Boolean operation
Boolean operation
Hi everyone!
How can I do a Boolean operation with keep instrument body (second operand) like in fusion 360 or any other cad?
https://wampi.ru/image/RZFWNRJ
Is the only way out is to make a copy of the body?
I will be glad of any help
Re: Boolean operation
Since FreeCAD obviously can do this, you'll have to be more explicit about what code you are trying. What workbench are you using?
Welcome.
Please remember also to tell us what version of FreeCAD are you susing, follow:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
Hello. Sorry, I'm new to FreeCAD, and I'm still not good at it.
I'm using Version: 0.19.24366 (Git) and I work only on standard workbenches (Part and Part design)
I am a student and as part of my educational project I am writing a macro that simulates the cutting process of a cnc grinding machine. I am creating a model of a workpiece and a tool (Grinding wheel). The tool discretely moves along the specified coordinates, and at each step of the combat operation subtracts a circle from the workpiece.
I need the tool to remain in the scene after the boolean operation, and I don't have to constantly create it again. How can I do this?
As here we are dealing with macros, describing thing without some code is hard.
As programmers "speaks through code" probably some code will be more helpful than a bunch of word.
Usually answers are not too far from the what you have already done, so if its possible to post something, maybe a simpler code that explain your problem, probably someone will drive you in the right direction.
Regards
Carlo D.
Regards
Carlo D.
My problem is in boolean operation:
App.activeDocument().addObject("Part::Cut","Cut")
App.activeDocument().Cut.Base = App.activeDocument().Body
App.activeDocument().Cut.Tool = App.activeDocument().Body001
After performing the operation, the second operand (tool or Body001) is deleted, and I need it to remain, because this body will still be used further.
It's eventually hidden, but surely not deleted. In GUI, you'll find the objects nested under the Cut in the Tree view.Klikest wrote: ↑Sun May 29, 2022 7:25 pm My problem is in boolean operation:
Works for me:
You can of course keep a reference to the objects by assigning them to a variable.
body = App.activeDocument().Body
App.activeDocument().Cut.Base = body
tool = App.activeDocument().Body001
App.activeDocument().Cut.Tool = tool
App.activeDocument().recompute()
- keeptool.FCStd
- (11.59 KiB) Downloaded 13 times
This is not a problem, is the way boolean operation will work.Klikest wrote: ↑Sun May 29, 2022 7:25 pm My problem is in boolean operation:
You are using DocumentObjects and operate on them using "Part::Cut" DocumentObject, and this is the way it works.
You could ever copy the object and use a copy to do the cut so is the copy that go under DocumentObject "Cut", or use another approach:
I'm assuming you have two objects referred as Body and Body001 as "Names"
doc = App.activeDocument()
# we need toposhapes so we are extracting using <.Shape>
body = doc.Body.Shape
tool = doc.Body001.Shape
cut = body.cut(tool).removeSplitter()
cut_dobj = doc.addObject("Part::FeaturePython", "boolean_cut")
cut_dobj.Shape = cut
doc.Recompute()
removeSplitter() is equivalent to put Refine = True in the "Part::Cut" DocumentObject.
NOTE: the code above is not tested, as I've written by hand so probable there are bugs or mistyping, iof anything go wrong please post an example the code, and I will make it work.
Regards
Carlo D.
Thank you so much!
