I found that normal vectors created via FreeCADGui.ActiveDocument.ActiveObject.toString() are pretty useful. Is there a way to export similar info to:
Normal {
vector [ -1 0 0,
-1 0 0,
-1 0 0,
-1 0 0,
1 0 0,
1 0 0,
1 0 0,
1 0 0,
0 -1 0,
0 -1 0,
0 -1 0,
0 -1 0,
0 1 0,
0 1 0,
0 1 0,
0 1 0,
0 0 -1,
0 0 -1,
0 0 -1,
0 0 -1,
0 0 1,
0 0 1,
0 0 1,
0 0 1 ]
EDIT: I got something after reading OpenInventor docs:
from pivy import coin
import Part
box = Part.makeBox(10, 10, 10)
fcmesh = box.tessellate(0.1)
gen = coin.SoNormalGenerator(True)
for f in fcmesh[1]: #indexes
#print f[0],f[1],f[2]
v0 = fcmesh[0][f[0]]
v1 = fcmesh[0][f[1]]
v2 = fcmesh[0][f[2]]
#print v0, v1, v2
sbv0 = coin.SbVec3f(v0)
sbv1 = coin.SbVec3f(v1)
sbv2 = coin.SbVec3f(v2)
#gen.beginPolygon()
gen.triangle(sbv0, sbv1, sbv2)
#gen.endPolygon()
gen.generate(1.5) #generate with cease angle 1.5 rad
#gen.getNumNormals()
for i in range(gen.getNumNormals()):
print gen.getNormal(i).getValue()
(-1.0, 0.0, 0.0)
(-1.0, 0.0, 0.0)
(-1.0, 0.0, 0.0)
(-1.0, 0.0, 0.0)
(-1.0, 0.0, 0.0)
(-1.0, 0.0, 0.0)
(1.0, 0.0, 0.0)
(1.0, 0.0, 0.0)
(1.0, 0.0, -0.0)
(1.0, 0.0, 0.0)
(1.0, 0.0, 0.0)
(1.0, 0.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, -1.0, 0.0)
(0.0, 1.0, 0.0)
(0.0, 1.0, -0.0)
(0.0, 1.0, 0.0)
(0.0, 1.0, 0.0)
(0.0, 1.0, 0.0)
(0.0, 1.0, 0.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, -1.0)
(0.0, 0.0, 1.0)
(-0.0, 0.0, 1.0)
(0.0, 0.0, 1.0)
(0.0, 0.0, 1.0)
(0.0, 0.0, 1.0)
(0.0, 0.0, 1.0)
