[Solved] There is way to make an object present in treview child of another?
Hello, I'm making some work about objects.
I want to create a new "Part::FeaturePython" object that will have as childs (like in a boolean operation or in extrude) as child in the TreeView to not pollute the view and avoid to hid too many things.
I have some primitives (cubes, cones, spheres and cylinders) and complex objects, like extrusion from sketchs.
For now I have made Links and togled the visibility of the linked objects, but it is a suboptimal solution.
TIA for any help.
Regards
Carlo D.
TIA for any help.
Regards
Carlo D.
- Various other stuffs.
- wandererfan
Re: There is way to make an object present in treview child of another?
obj.ViewObject.claimChildren() controls what appears below obj in the tree.
Thanks, I will try itwandererfan wrote: ↑Fri May 27, 2022 3:02 pm obj.ViewObject.claimChildren() controls what appears below obj in the tree.
EDIT:
claimChildren() from the documentation will return the children Objects, could you kindly point me on some Python examples to study the mechanics?
Regards
Carlo D.
- wandererfan
You return the list of document objects you want to appear as children in the tree view, or an empty list if none are to be claimed. If it is sensible to also delete the children when the user deletes the feature python object, then also look at onDelete(self, vobj, subelements). I use both of these in the pdwrapper macro.
Thanks, I've read your code but I'm getting lost in analyzing the code.TheMarkster wrote: ↑Fri May 27, 2022 3:52 pm You return the list of document objects you want to appear as children in the tree view, or an empty list if none are to be claimed. If it is sensible to also delete the children when the user deletes the feature python object, then also look at onDelete(self, vobj, subelements). I use both of these in the pdwrapper macro.
I could guess that there is a need of a ViewProvider with some functions to make things work, this complicated things some more.
I was hoping that there is around some examples maybe like:
https://wiki.freecadweb.org/Scripted_ob ... attachment
Where things are explained in a more easy way to catch the whole mechanics.
For now I've managed to link the objects to new created object and make the original objects "greyed out" using Visibility = False, If I don't get to make them children of the newly created object, I will left this for some future improvements.
Thanks and Regards
Carlo D.
yes, you need to define a ViewProvider() for your object. You can find a minimalistic example on how to setup and use one here:
https://github.com/Zolko-123/FreeCAD_As ... ts.py#L301
Thanks @Zolko I will see your code tomorrow, and let you know if I've solved.
Thanks again and Regards
Carlo D.
Carlo D.
Hello, I've tried your code, and probably I've not guessed the points:
class ViewProvider_EM(object):
"""ViewProvider Object."""
def __init__(self, vobj):
"""Init things."""
vobj.Proxy = self
self.attach(vobj)
def attach(self, vobj):
"""Attach things."""
self.ViewObject = vobj
self.Object = vobj.Object
def claimChildren(self):
"""Return objects that will be placed under it in the tree view."""
if hasattr(self.Object, "ShowElement") and self.Object.ShowElement:
return self.Object.ElementList
elif hasattr(self.Object, "SourceObject"):
return [self.Object.SourceObject]
def getIcon(self):
"""Return an icon corresponding to the array type."""
iconFile = None
if hasattr(self.Object,"ArrayType"):
tp = self.Object.ArrayType
if tp=='Circular Array':
iconFile = os.path.join( Asm4.iconPath, 'Asm4_PolarArray.svg')
if tp=='Linear Array':
iconFile = os.path.join( Asm4.iconPath, 'Asm4_LinkArray.svg')
if iconFile:
return iconFile
def __getstate__(self):
"""Get state."""
return None
def __setstate__(self, _state):
"""Set state."""
return None
And probably this code is not exactly the best, as it is a mix of two different source.
obj = doc.addObject("Part::FeaturePython", "EM_Object")
obj.Label = "EM_Object"
EM_Object(obj, sel)
obj.ViewObject.Proxy = 0
ViewProvider_EM(obj.ViewObject)
doc.recompute()
I know that is more than an advice, but I'm almost lost due to the lack of information.
TIA and Regards
Carlo D.
I think these are necessary minimal requirements. I just copied them from other code. The interesting bit is this:onekk wrote: ↑Tue May 31, 2022 11:12 amCode: Select all
class ViewProvider_EM(object): """ViewProvider Object.""" def __init__(self, vobj): """Init things.""" vobj.Proxy = self self.attach(vobj) def attach(self, vobj): """Attach things.""" self.ViewObject = vobj self.Object = vobj.Object def __getstate__(self): """Get state.""" return None def __setstate__(self, _state): """Set state.""" return None
this function must return what you want to see in the tree. So that (future child-) object needs to be referenced in your custom object (EM-Object ?). So your EM-Object needs a variable/property knowing that child-object. But for that, the viewprovider needs to know the object itself, and this is done by:Code: Select all
def claimChildren(self): """Return objects that will be placed under it in the tree view.""" if hasattr(self.Object, "ShowElement") and self.Object.ShowElement: return self.Object.ElementList elif hasattr(self.Object, "SourceObject"): return [self.Object.SourceObject]
obj.ViewObject.Proxy = 0 seems strange, where did you get that from ? Anyway, inside the EM_Object, "sel" needs to be known, and that is what claimChildren() must return. In short, the child needs to be known by the parent (that's the EM_Object), and the parent must be known by the viewprovider (that's the attach() function). You might try :And probably this code is not exactly the best, as it is a mix of two different source.
NOw I 've linked selected objects, but if I want them to be child of my "EM_Object", how I've to modify your code and very probably what property I have to add to the "EM_Object" code?Code: Select all
obj = doc.addObject("Part::FeaturePython", "EM_Object") obj.Label = "EM_Object" EM_Object(obj, sel) obj.ViewObject.Proxy = 0 ViewProvider_EM(obj.ViewObject) doc.recompute()
EM_Object(obj, sel)
doc.recompute()
EM_Object.ViewObject.Proxy = ViewProvider_EM()
https://github.com/FreeCAD/FreeCAD/blob ... ew_base.py
