Question: how to adapt "Property editor" width to new property names (Combo View)
onekk
Post by onekk »
Hello, I'm in need to resize "property editor" to adapt the "property" column to new "property names" created in a Feature Python Object (FPO).
We are speaking of this:
https://wiki.freecadweb.org/Property_editor
There is a way to adapt the size of "property editor" first column to adapt it to content added by a FPO?
I'm speaking about first column that contains the "Property Name".
I think that I could probably obtain the ComboView using this code:
import PySide2
import FreeCADGui
mw = FreeCADGui.getMainWindow()
cb = mw.findChild(PySide2.QtCore.QObject, "Combo View")
What I have found
Combo View widgets is made in this way:
<PySide2.QtWidgets.QDockWidget(0x5591a73daf00, name="Combo View") at 0x7fcad3269800>
16:06:43  <PySide2.QtWidgets.QWidget(0x5591a3dda1a0, name="Combo View") at 0x7fcad0343340>
16:06:43  [<PySide2.QtWidgets.QGridLayout(0x5591a3d6cd50) at 0x7fcad03307c0>, <PySide2.QtWidgets.QTabWidget(0x5591a3d6ef40, name="combiTab") at 0x7fcad0330800>]
So seems that there is :
- a QDockWidget named "Combo View" that I suppose is a sort of container
- among his children there are anothe widget named again "Combo View" specified as QtWidget, probably another container
- this container contains a QTabWidget named "combiTab"
So I suppose I have to operate on "combiTab" finding a way to resize the "first column".
I'm lost in the nidification.
I want to use it on a 0.19.3 version (It is only that I have this version installed), if possible.
If not possible on 0.19.3, even some hints for 0.20 will be appreciated.
Any hints will be appreciated.
TIA and Regards
Carlo D.
OS: Artix Linux (openbox)
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Edited to clarify the request and title changed to be more precise (I hope)
Edited II change title to make more clear that is a question, some minor English corrections, new code added to shorten thread.
- Various other stuffs.
onekk
Re: Question: how to adapt "Property editor" widht to new property names (Combo View)
Post by onekk »
I have edited first post to joint the new infos found.
Sorry for the mess.
Regards
Carlo D.
onekk
Post by onekk »
No hints?
I have done a search in the source tree using a grep for combiTab but sadly no luck.
@wmayer Please, do you have some hints?
wmayer wrote:
Sorry but I think you are the one that could help or give an authoritative answer.
Regards
Carlo D.
Founder
Re: Question: how to adapt "Property editor" width to new property names (Combo View)
Post by wmayer »
from PySide2 import QtWidgets
mw = Gui.getMainWindow()
tab = mw.findChild(QtWidgets.QTabWidget, "combiTab")
tab = tab.findChild(QtWidgets.QTabWidget, "propertyTab")
# Has two tree views
tree = tab.findChildren(QtWidgets.QTreeView)[1]
tree.resizeColumnToContents(0)
onekk
Post by onekk »
wmayer wrote: Wed Jun 29, 2022 11:38 am
Many thanks for the reply, I was lost.
I have a FeaturePython Object and the code is made to resize the property Tab based on on a property change.
I have a property Type that will add or delete the properties of the object based on his value.
I want the "Property column" to be adapted when I modify these properties.
I have tried to add them to onChanged() and in execute() and resizing seems not to be taken in account.
If I put the code in a python file, load it in "FC internal editor" and run the code resizing is taken in account.
What I'm doing wrong?
I have placed the code in a function (method) as follow:
    def resize_property_tab(self):
        """Adapt Property Column of Data Tab to content."""
        c_tab = mw.findChild(QtWidgets.QTabWidget, "combiTab")
        p_tab = c_tab.findChild(QtWidgets.QTabWidget, "propertyTab")
        tree = p_tab.findChildren(QtWidgets.QTreeView)[1]
        # print("resized")
And the code seems to be executed as "resized" is printed on the "Report View".
TIA and Regards.
Carlo D.
