[Solved] PyQt with Selection Observer
thyssentishman
Post by thyssentishman »
Hi all,
I would like to know how I can implement a Selection Observer like the one from here into my Qt interface so that the user can select edges on the 3D view and add them to a QListWidget. I've seen this functionality in many tools from FreeCAD. Here's what I have so far:
import FreeCAD
from PySide import QtGui, QtCore
class SelObserver:
    def addSelection(self):
        sel = FreeCADGui.Selection.getSelectionEx()[0].SubElementNames[0]
        # return selected edge (sel) so it can be added to list:
        # self.edges_list.addItem(sel)
        FreeCADGui.Selection.removeObserver(s)
s = SelObserver()
class GuiDialog(QtGui.QDialog):
    def __init__(self):
        super(GuiDialog, self).__init__()
        self.initUI()
    def initUI(self):
        self.setWindowTitle(" ")
        self.setFixedSize(175,215)
        self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
        self.add_edge = QtGui.QPushButton('Add Edge', self)
        self.edges_list_label = QtGui.QLabel("Edges:", self)
        self.edges_list = QtGui.QListWidget(self)
        self.cancel = QtGui.QPushButton('Cancel', self)
        self.add_edge.clicked.connect(self.addObject)
        self.cancel.clicked.connect(self.onCancel)
        self.add_edge.move(10,10)
        self.add_edge.resize(150, 25)
        self.edges_list_label.move(10,45)
        self.edges_list.move(10,60)
        self.edges_list.resize(155,110)
        self.cancel.move(90,180)
        self.show()
    def onCancel(self):
        self.close()
    def addObject(self, sel):
        FreeCADGui.Selection.addObserver(s)
gui = GuiDialog()
gui.exec_()
As an example of how it should work, the Additive Pipe tool in the Part Design WB has an "Add Edge" button for the user to select an Edge and add it to the list below the button.
OS: Windows 10 Version 2009
Version: 2022.402.28566 (Git)
Branch: LinkStage3
Hash: 0da0525ba7ff10c9efe0476d35ffcdf040ed470d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Germany (en_DE)
Last edited by thyssentishman on Fri May 20, 2022 11:50 am, edited 2 times in total.
mario52
Re: PyQt with Selection Observer
Post by mario52 »
Hi
without selObserver
import FreeCAD
#class SelObserver:
#    def addSelection(self):
#        sel = FreeCADGui.Selection.getSelectionEx()[0].SubElementNames[0]
#        # return selected edge (sel) so it can be added to list:
#        # self.edges_list.addItem(sel)
#        FreeCADGui.Selection.removeObserver(s)
#s = SelObserver()
    def __init__(self):
        self.initUI()
    def initUI(self):
        self.setFixedSize(175,280)
        self.cancel.setIcon(QtGui.QIcon.fromTheme("cancel",QtGui.QIcon(":/icons/edit_Cancel.svg")))
        self.del_edge = QtGui.QPushButton('Del item', self)
        self.clear_list = QtGui.QPushButton('Clear', self)
        self.del_edge.clicked.connect(self.delEdge)
        self.clear_list.clicked.connect(self.clearList)
        self.del_edge.move(10,40)
        self.del_edge.resize(150, 25)
        self.clear_list.move(10,70)
        self.clear_list.resize(150, 25)
        self.edges_list_label.move(10,100)
        self.edges_list.move(10,120)
        self.cancel.move(90,240)
        self.show()
        #sel = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
        subName = sel.SubElementNames[0]
        self.edges_list.addItem(subName)
    def clearList(self):
        self.edges_list.clear()    # clear the window
    def delEdge(self):
        self.edges_list.takeItem(self.edges_list.currentRow()) # del the item selected
    def onCancel(self):
        self.close()
gui = GuiDialog()
gui.exec_()
mario
thyssentishman
Hi @mario52,
Thank you so much. This definitely achieves what I wanted. I don't know how I didn't think of that. I guess I thought of first selecting the "Add Edge" button and then making the selection, but it's obviously simpler the other way around.
I will mark this post as solved, however I would still like to know how to implement the Selection Observer with a Qt interface. For example if I wanted the user to select a set of points in a face (a good example of this is the tool CurveOnMesh from the Surface WB). I believe that to achieve this kind of functionality, a Selection Observer is needed so that the user can make multiple selections before performing an action on them.
Could you maybe provide me with some guidance here. I believe the code I sent you previously could easily be adapted for this functionality.
Thank you!
openBrain
Post by openBrain »
rvq wrote: Fri May 20, 2022 7:10 am Could you maybe provide me with some guidance here. I believe the code I sent you previously could easily be adapted for this functionality.
Thank you!
Here is a minimal demonstrating macro :
from PySide2 import QtCore, QtWidgets
import FreeCADGui as Gui
class myWid(QtWidgets.QListWidget):
	def __init__(self,parent):
		super().__init__(parent)
		self.setWindowFlag(QtCore.Qt.Tool)
		self.setAttribute(QtCore.Qt.WA_DeleteOnClose, True)
		self.setAttribute(QtCore.Qt.WA_WindowPropagation, True)
		Gui.Selection.addObserver(self)
	def addSelection(self,doc,obj,sub,pnt):
		self.updateView()
	def clearSelection(self,doc):
		self.updateView()
	def removeSelection(self,doc,obj, sub):
		self.updateView()
	def updateView(self):
		self.clear()
		sel = Gui.Selection.getSelectionEx('',0)
		for o in sel:
			for so in o.SubElementNames:
				self.addItem(so)
	def closeEvent(self, event):
		Gui.Selection.removeObserver(self)
wid = myWid(Gui.getMainWindow())
wid.show()
thyssentishman
Re: [Solved] PyQt with Selection Observer
Thank you @openBrain, this helps me a lot!
