Get all Shells/Faces/Edges/Vertices at a particular point in 3D space
mntruell
Post by mntruell »
Using Python, is there a way to look up all objects (shells/faces/edges/vertices) in a body that intersect with a particular point in 3D space?
For example, imagine my body is a cube occupying [0, 1]x[0, 1]x[0, 1]. Given the point (0, 0, 0.5), I'd like to get the Python edge from (0, 0, 0) to (0, 0, 1). Given the point (0, 0.5, 0.5), I'd like to get the face on the YZ-plane in Python.
Roy_043
Re: Get all Shells/Faces/Edges/Vertices at a particular point in 3D space
Post by Roy_043 »
doc = App.ActiveDocument
box = doc.addObject("Part::Box", "Box")
doc.recompute()
point = App.Vector(5, 0, 5)
distance, points, info = box.Shape.distToShape(Part.Vertex(point))
print(info)
mntruell
Post by mntruell »
What is the structure of info?
Roy_043
Post by Roy_043 »
[('Face', 2, (5.0, 5.0), 'Vertex', 0, None)]:
'Face' = subelement
2 = index of subelement (zero-based)
(5.0, 5.0) = (u, v) parameters of the point.
mntruell
Post by mntruell »
Fantastic. Thank you!
mntruell
Post by mntruell »
How do I evaluate the subelement at the supplied parameters?
edwilliams16
Post by edwilliams16 »
face = box.Shape.Faces[2]
print(face.valueAt(5,5)) #-> Vector (5.0, 0.0, 5.0)
face.Surface.normal(5,5)# normal at location etc.
mntruell
Post by mntruell »
How do I transform the result of valueAt into a correct 3D point? I'm trying to use it to produce a point cloud of a BREP, but it is giving incorrect results.
onekk
Post by onekk »
mntruell wrote: Mon Jul 04, 2022 2:32 am How do I transform the result of valueAt into a correct 3D point? I'm trying to use it to produce a point cloud of a BREP, but it is giving incorrect results.
valeAt is returning a Vector() and usually a Vector() will suffice to feed many methods that uses "3d Points" like lines and other entities. In other word where you have to use the returned info?
Regards
Carlo D.
- Various other stuffs.
