how to change SubShapeBinder Support with python (in a Part container)
easyw-fc
Post by easyw-fc »
how could I change SubShapeBinder Support with python (in a Part container)?
I have an object contained in a Part which is contained in a second Part container.
I would like to assign to an existing SubShapeBinder to this object selecting the SubShapeBinder and the object itself, and then launching a python command.
What I miss is the way to assign the right 'full parent name' to SubShapeBinder... like in the sample 'Part.Part001.Box.'
Here a code which gives me the wrong Support
import FreeCAD, FreeCADGui
sel=FreeCADGui.Selection.getSelection()
binder=sel[0]
obj2link = sel[1]
binder.Support = [obj2link]
I would need to get 'Part.Part001.Box.' from the Selection python code...
thanx in advance
SubShapeBinder-test.FCStd
(9.86 KiB) Downloaded 11 times
Roy_043
Re: how to change SubShapeBinder Support with python (in a Part container)
Post by Roy_043 »
sel = FreeCADGui.Selection.getSelectionEx("", 0)
s = sel[0]
Print(s.SubElementNames)
Print(s.Object)
easyw-fc
Post by easyw-fc »
Roy_043 wrote: Sat Jun 25, 2022 4:32 pm ping
many thanks :D
