SOLVED: Common Face when one object is a Linked Copy.
keithsloan52
Post by keithsloan52 »
I am trying to write code to find a common face.
I have a challenge in that one Object2 is a Linked copy of Object1 with a different Placement (Base), otherwise the Shape of the two objects are the same. If I try and create a new shape from the objects with something like
def adjustShape(part):
    # Shape is immutable so have to copy somehow?
    shape = part.Group[0].Shape
    return shape.translate(part.Placement.Base)
I get an error <class 'ReferenceError'>: This object is immutable, you can not set any attribute or call a non const method
Okay the following works
    shape = part.Group[0].Shape.copy()
