[Solved] App::FeaturePython Selectable property
Hi all,
I've noticed that an object of type Part::Feature has a Selectable (bool) property but App::FeaturePython doesn't. I need this to prevent the scripted object from being highlighted when selected in the tree.
Is there a way to implement this property manually?
Thank you.
Thank you.
Last edited by thyssentishman on Wed Jun 29, 2022 2:21 pm, edited 1 time in total.
Re: App::FeaturePython Selectable property
https://wiki.freecadweb.org/Propertyrvq wrote: ↑Mon Jun 27, 2022 1:36 pm Hi all,
Thank you.
Selectable is in View properties so you could modify using obj.ViewObject.Selectable property
Nevertheless, View properties can also be assigned using the view provider object's addProperty() method.
I have not checked, but as what is you see in the TreeView is managed by Coin and Coin is responsible of View properties, probably they are in the "View" Tab.
EDIT: Modified the text to be more precise after a couple of tests.
Hope it helps.
Carlo D.
- Various other stuffs.
Thank you @onekk,
I couldn't find the definition of this property but for the Part::Feature in the source code.
I know that properties can be added to the ViewProvider, however I don't know how to code the functionality to make the tree object Selectable or not.
I have simply ported the example code in the page linked.
As Selectable is a standard property in the "View Tab" if you want to make a FPO not selectable, you could simply to put in the execute():
obj.ViewObject.Selectable = False
Edit: hoping now it is more clear, I apologize.
Hope it helps
Regards
I think Selectable is a standard property only for Part::Feature but not for App::FeaturePython.
If I enter the following:
obj = FreeCAD.ActiveDocument.addObject("App::FeaturePython","myObj")
AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'Selectable'
OS: KDE Flatpak runtime (pop:GNOME/pop)
Version: 0.20.29177 (Git)
Python 3.9.9, Qt 5.15.4, Coin 4.0.0, Vtk 8.2.0, OCC 7.6.2
I'm a beginner at FeaturePython, but if I create a point this way, with the default ViewProvider, I get Selectable in the View Properties
class Point:
def __init__(self, obj, loc):
''' Point location '''
obj.addProperty("App::PropertyVector","Location","Point","Location")
obj.Location = loc
obj.addExtension('Part::AttachExtensionPython')
obj.Proxy = self
def execute(self, obj):
obj.Shape = Part.Point(obj.Location).toShape()
obj.positionBySupport() #add attachment
def makePoint(loc = FreeCAD.Vector(0, 0, 0)):
doc=FreeCAD.ActiveDocument
a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Point")
Point(a, loc)
a.ViewObject.Proxy=0 # just set it to something different from None
doc.recompute()
return a
doc = App.ActiveDocument
p = makePoint(FreeCAD.Vector(10,10,10))
p.ViewObject.PointSize = 6
- Screen Shot 2022-06-27 at 11.41.25 AM.png (46.79 KiB) Viewed 806 times
I believe it's because you are using Part:FeaturePython and I am using App:FeaturePython. What is the difference? Also when I change App for Part, the Selectable property shows up and the tree item as well, but the object won't show in the 3D view anymore.edwilliams16 wrote: ↑Mon Jun 27, 2022 9:47 pm I'm a beginner at FeaturePython, but if I create a point this way, with the default ViewProvider, I get Selectable in the View Properties
In the wiki example here the former is used and here the latter.
first link is for ViewProvider,
second is for FPO scripted objects
Sorry I have not noted the different between App::FeaturePython and Part::FeaturePython I was referring to the latter.
Let me analyze the App::FeaturePython object.
Edit:
From the wiki page:
From this comment and from the little I know of FC, I have two questions:If the desired object should have a placement, a shape, an attachment or other complex properties, it is better to create one of the more complex classes, for example, App GeoFeature, Part Feature, or Part Part2DObject.
Why you have to make an App::FeaturePython?
What are you trying to achieve?
End Edit
Regards
Carlo D.
I am working on the blender-like grid created by @Chris_G from this thread.
As discussed in that thread when the Grid object is selected in the tree, it is highlighted (which makes it obtrusive in the 3D view).
