Unit mismatch error in FreeCAD 0.20
Zoltan
Post by Zoltan »
I encountered a strange error in FreeCAD 0.20.
Assume that you have four points (Draft.Point objects), labelled as P1, P2, P3 and P4, with units in mm. I have an expression in the form of a Python string to evaluate, let us call it expression. To evaluate this expression, we can use
P1.evalExpression(expression)
This provides the correct value in FreeCAD 0.19, but not in FreeCAD 0.20 (git hash 68e3376), the latter throwing an exception:
ArithmeticError: Quantity::operator +(): Unit mismatch in plus operation
What makes the situation stranger is that when I run my script containing this expression using the PyCharm IDE (the Python interpreter coming from the extracted AppImage), I do not get this error.
Do you have any ideas why this happens and how I could further narrow down the cause of the error?
The error can be reproduced with the code below.
import FreeCAD as App
import Draft
P1 = Draft.make_point(App.Vector(-74.924, 2.875, 160.36))
P1.Label = 'P1'
P2 = Draft.make_point(App.Vector(-10.965, 11.594, 160.36))
P2.Label = 'P2'
P3 = Draft.make_point(App.Vector(-7.391, -50.421, 160.36))
P3.Label = 'P3'
P4 = Draft.make_point(App.Vector(54.302, 5.066, 160.36))
P4.Label = 'P4'
expression = 'P3.X + (-10)*-(((P3.Y + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Y) - (P3.Y)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Y)) / sqrt(((P3.X + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.X) - (P3.X)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.X))^2 + ((P3.Y + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Y) - (P3.Y)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Y))^2 + ((P3.Z + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Z) - (P3.Z)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Z))^2))'
openBrain
Re: Unit mismatch error in FreeCAD 0.20
Post by openBrain »
Maybe you could evaluate each parenthesis content by descending hierarchical order...
onekk
Post by onekk »
Zoltan wrote: Wed Jun 29, 2022 3:56 pm
Probably it is happening has you has no units in the multipliers:
try:
print(P1.X)
expr1 = 'P3.X + -10 mm'
expr2 = ""
# expr2 = ' * -(((P3.Y + 1.5 * (sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Y) - (P3.Y)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Y)) / sqrt(((P3.X + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.X) - (P3.X)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.X))^2 + ((P3.Y + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Y) - (P3.Y)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Y))^2 + ((P3.Z + 1.5*(sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2))*((P1.Z) - (P3.Z)) / sqrt(((P1.X) - (P3.X))^2 + ((P1.Y) - (P3.Y))^2 + ((P1.Z) - (P3.Z))^2)) - (P3.Z))^2))'
expression = expr1 + expr2
You will easily see that P1.X will return units, and 10 has no units in your code, in my test code it will print correctly
So the error has some sense!
But probably expression should allow "unitless" operators?
Regards
Carlo D.
Edit: some conceptual error it was not a multiplier but addend.
- Various other stuffs.
TheMarkster
Post by TheMarkster »
import math
>>> P1.Y
2.875 mm
>>> math.sqrt(P1.Y)
1.695582495781317
>>> math.sqrt(P1.Y)+P1.Y
Zoltan
Post by Zoltan »
TheMarkster wrote: Wed Jun 29, 2022 5:24 pm import math
>>> P1.Y
2.875 mm
>>> math.sqrt(P1.Y)
1.695582495781317
This is indeed the problem. Your code worked in FreeCAD 0.19, so I guess there was implicit conversion for the units. On the other hand, the sqrt function in the Expression Engine may propagate the units as opposed to math.sqrt, which removes the unit as you demonstrated. So I am still puzzled.
Zoltan
Post by Zoltan »
onekk wrote: Wed Jun 29, 2022 5:19 pm You will easily see that P1.X will return units, and 10 has no units in your code, in my test code it will print correctly
Thank you, Carlo! You found the error.
Here is the summary:
  • Additive operators (+ and -) require consistency in the units
  • Multiplicative operators (* and /) perform implicit conversion, so consistency in the units is not necessary
  • The expression engine must have changed since version 0.19, in which additive operators were agnostic to units
Zoltan
Post by Zoltan »
I made some detective work and I think I found the source of the problem. Here are the steps I went through, hopefully it will be useful for others when encountering issues with FreeCAD.
  1. Simplify the problem
    Thanks to onekk, I know exactly which part of the expression causes the error. So I came up with a minimum working example (MWE):
    >>> from FreeCAD import Units
    >>> Units.Quantity(1.0, Units.Unit(1)) + 2
    3.0 mm
  2. Browsing GitHub for existing issues, PRs and commits
    The search term unit mismatch did not give answer to my problem. Same on the old issue tracker.
  3. Checking the documentation
    The corresponding wiki page gives an example for the addition of units, right at the beginning:
    Operators and functions are unit-aware, and require valid combinations of units, if supplied. For example, 2mm + 4mm is a valid expression, while 2mm + 4 is not (the reason for this is that an expression like 1in + 4 will most likely be interpreted as 1in + 4in by humans, but all units are converted to the SI system internally, and the system is not able to guess this).
    Therefore, according to the wiki, my example should not work! Maybe it was introduced in a later version?
  4. Finding when the feature was introduced
    I clicked on View history at the top right corner to find out when the referenced sentence was written. Looking at the complete history, it turned out that even the very first wiki entry mentioned it. And that entry was written in September 2015, well before FreeCAD 0.19!
    Then I realized that I was using the RealThunder fork of FreeCAD 0.19. So I downloaded the official version 0.19.3, the latest bugfix release available for Linux. My MWE fails there. This means that adding a unitless quantity to a length is supported only in the RealThunder fork, not in base FreeCAD. Although I could not find it.
Conclusion: since I do not need the Assembly 3 workbench, I will use the official FreeCAD releases.
