How can I modify a FreeCAD obeject's "Name"?
- Snipaste_2022-05-11_10-05-36.png (7.55 KiB) Viewed 904 times
Thank you!
Re: How can I modify a FreeCAD obeject's "Name"?
You can't. You can assign your own Label. Names are assigned by FreeCAD. https://wiki.freecadweb.org/Object_name
It's possible, just not directly. You could do it by:
# 1. Creating a temporary Document and creating in it a new object with the desired name.
# 2. Reading back the resulting name to get a sanitized name we know we are allowed to use.
# 3. Creating a shallow copy of the original object. We do this without any dependencies,
# as we want to leave those alone.
# 4. Creating another temporary Document and moving the shallow copy there.
# 5. Saving the temporary Document to the temp directory, making note of
# the Name and Label the shallow copy ended up with.
# 6. Opening the saved Document as a .ZIP file...
# 7. ...Then creating an element-wise copy, with each file in the archive having had
# every occurrence of Name and Label values changed to the name we got from step 1.
# 8. And finally, merging the modified Document back into the original Document.
If I had an API that could swap all references to object A to reference its copy A_2 and viceversa, I could turn this into a fully-functional macro.
(Now that I think about it, all these steps could be avoided if Std DuplicateSelection allowed the names of the new objects it creates to be customized.)
You can remove the object and create new one with exact name. If there is no such name this will be working.
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