The same applies for the selection of the object in the 3D View which can be avoided using the following:
# Make grid unselectable in the 3D View
self.pick = coin.SoPickStyle()
self.pick.style.setValue(coin.SoPickStyle.UNPICKABLE)
Here is the code that @Chris_G provided:
import FreeCAD
import FreeCADGui
import math
from pivy import coin
class gridNode(coin.SoSeparator):
def __init__(self):
super(gridNode, self).__init__()
self.vec = coin.SoTransformVec3f()
#self.vec.matrix.connectFrom(cam.orientation)
self.vec.vector = coin.SbVec3f(0,0,-1)
self.calc = coin.SoCalculator()
self.calc.A.connectFrom(self.vec.direction)
self.calc.expression.set1Value(0,"ta=0.5") # maxviz
self.calc.expression.set1Value(1,"tb=20.0") # factor
self.calc.expression.set1Value(2,"tA=vec3f(1,0,0)") # plane normal
self.calc.expression.set1Value(3,"tc=dot(A,tA)")
self.calc.expression.set1Value(4,"td=fabs(tc)")
self.calc.expression.set1Value(5,"oa=1.0-ta*pow(td,tb)")
self.calc.expression.set1Value(6,"oA=vec3f(oa,0,0)")
self.scaleEngine = coin.SoCalculator()
#self.scaleEngine.a.connectFrom(cam.height)
self.scaleEngine.expression.set1Value(0,"ta=floor(log10(a/10))")
self.scaleEngine.expression.set1Value(1,"tb=pow(10,ta)")
self.scaleEngine.expression.set1Value(2,"oA=vec3f(tb,tb,tb)")
self.scaleEngine.expression.set1Value(3,"oa=0.01*a/tb")
self.calc2 = coin.SoCalculator()
self.calc2.a.connectFrom(self.scaleEngine.oa)
self.calc2.b.connectFrom(self.calc.oa)
self.calc2.expression.set1Value(0,"ta=pow(a,0.3)")
self.calc2.expression.set1Value(1,"oa=(b>ta)?b:ta")
self.material1 = coin.SoMaterial()
self.material2 = coin.SoMaterial()
self.material3 = coin.SoMaterial()
self.material4 = coin.SoMaterial()
self.coord = coin.SoCoordinate3()
self.coord2= coin.SoCoordinate3()
self.line1 = coin.SoIndexedLineSet()
self.line2 = coin.SoIndexedLineSet()
self.lineSet = coin.SoIndexedLineSet()
self.lineSet2= coin.SoIndexedLineSet()
self.miniscale = coin.SoScale()
self.miniscale.scaleFactor = coin.SbVec3f(0.1,0.1,0.1)
self.mainscale = coin.SoScale()
self.mainscale.scaleFactor.connectFrom(self.scaleEngine.oA)
self.addChild(self.mainscale)
self.addChild(self.coord)
self.addChild(self.material1)
self.addChild(self.line1)
self.addChild(self.material2)
self.addChild(self.line2)
self.addChild(self.material3)
self.addChild(self.lineSet)
self.addChild(self.miniscale)
self.addChild(self.material4)
self.addChild(self.coord2)
self.addChild(self.lineSet2)
self._vector1 = coin.SbVec3f(1,0,0)
self._vector2 = coin.SbVec3f(0,1,0)
self.normal = self._vector1.cross(self._vector2)
self._mainDim = 100
self._subDim = 10
self._maxviz = 1.0
self._factor = 1.0
self._numGridLines = 4
self.material1.diffuseColor = coin.SbColor(1,0,0)
self.material2.diffuseColor = coin.SbColor(0,1,0)
self.material3.diffuseColor = coin.SbColor(0.5,0.5,0.5)
self.material4.diffuseColor = coin.SbColor(0.5,0.5,0.5)
self.material3.transparency.connectFrom(self.calc.oa)
self.material4.transparency.connectFrom(self.calc2.oa)
@property
def transparency(self):
return self.material3.transparency.getValues()[0]
@transparency.setter
def transparency(self, tr):
# self.material3.transparency = tr
# self.material2.transparency = tr
@property
def vector1color(self):
return self.material1.diffuseColor.getValues()[0].getValue()
@vector1color.setter
def vector1color(self, color):
self.material1.diffuseColor = (color[0], color[1], color[2])
@property
def vector2color(self):
return self.material2.diffuseColor.getValues()[0].getValue()
