REVISIT: Help with computing shared face.
edwilliams16
Re: Help with computing shared face.
Post by edwilliams16 »
How about
print(f'is planar?  {obj.Shape.Faces[0].Surface.TypeId == "Part::GeomPlane"}')
But that possibly might depend on how it was constructed. I've only tested a few possibilities.
keithsloan52
Post by keithsloan52 »
CommonFace function currently looks like
def commonFace(self, shape0, shape1):
        print(f'Common Face : {len(shape0.Faces)} : {len(shape1.Faces)}')
        zero = FreeCAD.Vector(0.0, 0.0, 0.0)
        for i, face0 in enumerate(shape0.Faces):
            for j, face1 in enumerate(shape1.Faces):
               print('dir surface')
               print(dir(face0.Surface))
               print(face0.Surface.TypeId)
               print(isinstance(face0.Surface, Part.Plane))
               print(isinstance(face1.Surface, Part.Plane))
               if isinstance(face0.Surface, Part.Plane) and \
                  isinstance(face1.Surface, Part.Plane):
                  print('Both Flat')
And that outputs for the boxes :-(
20:24:39  dir surface
20:24:39  ['Content', 'Continuity', 'FirstUKnotIndex', 'FirstVKnotIndex', 'LastUKnotIndex', 'LastVKnotIndex', 'MaxDegree', 'MemSize', 'Module', 'NbUKnots', 'NbUPoles', 'NbVKnots', 'NbVPoles', 'Rotation', 'Tag', 'TypeId', 'UDegree', 'UKnotSequence', 'UPeriod', 'VDegree', 'VKnotSequence', 'VPeriod', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'approximate', 'bounds', 'buildFromNSections', 'buildFromPolesMultsKnots', 'clone', 'copy', 'curvature', 'curvatureDirections', 'deleteExtensionOfName', 'deleteExtensionOfType', 'dumpContent', 'exchangeUV', 'getAllDerivedFrom', 'getD0', 'getDN', 'getExtensionOfName', 'getExtensionOfType', 'getExtensions', 'getPole', 'getPoles', 'getPolesAndWeights', 'getResolution', 'getUKnot', 'getUKnots', 'getUMultiplicities', 'getUMultiplicity', 'getVKnot', 'getVKnots', 'getVMultiplicities', 'getVMultiplicity', 'getWeight', 'getWeights', 'hasExtensionOfName', 'hasExtensionOfType', 'increaseDegree', 'increaseUMultiplicity', 'increaseVMultiplicity', 'incrementUMultiplicity', 'incrementVMultiplicity', 'insertUKnot', 'insertUKnots', 'insertVKnot', 'insertVKnots', 'interpolate', 'intersect', 'intersectSS', 'isDerivedFrom', 'isPlanar', 'isUClosed', 'isUPeriodic', 'isURational', 'isUmbillic', 'isVClosed', 'isVPeriodic', 'isVRational', 'mirror', 'movePoint', 'normal', 'parameter', 'projectPoint', 'removeUKnot', 'removeVKnot', 'reparametrize', 'restoreContent', 'rotate', 'scale', 'segment', 'setExtension', 'setPole', 'setPoleCol', 'setPoleRow', 'setUKnot', 'setUKnots', 'setUNotPeriodic', 'setUOrigin', 'setUPeriodic', 'setVKnot', 'setVKnots', 'setVNotPeriodic', 'setVOrigin', 'setVPeriodic', 'setWeight', 'setWeightCol', 'setWeightRow', 'tangent', 'toBSpline', 'toShape', 'toShell', 'transform', 'translate', 'uIso', 'vIso', 'value']
20:24:39  Part::GeomBSplineSurface
20:24:39  False
20:24:39  False
keithsloan52
                  print('Both Flat')
20:24:39  False
20:24:39  False
Boxes are created with this code
def createGeometry(self, fp):
        # print('createGeometry')
        if all((fp.x, fp.y, fp.z)):
            currPlacement = fp.Placement
            # if (hasattr(fp,'x') and hasattr(fp,'y') and hasattr(fp,'z')) :
            mul = GDMLShared.getMult(fp)
            GDMLShared.trace('mul : '+str(mul))
            x = mul * fp.x
            y = mul * fp.y
            z = mul * fp.z
            box = Part.makeBox(x, y, z)
            base = FreeCAD.Vector(-x/2, -y/2, -z/2)
            fp.Shape = translate(box, base)
            fp.Placement = currPlacement
        if hasattr(fp, 'scale'):
            super().scale(fp)
edwilliams16
Some operations turn flat faces into B-Spline Objects. It depends on the history of your objects...
The idea of intersecting thickened faces appears to work. It would take a little effort to code it. Draft|Downgrade to make faces. Then Part|3DOffset to thicken them and then Part|Boolean Common. The latter works fine on solids, but not on the original faces, for presumably numerical reasons. Another Draft|Downgrade could make the common surface.
The example is a Cube partially intersecting a cylinder.
Screen Shot 2022-06-27 at 10.56.30 AM.png (31.31 KiB) Viewed 1150 times
Screen Shot 2022-06-27 at 11.07.08 AM.png (28.66 KiB) Viewed 1150 times
commonfacevia3DOffset.FCStd
(20.72 KiB) Downloaded 28 times
keithsloan52
edwilliams16 wrote: Mon Jun 27, 2022 9:10 pm Some operations turn flat faces into B-Spline Objects. It depends on the history of your objects...
Screen Shot 2022-06-27 at 10.56.30 AM.pngScreen Shot 2022-06-27 at 11.07.08 AM.png
Sorry don't like that solution at all, will carry on trying to find a solution,
edwilliams16
keithsloan52 wrote: Tue Jun 28, 2022 1:08 am
Let us know what you find, that will work in general.
keithsloan52
So how would one check if a B-Spline Surface is Flat?
edwilliams16
keithsloan52 wrote: Tue Jun 28, 2022 6:52 am So how would one check if a B-Spline Surface is Flat?
@Chris_G is most likely to know.
What's the plan if it isn't flat?
keithsloan52
edwilliams16 wrote: Tue Jun 28, 2022 5:18 pm
If both Faces are Flat check for coplaner(?) same Plane
If both Faces are Curved somehow check if they are both part of the same curved surface. i.e. the same or the smaller one would be part of the larger.
edwilliams16
keithsloan52 wrote: Tue Jun 28, 2022 5:38 pm
So, given a method powerful enough to match curved surfaces, surely it could handle flat ones?
Given that even flat surfaces can end up being described by B-Splines, the method has to handle them. Then there's no need to test if they are actually flat, or actually cylindrical, or actually spherical or any other special case.
