Need some coding help, macro included
freedman
Post by freedman »
The goal is to select an edge and the macro will highlight the associated face. I made a simple macro so if a Body object is selected in the tree it will exit, simple enough. Start the macro and select an edge.
I am attaching a file but it is just a cylinder.
I'm having a problem here:
for fac in faces:
	if fac.Surface.isPlanar():
        	print("Found planar face",fac)
                Gui.Selection.addSelection(self.doc.Name,'Body',fac)
I can't figure out what AddSelection needs to work correctly.
Thank you
disk1.FCStd
(11.33 KiB) Downloaded 10 times
Additive1.FCMacro
(2.23 KiB) Downloaded 10 times
freedman
Re: Need some coding help, macro included
Post by freedman »
Got it. I'm close, now I need to use edwilliams code to select which face to use.
Additive2.FCMacro
(2.36 KiB) Downloaded 11 times