Founder
Post by wmayer »
I don't think this is a suitable place to add the code there. A better way is to implement your own DocumentObserver and implement the function slotAppendDynamicProperty.
from PySide2 import QtCore
class MyDocObserver:
    def __init__(self, tree):
        self.tree = tree
    def resizeColumnToContents(self):
        self.tree.resizeColumnToContents(0)
    def slotAppendDynamicProperty(self, obj, prop):
        print ("Call slotAppendDynamicProperty")
        QtCore.QTimer.singleShot(200, self.resizeColumnToContents)
doc_observer = MyDocObserver(tree)
App.addDocumentObserver(doc_observer)
obj = App.ActiveDocument.addObject("App::FeaturePython", "Object")
# Select the object before running the next line
obj.addProperty("App::PropertyString", "Averyveryveryveryveryveryveryveryverylongpropertyname")
Hint: The property editor will only adjust its column width if the object is selected while adding the new property.
thyssentishman
Post by thyssentishman »
onekk wrote: Wed Jun 29, 2022 2:50 pm I have a FeaturePython Object and the code is made to resize the property Tab based on on a property change.
Hi @onekk,
I managed to get something close to what you might want. I found two solutions for which I wrote two scripts.
Solution 1 (Hacky):
The header of the QTreeView from the PropertiesView has by default the interactive ResizeMode (QtWidgets.QHeaderView.Interactive). However there is also the QtWidgets.QHeaderView.ResizeToContents resize mode.
The clear disadvantage of using the latter is of course that you won't be able to resize the header columns anymore. A hacky (IMO) workaround would be to change to the ResizeToContents mode when your Type property is changed and after the columns have been resized to fit the content of the new properties, switch back to the Interactive mode. For the switch back to happen however, the document must be recomputed.
I did this by changing to the ResizeToContents mode inside the onChange() function and then switch back to the Interactive mode inside the execute() function.
Here is the example:
And here is the script:
ResizeToFit1.FCMacro
(2.68 KiB) Downloaded 17 times
Solution 2:
As @wmayer shared, you can use QtWidgets.QTreeView.resizeColumnToContents(column) to resize specific columns. I used this method by calling your resize_property_tab function inside execute(). However when you change your Type property the changes will not be immediately visible. A document recompute has to occur first.
ResizeToFit2.FCMacro
(2.5 KiB) Downloaded 15 times
I hope this helps. I'm sure there must be a better way but I thought that this could be enough for your purposes.
Kind regards,
Johannes
onekk
Post by onekk »
wmayer wrote: Thu Jun 30, 2022 12:49 pm
Many Thanks, I will experiment some more.
I have some question, if I could abuse of your kindness:
1) What is the scope of a "Document Observer"
2) In my "application" when I modify "Type" Property the Object is not selected "by default"
3) When I create a new object it is not selected by default
Regards
Carlo D.
onekk
Post by onekk »
thyssentishman wrote: Thu Jun 30, 2022 1:02 pm ...
Kind regards,
Johannes
Yes it helps at least to have some code to experiment with, and to know better the working of the FC interface.
Let me analyze various options and decide what implement.
Many many thanks.
Carlo D.
onekk
Post by onekk »
wmayer wrote: Thu Jun 30, 2022 12:49 pm ...
Thanks the code seems to work, but I note a strange behaviour:
When I activate Wb and open a file, the Property column is not adapting to the contents like in stock behaviour.
If I select an object it will correctly resize, it seems that "document Observer" is working adapting column 0 size as "debug" print statement:
If I change Type property, first column is resized correctly.
Let me know if I my explaining is not giving you correct informations:
I'm testing on:
Qt version: 5.12.9
OCC version: 7.5.3
EDIT:
The problem above is shown in the WB with "Customs FPO" in a saved FCStd file.
Strangely with this simple test code problem is not shown, I'm puzzled.
Fpobj.py
(6.01 KiB) Downloaded 10 times
End Edit
TIA and Regards
Carlo D.