@vector2color.setter
def vector2color(self, color):
self.material2.diffuseColor = (color[0], color[1], color[2])
@property
def gridcolor(self):
return self.material3.diffuseColor.getValues()[0].getValue()
@gridcolor.setter
def gridcolor(self, color):
self.material3.diffuseColor = (color[0], color[1], color[2])
self.material4.diffuseColor = (color[0], color[1], color[2])
@property
def vector1dir(self):
return self._vector1.getValue()
@vector1dir.setter
def vector1dir(self, vec):
self._vector1 = coin.SbVec3f(vec)
self.calc.expression.set1Value(2,"tA=vec3f(%f,%f,%f)"%(self.normal.getValue()[0],self.normal.getValue()[1],self.normal.getValue()[2]))
self.buildGrid()
@property
def vector2dir(self):
return self._vector2.getValue()
@vector2dir.setter
def vector2dir(self, vec):
self._vector2 = coin.SbVec3f(vec)
self.buildGrid()
@property
def mainDim(self):
return self._mainDim
@mainDim.setter
def mainDim(self, n):
self._mainDim = n
self.buildGrid()
@property
def subDim(self):
return self._subDim
@subDim.setter
def subDim(self, n):
self._subDim = n
self.buildGrid()
@property
def maxviz(self):
return self._maxviz
@maxviz.setter
def maxviz(self, n):
self._maxviz = n
self.calc.expression.set1Value(0,"ta=%f"%n) # maxviz
@property
def factor(self):
return self._factor
@factor.setter
def factor(self, n):
self._factor = n
self.calc.expression.set1Value(1,"tb=%f"%n) # factor
def linkTo(self, cam):
def updateTransformedNormal(self):
# // First get hold of an SoPath through the scenegraph down to the
# // node ("mynode") you want to query about its current world space
# // transformation(s).
# SoSearchAction * searchaction = new SoSearchAction;
# searchaction->setNode(mynode);
# searchaction->apply(myscenegraphroot);
# SoPath * path = searchaction->getPath();
# assert(path != NULL);
# // Then apply the SoGetMatrixAction to get the full transformation
# // matrix from world space.
# const SbViewportRegion vpr = myviewer->getViewportRegion();
# SoGetMatrixAction * getmatrixaction = new SoGetMatrixAction(vpr);
# getmatrixaction->apply(path);
# SbMatrix transformation = getmatrixaction->getMatrix();
# // And if you want to access the individual transformation
# // components of the matrix:
# SbVec3f translation;
# SbRotation rotation;
# SbVec3f scalevector;
# SbRotation scaleorientation;
# transformation.getTransform(translation, rotation, scalevector, scaleorientation);
searchaction = coin.SoSearchAction()
searchaction.setNode(self)
searchaction.apply(FreeCADGui.ActiveDocument.ActiveView.getSceneGraph())
path = searchaction.getPath()
vpr = FreeCADGui.ActiveDocument.ActiveView.getViewer().getViewportRegion()
getmatrixaction = coin.SoGetMatrixAction(vpr)
getmatrixaction.apply(path)
transformation = getmatrixaction.getMatrix()
self.transformedNormal = transformation.multVecMatrix(self.normal)
self.calc.expression.set1Value(2,"tA=vec3f(%f,%f,%f)"%(self.transformedNormal.getValue()[0],self.transformedNormal.getValue()[1],self.transformedNormal.getValue()[2]))
return()
def gridPts(self, t, s):
n = t*s
r = []
nr = []
for i in range(1,n):
r.append( 1.0 * self._subDim * i)
nr.append(-1.0 * self._subDim * i)
r.append( self._mainDim)
nr.append(-self._mainDim)
nr.reverse()
fullRange = nr + r
pts = []
for i in fullRange:
pts.append(1*i * self._vector2 - s*self._mainDim * self._vector1)
pts.append(1*i * self._vector2 + s*self._mainDim * self._vector1)
pts.append(1*i * self._vector1 - s*self._mainDim * self._vector2)
