There is way to specify a "position" for a menu item and toolbars ?
onekk
Post by onekk »
Hello, as in the title, there is a way to specify the position of a menu item:
Using word, I want to place my menu after Macro (or maybe prior of Help).
For Toolbars, I want to place my toolbar prior of "Part tools" (this is the name of one of the Part WB toolbars).
In alternatives, there is some documentation or code to "study" to see how the things are placed.
I want to make this things, in Python.
Regards
Carlo D.
- Various other stuffs.
onekk
Re: There is way to specify a "position" for a menu item and toolbars ?
Post by onekk »
Nobody has some hint?
Regards
Carlo D.
mario52
Post by mario52 »
onekk
Post by onekk »
mario52 wrote: Sat May 28, 2022 9:32 am Hi
maybe study PersistentToolbars and Remember active workbench by tab
mario
Ok i have seen that the toolbar is:
tb = mw.findChildren(QtGui.QToolBar)
But I haven't guessed how to put a new "item" after another item, I suspect that some "list" or similar thing manipulation must be done, but how?
My main problem is the "menu item" that is placed prior of "File" when the menu is activated.
I could scan the menu with:
def scan_menubar():
    menu = mw.menuWidget()
    actions = menu.actions()
    a = actions
    num_act = len(a)
    b = []
    sep_pos = None
    for ii in range(0, len(a)):
        FreeCAD.Console.PrintMessage(f"n: {ii} text: {a[ii].text()}  Name: {a[ii].objectName()}\n")
        if a[ii].objectName() == "Separator":
            sep_pos = ii
        else:
            b.append(a[ii])
    print(f"Separator position: {sep_pos}")
And I can guess that menu.actions() is thing to manipulate, but how to manipulate it seems the problem.
Any hints?
TIA and Regards
Carlo D.
