeature.py
/usr/lib/freecad/Mod/PartDesign/InvoluteGearFeature.ui
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestBoolean
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestChamfer
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestDatum.p
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestDraft.p
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestFillet.
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestHole.py
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestInvolut
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestLinearP
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestLoft.py
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestMirrore
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestMultiTr
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestPad.py
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestPipe.py
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestPocket.
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestPolarPa
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestPrimiti
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestRevolve
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestShapeBi
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/TestThickne
/usr/lib/freecad/Mod/PartDesign/PartDesignTests/__init__.py
/usr/lib/freecad/Mod/PartDesign/__init__.py
Adding /usr/lib/freecad/Mod in the settings of sverchok does not add it to syspath (when looking at syspath from the Python or Blender python console).
I have also just discovered the FreeCAD files in /usr/lib/python3.10/site-packages are symlinks to /usr/lib.
Is /usr/lib the appropriate place for freecad files like Part.so, _PartDesign.so, PartGui.so, Path.so, etc.? (But, none to PartDesign)
And, to be duplicated in /usr/lib/freecad/Mod?
Making a symlink to PartDesign in /usr/lib/python3.10/site-packages to /usr/lib/freecad/Mod.
Also solves the import issue in Blender.
Is it possible, that, on both of these machines the earlier AUR scripts that failed left polution in these three places? (Though the symlinks in site-packages is puzzling...I think??)
adrianinsaval
wmayer wrote: Wed May 11, 2022 4:28 pm The environment variable is used in this script but not sure if this is placed into a location where it can be found by the interpreter before having loaded the FreeCAD module.
Looks like in this case it would add /usr/lib to sys.path but I don't see why that would be necessary to begin with @drmacro what happens if you unset this variable before running python?
Given that, is it bad practice to make those symlinks into site-packages? Sounds like that can be the problem here. Or is it because the libraries are in /usr/lib ? Or is this a bug due to the use of INSTALL_TO_SITEPACKAGES=ON?
drmacro wrote: Wed May 11, 2022 4:41 pm The output of
can you post the full output to see the stuff on site-packages? I'm on windows for now.
The symlinks are purposefully created by the AUR script, I don't know if that's a good idea by the packager though. It is extremely unlikely that previous AUR installations would leave junk behind because it gets packaged and goes through pacman (the package manager) which keeps a list of all the files installed and removes them when you uninstall/update a package.
drmacro
Post by drmacro »
adrianinsaval wrote: Wed May 11, 2022 5:10 pm ...@drmacro what happens if you unset this variable before running python?
Do you mean PYTHONPATH?
I specifically tried it without it being set. So, my comments are sans PYTHONPATH
...Given that, is it bad practice to make those symlinks into site-packages? Sounds like that can be the problem here. Or is it because the libraries are in /usr/lib ? Or is this a bug due to the use of INSTALL_TO_SITEPACKAGES=ON?
I don't know, but, it seem to me that just dumping all the FreeCAD modules/etc. in usr/lib is not the desired way...
Since, on Debian there is only my build directory and it works correctly, it seems dumping stuff in site-packages may not be desirable either.
I didn't post the rest because it is long and is just a directory listing o the /usr/lib/freecad/Mod directory.
The symlinks are purposefully created by the AUR script, I don't know if that's a good idea by the packager though. ...
Agreed.
Founder
Post by wmayer »
The symlinks shouldn't be a problem. On Ubuntu it used to be that /usr/bin/freecad is a symlink to /usr/lib/freecad/bin/FreeCAD but the Mod directory is then correctly assumed in /usr/lib/freecad/Mod and not /usr/Mod
drmacro
Post by drmacro »
wmayer wrote: Wed May 11, 2022 5:49 pm
I wouldn't think they are a problem per se.
But, I really wonder if AUR is getting the install quite right.
The two things I see at this point is there is no PartDesign directory that Python finds by default and /usr/lib has FreeCAD packages just mixed with everything in there. As does site-packages and both site-packages and /usr/lib also has freecad/Mod.
Maybe this is the right way, but, seems a bit untidy...
adrianinsaval
according to https://refspecs.linuxfoundation.org/FH ... mmingAndPa since freecad is using a subdirectory inside /usr/lib it should have everything inside that subdirectory and not part of it on /usr/lib I think that is an error in the packaging, also wmayer said that when called freecad would expect Mod to be on ../Mod so that seems like a problem, symlinking stuff into site-packages seems like a hack rather than proper packaging but I don't know about that stuff.
adrianinsaval
@drmacro ok I think I figured it out, here's a working PKGBUILD (remove txt extension), please test that it works without any hacks but please reboot after installation before testing to ensure the PATH_TO_FREECAD_LIBDIR env variable is not set anymore. I'll ask the AUR maintainer to use my PKGBUILD or add me as maintainer to the AUR freecad-git repo
EDIT: I've been added as co-maintainer of the AUR package so I will push my changes tonight once I'm home since I need to setup ssh authentication
EDIT2: done, please test a normal build from AUR again and ping me if something doesn't work (that could be attributed to this build)
