[macro req] make line perpendicular to two non-colinear lines [pseudocode]
llll
Post by llll »
Right now I can do it manually, but it is not parametric..
If there's a method to do this in sketcher, please show.
If someone can make macros well, please do this one :D
It's to centre a line at the intersection of two lines, no matter angle..
I've run into need to do this a few times, despite being new. But cyclic dependencies prevent
Maybe rounding errors preventing both angles being driving value? Would fixing that allow solving the cyclic dependency issue? idk
Make One half reference angle, one driving angle
Plug those values into this equation to find correct driving angle.
Larger angle - lesser angle /2 = equalizer.
If larger angle == driving dimension
  	 Driving dimension = larger angle - equalizer
Elif lesser angle == driving dimension
 	 Driving dimensions = lesser angle + equalizer
Roy_043
Re: [macro req] make line perpendicular to two non-colinear lines [pseudocode]
Post by Roy_043 »
You seem to want to bisect an angle in a sketch.
sketch-bisect-angle.FCStd
(7.15 KiB) Downloaded 17 times
Roy_043
Post by Roy_043 »
Without partially redundant constraint.
sketch-bisect-angle-2.FCStd
(6.89 KiB) Downloaded 12 times