pts.append(1*i * self._vector1 + s*self._mainDim * self._vector2)
return(pts)
def buildGrid(self):
n = int(1.0 * self._mainDim / self._subDim)
pts = []
pts.append(-self._mainDim * self._vector1)
pts.append( self._mainDim * self._vector1)
pts.append(-self._mainDim * self._vector2)
pts.append( self._mainDim * self._vector2)
pts += self.gridPts(n,1)
self.coord.point.setValues(0,len(pts),pts)
self._numGridLines = len(pts) / 2.0
pts2 = self.gridPts(n,10)
self.coord2.point.setValues(0,len(pts2),pts2)
#self._numGridLines = len(pts) / 2.0
a = []
l = len(pts)-4
for i in range(int(l/2)):
a.append(2*i + 4)
a.append(2*i + 5)
a.append(-1)
self.line1.coordIndex.setValue(0)
self.line1.coordIndex.setValues(0, 3, [0,1,-1])
self.line2.coordIndex.setValue(0)
self.line2.coordIndex.setValues(0, 3, [2,3,-1])
self.lineSet.coordIndex.setValue(0)
self.lineSet.coordIndex.setValues(0, len(a), a)
a2 = []
l = len(pts2)
a2.append(2*i)
a2.append(2*i + 1)
a2.append(-1)
self.lineSet2.coordIndex.setValue(0)
self.lineSet2.coordIndex.setValues(0, len(a2), a2)
class gridObject:
def __init__(self, obj):
obj.Proxy = self
obj.addProperty("App::PropertyPlacement", "Placement", "Base", "Placement")
return()
def onChanged(self, fp, prop):
if prop == 'Placement':
FreeCAD.Console.PrintMessage('Placement udpate\n')
tr = fp.Placement.Base
ro = fp.Placement.Rotation.Q
fp.ViewObject.Proxy.trans.translation = coin.SbVec3f(tr.x,tr.y,tr.z)
fp.ViewObject.Proxy.trans.rotation = coin.SbRotation(ro[0],ro[1],ro[2],ro[3])
class gridVP:
def __init__(self, obj ):
obj.addProperty("App::PropertyDistance", "Total", "Size", "Size of a grid quadrant").Total = '100mm'
obj.addProperty("App::PropertyDistance", "Subdivision", "Size", "Size of subdivisions").Subdivision = '10mm'
obj.addProperty("App::PropertyFloat", "XY_Attenuation", "View", "XY plane attenuation").XY_Attenuation = 2.0
obj.addProperty("App::PropertyFloat", "XZ_Attenuation", "View", "XZ plane attenuation").XZ_Attenuation = 50.0
obj.addProperty("App::PropertyFloat", "YZ_Attenuation", "View", "YZ plane attenuation").YZ_Attenuation = 50.0
obj.addProperty("App::PropertyFloat", "XY_Visibility", "View", "XY plane max visibility").XY_Visibility = 1.0
obj.addProperty("App::PropertyFloat", "XZ_Visibility", "View", "XZ plane max visibility").XZ_Visibility = 0.5
obj.addProperty("App::PropertyFloat", "YZ_Visibility", "View", "YZ plane max visibility").YZ_Visibility = 0.5
obj.addProperty("App::PropertyColor", "GridColor", "Color", "Grid Color").GridColor = (0.5,0.5,0.5)
obj.Proxy = self
def attach(self, obj):
self.trans = coin.SoTransform()
self.xy = gridNode()
self.xy.vector1dir = (1,0,0)
self.xy.vector1color = (0.827,0.149,0.149) # red (X)
self.xy.vector2dir = (0,1,0)
self.xy.vector2color = (0.400,0.590,0.200) # green (Y)
self.xy.mainDim = 100
self.xy.subDim = 10
self.xy.maxviz = 1.0
self.xz = gridNode()
self.xz.vector1dir = (1,0,0)
self.xz.vector1color = (0.827,0.149,0.149) # red (X)
self.xz.vector2dir = (0,0,1)
self.xz.vector2color = (0.133,0.490,0.882) # blue (Z)
self.xz.mainDim = 100
self.xz.subDim = 10
self.xz.maxviz = 0.5
self.yz = gridNode()
self.yz.vector1dir = (0,1,0)
self.yz.vector1color = (0.400,0.590,0.200) # green (Y)
self.yz.vector2dir = (0,0,1)
self.yz.vector2color = (0.133,0.490,0.882) # blue (Z)
self.yz.mainDim = 100
self.yz.subDim = 10
self.yz.maxviz = 0.5
self.sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
self.cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
self.xy.linkTo(self.cam)
self.xy.factor = 1.
