GroupPython Not Exporting in STL
Vasten
Post by Vasten »
I created my own DocumentObjectGroupPython fine, having custom icons is great
when i select it in tree view it highlights all of its object green as normal for any group or container
but when i export to step or stl the file is empty
if a select the internal objects they export fine
is there something i need to add to my container to make the export feature work
I plan to have these in a hierarchy to clean up tree display
but it kind of defeats the point if every time i want to export i have to go through the whole tree and select the object of every group manually
EDIT:
I just tried fusing something with the group and it said "input shape is null"
so i think can understand why it would not export.. the group object itself doesn't have a shape
makes sense
but if i put this group inside a tree, when i select a higher level up it wont select every object in the group, only the group
there must be a way to group things like this in a hierarchy...only need to select the top of the hierarchy... and be able to export
what am i missing? I'm guessing its something simple
Vasten
Re: GroupPython Not Exporting in STL
Post by Vasten »
Update:
did a quick test
I tried adding a Part::PropertyPartShape called Shape to the Group and then setting that to be the Shape of an existing Box
Still nothing
Buyt my FeaturePython objects all export fine
Is there a way to create a FeaturePython Object that can have children just like a Group object? in that case I could just fuse everything and set the Feature Python object Shape
OS: Windows 10 Version 2009
Version: 2022.430.28641 (Git)
Branch: LinkStage3
Hash: a77045488092c24ece25d63c91f362cbd2181d36
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Vasten
Post by Vasten »
god
hours of playing and I just found it
export mode was set to disabled.. god i feel stupid.. i didnt know there was a flag just for this
Seems a bit odd that it defaults to disabled lol
onekk
Post by onekk »
Vasten wrote: Sun Jun 26, 2022 10:22 am ...
You are using from your FC info a linkstage3 version that could be different from "stock FC" , as due to many difference in source RealThunder sync it from time to time to the "stock FC" sources.
This problem could affect or not affect "stock FC" code, so good to have it also here, but there is a dedicated section for LS3.
https://forum.freecadweb.org/viewforum.php?f=44
Probably posting there will gave you more feedback from LS3 users, or maybe referring directly to RT github pages and making an "Issue" could lead to a "future PR" that will solve this "glitch".
Hope it helps.
Regards
Carlo D.
- Various other stuffs.