self.xz.linkTo(self.cam)
self.xz.factor = 50.
self.yz.linkTo(self.cam)
self.yz.factor = 50.
self.grid = coin.SoGroup()
self.grid.addChild(self.trans)
self.grid.addChild(self.xy)
self.grid.addChild(self.xz)
self.grid.addChild(self.yz)
obj.addDisplayMode(self.grid,"Wireframe")
self.ViewObject = obj
self.Object = obj.Object
# def updateCam(self):
# self.cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
# self.xy.linkTo(self.cam)
# self.xz.linkTo(self.cam)
# self.yz.linkTo(self.cam)
def getIcon(self):
return (":/icons/Draft_Grid.svg")
def getDisplayModes(self,obj):
"Return a list of display modes."
modes=[]
modes.append("Wireframe")
return modes
def getDefaultDisplayMode(self):
"Return the name of the default display mode. It must be defined in getDisplayModes."
return "Wireframe"
def setDisplayMode(self,mode):
return mode
def onChanged(self, vp, prop):
self.updateCam()
if prop == 'Total':
if float(vp.Total) >= float(vp.Subdivision):
self.xy.mainDim = float(vp.Total)
self.xz.mainDim = float(vp.Total)
self.yz.mainDim = float(vp.Total)
else:
vp.Total = vp.Subdivision
if prop == 'Subdivision':
self.xy.subDim = float(vp.Subdivision)
self.xz.subDim = float(vp.Subdivision)
self.yz.subDim = float(vp.Subdivision)
else:
vp.Subdivision = vp.Total
if prop == 'XY_Attenuation':
if vp.XY_Attenuation < 0.1:
vp.XY_Attenuation = 0.1
elif vp.XY_Attenuation > 100:
vp.XY_Attenuation = 100
self.xy.factor = vp.XY_Attenuation
if prop == 'XZ_Attenuation':
if vp.XZ_Attenuation < 0.1:
vp.XZ_Attenuation = 0.1
elif vp.XZ_Attenuation > 100:
vp.XZ_Attenuation = 100
self.xz.factor = vp.XZ_Attenuation
if prop == 'YZ_Attenuation':
if vp.YZ_Attenuation < 0.1:
vp.YZ_Attenuation = 0.1
elif vp.YZ_Attenuation > 100:
vp.YZ_Attenuation = 100
self.yz.factor = vp.YZ_Attenuation
if prop == 'XY_Visibility':
if vp.XY_Visibility < 0.0:
vp.XY_Visibility = 0.0
elif vp.XY_Visibility > 1.0:
vp.XY_Visibility = 1.0
self.xy.maxviz = vp.XY_Visibility
if prop == 'XZ_Visibility':
if vp.XZ_Visibility < 0.0:
vp.XZ_Visibility = 0.0
elif vp.XZ_Visibility > 1.0:
vp.XZ_Visibility = 1.0
self.xz.maxviz = vp.XZ_Visibility
if prop == 'YZ_Visibility':
if vp.YZ_Visibility < 0.0:
vp.YZ_Visibility = 0.0
elif vp.YZ_Visibility > 1.0:
vp.YZ_Visibility = 1.0
self.yz.maxviz = vp.YZ_Visibility
if prop == 'GridColor':
self.xy.gridcolor = vp.GridColor
self.xz.gridcolor = vp.GridColor
self.yz.gridcolor = vp.GridColor
tr = vp.Object.Placement.Base
ro = vp.Object.Placement.Rotation.Q
self.trans.translation = coin.SbVec3f(tr.x,tr.y,tr.z)
self.trans.rotation = coin.SbRotation(ro[0],ro[1],ro[2],ro[3])
self.xy.updateTransformedNormal()
self.xz.updateTransformedNormal()
self.yz.updateTransformedNormal()
def onDelete(self, feature, subelements):
self.sg.removeChild(self.grid)
return(True)
def main():
obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","Grid")
gridObject(obj)
gridVP(obj.ViewObject)
if __name__ == '__main__':
main()
Not optimal, as it is not visible, in tree.
But if you assign it to a toggle button, it could work?
Hope it helps
Regards
Carlo D.
def main():
gridObject(obj)
obj.ViewObject.ShowInTree = False
Regards
Carlo D.
